Question about Dewalt 7.2-18.0 Volt One Hour Charger
Drawing Hi Kinfax, Is there a chance you could email that drawing of the Dewalt battery charger? I'm trying to convert mine over from 120V to 240V. Regards, Richard.
  • 7 more comments
  • the charger Jul 03, 2008
    Hi Kinmax,
    As I said I am trying to convert my charger from 120V to 240 V and need a circuit diagram. If you have one could you please email it to ferrismail@iinet.net.au
    Thanks again,
    Charger.
  • cakramer Oct 14, 2008
    Can you email me a copy of that schematic also? I am doing research on battery chargers.
    Thanks,
    cakramer@jacks.sdstate.edu
  • error_id10t Oct 21, 2008
    I'm also trying to convert a charger from 110v to 240v. That circuit diagram would be useful, if you could email it to me.
  • Burrrrp Nov 30, 2008
    Hi, I read here that there is a schematic for a DW9116.
    Would it be possible to get a copy of it emailed to me?
    Thanks all.
    kurt@itu.com.au
  • Anonymous May 18, 2009
    I need also, please.
    sveclibor@gmail.com
    Thanks a lot
  • ziki kroizman Aug 04, 2013
    may i get the diagram & changes as well
  • michael Skov Sep 25, 2013
    Hey i know it is an old tred but can ennyboddy send me the scematic
    Is there a chance you could email that drawing of the Dewalt battery charger? I'm trying to convert mine over from 120V to 240V(michael.skov@mail.dk)
Have a look here, you need to change 4 components to convert a dewalt 110v charger to a 220v charger http://translate.google.com/translate?js=n&prev=_t&hl=en&ie=UTF-8&layout=2&eotf=1&sl=zh-CN&tl=en&u=http%3A%2F%2Fwww.zuojiaju.com%2Fthread-13314-1-1.html&act=url
Posted on Nov 15, 2010
    Is there a chance you could email that drawing of the Dewalt battery charger? I'm trying to convert mine over from 120V to 240V (michael.skov@mail.dk)
I need also, please
Alexgrbicus@yahoo.com
Thanks a lot
Posted on Sep 19, 2008
  • 6 Answers
OK, sorry, because my internet connection went down for near a month, so ...
No problem for that, just give me your e-mail address.I will e-mail you ASAP.
Posted on Jul 03, 2008
Is the Dewalt DE9108 battery charger suitable for charging Ni-Mh batteries?
  • For Battery Type: Ni-Cd Ni-MH
  • Input Voltage: 110V-240V
  • Smart Charger for Dewalt 7.2V ~ 18V Ni-Cd Ni-Mh Li-ion Battery
  • For Brand: DEWALT
  • Color: Black
  • Brand New: A brand-new, unused, unopened, undamaged item in its original packaging
May 04, 2015 | Dewalt Drills
Can I use this thermostat to control a 310w, 120v heat lamp load?
Voltage & Amperage are two different things. Check how much amperage iheat lamp requires. Rich
Apr 13, 2015 | Dimplex ETS610A1 Electronic Line Voltage...
Dewalt dc012 won't run on 120v?
change tranformer for converting 12 volt from 110
May 06, 2014 | Dewalt DC012 Radio/charger,120v Ac Or 7.2...
Hi. I have a charger for 18v Dewalt Li-Ion (dc9130 120v 60hz) and I'd like to find a circuit diagram so I might be able to convert it to use with 240v 50hz. So I probably need the diagram for the 240v one...
most chargers will fuction on 240/50 hz, look closely at the writing on the charger, it may say. I have laptop chargers and have used the overseas with no problem, that being said, you might try contacting dewalt and asking them if you can do it. Like I said, it probably already will work without doing anything. i have seen some devices (amplifiers mostly) that have a switch on the bakc to switch voltage, ( I don't recall ever seeing a switch to change line frequecny though), hope this helps a bit
Mar 10, 2011 | Dewalt Drills
Can you put a aussie 240 volt plug on an US battery charger
Look at the specs on the label, if it says that the charger is capable of taking a 240v input then you can change the plug and use it at 240v with no problem. If it says 120v then you won't be able to, you'll want to use a transformer or some other 240 to 120v supply.
lp
Dec 26, 2010 | Dewalt 7.2-18.0 Volt One Hour Charger
I am from Israel and our main supply here is 240volt . I bought a BOSCH 36volt drill kit from USA and I am interested to make changes in the charger in order to fit our supply .
look for a travel converter or 240v to 110/120v converter usually the adapter will plug into ur outlet and the charger[or whatever] plugs into the adapter and can convert the power down to the lower i have used mine every time i go to europe the adapters cost between 10 and 15 dollars mine is a one piece multi-use 8 different outlet designs- its easier than rewiring the charger
Feb 01, 2010 | Bosch 18V Compact Litheon Drill/Driver...
Dewalt charger
Ok, for easy way, you can just put a 1~2A diode in series of the input 240v power wire, so the after voltage would be around 120v, but for precaution it is better that you put two diode in series, it will give you same result. In addition, I have already tested it on a similar charger, it works fine.
p.s: I do have a similar one that is also 110v, I compared it with other 240v one. They worked same.
Jul 03, 2008 | Dewalt 7.2-18.0 Volt One Hour Charger
Changing Dewalt charger from 120V to 240V
all i can say get a seperate step up transformer fron 110v to 220v.then just plug in charger to the step up transformer. make sure that u have 2 consider the frequency in ur country.
Change 120v chager to run on 240v
all you needs is a step tranformer from 110v to 220v ac
Nov 13, 2007 | Dewalt 7.2-18.0 Volt One Hour Charger
Dewalt 7.2-18.0 Volt One Hour Charger Logo
1,149 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
