Question about Dewalt 7.2-18.0 Volt One Hour Charger
Changing Dewalt charger from 120V to 240V
I also want to covert my charger from from 120 VAC to 240 VAC, did you get any useful responses???
  • 313 Answers
All i can say get a seperate step up transformer fron 110v to 220v.then just plug in charger to the step up transformer. make sure that u have 2 consider the frequency in ur country.
Posted on Aug 21, 2008
Look on the information label to see how many amps it draws at 120 volts. Multiply the amps by 120 to get watts. Next you'll need to get a transformer that will handle the watts when changing 240 volts to 120 volts
Oct 10, 2014 | Aroma Rice Cooker ARC-150sb 20-Cup Cooked...
Led wiring diagram on 240V AC
Is Led 120V or 240V?
For 120V you need a neutral wire.
240V generally does not have neutral wire.
Aug 14, 2014 | Hardware & Accessories
I have a customer that recently replaced his generator, problem is , he got a 120 VAC output. He has 2 SW 4024 for 240 VAC output. Can I hookup the 120VAC to the master inverter, or should I get a...
I will accept the second option which is getting transformer.
Go ahead and get a transformer in order to step up the voltage. This is better than hooking up the 120V AC to the master inverter.
In summary, get a transformer to step up the voltage.
I hope this is clear now....
Good luck.
Apr 01, 2011 | Xantrex Technology Xantrex SW Series...
Hi. I have a charger for 18v Dewalt Li-Ion (dc9130 120v 60hz) and I'd like to find a circuit diagram so I might be able to convert it to use with 240v 50hz. So I probably need the diagram for the 240v one...
most chargers will fuction on 240/50 hz, look closely at the writing on the charger, it may say. I have laptop chargers and have used the overseas with no problem, that being said, you might try contacting dewalt and asking them if you can do it. Like I said, it probably already will work without doing anything. i have seen some devices (amplifiers mostly) that have a switch on the bakc to switch voltage, ( I don't recall ever seeing a switch to change line frequecny though), hope this helps a bit
Mar 10, 2011 | Dewalt Drills
Can a 240 volt outlet be ran off this breaker and can a 240 volt electric baseboard heater be wired to it or should i use double pole breaker?
You need 240 breaker:
Notice that your 240V breaker is twice as wide as regular 120V breaker.
Notice that both switches are tied together on 240V breaker, making this a double-pole breaker.
For more information about breakers and 120-240V circuits:
Jan 24, 2011 | Siemens 20 Amp Single Pole Breaker 120/240...
Can you put a aussie 240 volt plug on an US battery charger
Look at the specs on the label, if it says that the charger is capable of taking a 240v input then you can change the plug and use it at 240v with no problem. If it says 120v then you won't be able to, you'll want to use a transformer or some other 240 to 120v supply.
Dec 26, 2010 | Dewalt 7.2-18.0 Volt One Hour Charger
I have a ups system that i am feeding with 240 vac phase to phase and both phase to ground readings are 120 vac but when i go to battery power i get 240 vac phase to phase and 1 phase to ground i get 220...
No, I don't think there is anything wrong. Your UPS seems to have a single phase 240V output, which seems to be "floating" (no or only a weak ground reference).
Just be aware that you can only power 240V equipment from it. If you need 120V for some devices _and_ if the UPS provides sine wave output, you could use a step down transformer for this purpose.
Mar 12, 2010 | Tripp Lite Smart Pro UPS System
Electrical how to make it to 120v.
The drive motors for the washer and dryer run off 120 VAC, but the heating circuits require 240 VAC in order to work. You will need to have a 240 VAC outlet installed in order for the appliance to run properly. There is no conversion for this. This is the way the appliance was made.
Oct 07, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dewalt charger
Ok, for easy way, you can just put a 1~2A diode in series of the input 240v power wire, so the after voltage would be around 120v, but for precaution it is better that you put two diode in series, it will give you same result. In addition, I have already tested it on a similar charger, it works fine.
p.s: I do have a similar one that is also 110v, I compared it with other 240v one. They worked same.
Jul 03, 2008 | Dewalt 7.2-18.0 Volt One Hour Charger
Dewalt 7.2-18.0 Volt One Hour Charger Logo
1,322 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
