Hotpoint WM83 control module plug connections
I just replaced the door interlock on my WM83, and when I removed the control module for access, I forgot to note the position of two of the wiring plugs (although I correctly noted all of the others....): The ones that i didnt note are:
1. The purple connector (2 black wires), and
2. The white connector (4 black wires going to the triple switch bank)
Advice would be very gratefully received.
Fixed it - by a process of elimination and logic :) What was worrying me initially was the fact that it is possible to fit the connectors in either position (Hotpoint!).
Posted on Jul 04, 2008
Hotpoint wdl520 aquarius not switching on!
hi if you are getting no power at all and fuse in plug good i would check interlock that is were door locks in next is control panel usually interlock is cause
Jan 01, 2014 | Hotpoint Aquarius WD63 Front Load...
We have a Lexmark printer C534dn and it keeps displaying 113.01 Service Printhead error. We have tried turning it off and sitting then turning it back on with no success. Of note the printer is plugged...
Try this:
  1. Is the front access door completely closed? Not?
  2. Turn the printer off, and remove the rear cover.
    Check the connector JINT1 (5 V interlock
    switch cable) for proper connection to the
    system card, the cable for pinch points, and the
    cable or connector for any other damage.
    Is the cable damaged? Yes? Replace the front access
    door 5 V interlock switch.
    Not?
  3. Turn the printer power on, and check for 5 V dc
    between JINT1 pin (red wire) and ground.
    Is voltage present? Yes? Replace the front access
    door 5 V interlock switch.Not?
  4. Replace the printhead. Doesn't the error clear?
  5. Replace the system card.
Jun 30, 2011 | Office Equipment & Supplies
My Hotpoint WF000 washes the cloths but won't spin. The On/Off light flahes but nothing else happens. Any advice???
Check the door is closing proerly and is fully engaged,.
Check door interlock, and the control module connections.
Hope this is of some help to you.
Dec 05, 2009 | Hotpoint Washing Machines
How do I remove and then replace a new door seal on my hotpoint WD420 washer / dryer
First switch off electrics , Remove door interlock , leave wires on .remove soap dispenser,remove front panel with controls 3 screws top of machine 3 screws bottom remove front casing you can now see door boot. remove sring note how boot came off refit is oposit to this noting top / bottom of seal ..Hope this some help-
Oct 03, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint Aquarius WF320
interlock is device which prevents door opening when machine is operating. why do you want to change it?
to access interlock. remove door gasket from cabinet in area of door handle and interlock is held by 2 screws from outside
Aug 08, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hi I’m after some help fixing a Hotpoint washing machine WMA40 the door locked LED is constantly flashing, I replaced the door interlock but the same thing happened. However on the new interlock was a...
Remove the front control panel where the controls are...
undue the three screws by the soap draw to do this.. Behind this panel is a pcb board,,,, detach the board from the plastic panel and check that it is not blown... check by the biggest wiring plug.... it might be blown.....
if not let me know and i will try my best to resolve...
Jan 22, 2008 | Washing Machines
Door interlock flashing
Same issue with loose solder joint on the relays inside CCU (computer control unit)
the same bad CCU is used by several manufactures.
you have to open the CCU and re-solder the the relays to the board. they have microcracks around the legs.
you will get the door lock issue randomly.
to prove the issue open the top access panel .and pull up on the center black plastic connector and the issue will go away.
Dec 14, 2007 | Hotpoint Aquarius WD63 Front Load...
HOTPOINT AQUARIUS WF250
it may be the interlock but is more probably the control PCB in the fascia, this is not a DIY repair as it requires programming when replaced.
Reagrds
Advisor
Nov 10, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WF860
when the machine was flashing door this was telling you that either the door was not shut properly, try it again, or the interlock switch was faulty, chances are its probably shorted out and blown the circuit board, take care and remove the board to check for signs of blowing, if no signs then i would replace the interlock and start from there, ps i am a retired engineer and have had the same machine myself
Sep 30, 2007 | Hotpoint Ultima WF860 Front Load Washer
Door indicator prevents microwave from starting
This is usually an indication of a bad door interlock. Take resistance readings with the power turned off on the primary and secondary interlocks. You will need to remove the control panel to access them. There should be a wiring diagram somewhere inside the control panel to assist you in determining if the interlock is normally OPEN, or normally CLOSED. As you open and close the door the interlock should change states. Additionally, double all your connectors to make sure they are plugged in correctly. I had a similar problem once and it turned out to be a loose connection on one of the interlocks. I hope this helps you.
Aug 04, 2007 | KitchenAid KBMC140HSS Convection/Microwave...
Washing Machines Logo
117 people viewed this question
Top Washing Machines Experts
