Question about Cooktops
Install cooktop hi, im putting in a new cooktop, and all it had in the box was the top, not manual and nothing to clamp it down. should there be something with it to clamp it to the bench? or does it just.... sit there?
  • Amy Wooley Jul 05, 2008
    ok, thank you very much. i would have thought it should be sealed, but as there was no booklet with it, i didnt know. i just thought for hygene reasons, incase liquid gets under the edge a bit. thank you once again, now i can go and cut the hole to fit it in...
  • goftadeh Jan 05, 2009
    the edges of cooktop are not flash with contertop-
  • 413 Answers
Most cooktops do not require clamping devices, it hangs from the counter top. Do not adhere or use caulking to secure to counter top. Some day it may require servicing and will have to be removed.
Posted on Jul 05, 2008
Im trying to install this cooktop maytag mgc7430ws, there are two brackets in it and there is absolutely nothing in the instructions about how to attach it to the cabinet
I just put one of these in. You're right, there is nothing in the instructions about this, I had to figure it out for myself.
Your kit includes two brackety-shaped steel brackets and two long screws. Look on the bottom of your cooktop, halfway between the front and back on the left and right edges and you'll see a hole on each side. They are the only holes on the bottom.
Manipulate the brackets until you see that the hole in the bracket matches the hole in the bottom AND the bracket fits upward along the side of the cooktop. The flange on the top end of the bracket goes against the bottom of the countertop.
It's useful to have another person lift each end of the cooktop while you insert the bracket from below.
Once the brackets are in lace, center the cooktop so it's straight on the countertop, then screw the brackets to the bottom of the cooktop. They will tighten against the countertop and make the cooktop stop wiggling.
May 31, 2011 | Maytag MGC7430WS Stainless Steel Gas...
Replacing an old jenn air electric cook top with new 30" down draft gas cooktop. Need to know how to secure the cooktop to the granite countertop.
You should just be able to set the cooktop in after you attach the downdraft, usually there are tabs on the downdraft that clamp on to the granite cutout. There is probably a closed-cell foam strip that runs under the lip of the cooktop, I would just make sure it seals to the granite properly (no gaps) and put a couple dabs of silicone in between the lip of the cooktop and the granite. Usually the cooktop is heavy enough that the silicone will keep it from moving around.
StoneRepairman.com
Brandon@Stonerepairman.com
406.471.0000
Mar 25, 2011 | Jenn-Air 30 in. Expressions CCGX2420 Gas...
My smeg SE2640TC1 cooktop is cracked and we need to replace it. How do we go about doing this - (ie hardwire etc)
To replace the cooktop the first thing you need to do is turn off the breaker outside that supplies the power to the cooktop.. Then go under the cooktop in the cabinet and follow the flex power cord to the wall. Remove the cover plate on that box in the wall. un connect the wires from the wires in the wall. Next look up at the bottom of the cooktop to make sure there is no clamps that hold the cooktop to the counter top. if there is remove the. Then just lift the cooktop off the counter top. from here you just reverse the steps to put the new one in.
Good Luck
May 26, 2010 | Smeg 23 in. SA435X Electric Cooktop
We have a Thermador Mod SGCS365RW 5-burner that was new in 2001 and installed for Propane. It has worked fine until yesterday - the top center burner does not get gas to the burner. The igniter works fine....
Hi, if the other 4 burners are working fine, the problem must be in the valve stem. There is a linkage inside the valve body which may have stripped itself. If this is the case you would need to replace the valve.
Feb 04, 2010 | Thermador SGS36GS Gas Cooktop
Remove embedded/inset smooth electric cooktop
HI they just sit on the top with brackets holding from the underside or screwed in from under the top sounds like this was put in the tiled after they arestuck downfwith double sided tape as well some times , if nothing works you could go through the top it breaks like a car windscreen hope this helps
Jan 25, 2010 | Cooktops
How do you get the black top off. I have to put in a new front burner. Thanks.
I had the same problem. Mine was caused by liquid seeping into the infinite switch (the switch that gets rotated by the knob to set burner temperature). This caused one of the live wires to short to ground within the switch. Bad Design IMHO. Replacing the switch fixed the problem (you can get replacement parts at Searspartsdirect.com - search using the cooktop model number).
You first need to remove the unit from its installation. Start by disconnecting the exhaust fan from the ductwork. Then push the cooktop up.
To get at the switch you need to remove the top by taking off only the top row of screws all around the unit and also in the down draft cavity (the down draft cavity is where the grease guard mesh is)
Turn off the circuit breaker to the cooktop. Verify by making sure the burners/fan do not come on. Disconnect the exhaust fan (underneath the cooktop) from the ductwork by removing the tape that joins it. While you are underneath the cooktop, open the junction box. Label the four wires that are joined so that you will be able to connect them later. Then disconnect the four wires. Remove the metal sheating that connects to the junction box (there is a nut on the inside of the junction box that you loosen. Pull out all the supply wires (from the mains) from the junction box. Then push the cooktop up and out and lay it flat on a table with the flat side down.
Take off only the top row of screws all around the unit. Rotate the unit so that you can get to the down draft cavity (the down draft cavity is where the grease guard mesh is). Remove the two center screws. Then pull the black top off.
For an exploded view of the unit check out
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47639&diagram_id=681565#d681565
Sep 03, 2009 | Jenn-Air JED8430 Electric Cooktop
Spot on Jenn Air smooth cook top stove with down draft.
Use Cooktop Cleaner with a soft micro cloth. Don't use water. Buff until the mark disappears. Hint: Never clean the cooktop until it is completely cool to touch as doing so makes cleaning much harder. Never use abrasives on the glass or abrasive cast iron skillets.
Mar 26, 2009 | Jenn-Air JED8430 Electric Cooktop
Jenn air cook top
Yes you can. Call Jenn Air ((877) 232-6771) and give them your model number (serial is helpful too). They sent my replacement glass within a week. I have a model JED8430ABD from 2000 and they had the top. Fit perfectly and took about an hour to replace.
To change it out, after unplugging the cooktop, I removed the metal tape connecting the external vent shaft to the blower. Then I just lifted the entire cooktop out up out of the countertop so I could access the screws on the sides of the cooktop (looking at the edges of the new cooktop glass helped me figure out which screws to remove around the edge). Then I removed the 2 screws in the vent area on top (1 black screw on each side). And that released the cooktop glass from the metal box that holds the burners. I then took the rubber rings out of the knob holes so I could put them in the new cooktop (I almost missed that...). Finally, I put the new cooktop glass on, put the screws back in, lowered the cooktop back into the counter, and retaped the blower to the vent shaft. Voila!
I really wouldn't be afraid of doing this yourself if you are handy at all. And it will save you a ton. Good luck.
PS The screws around the perimeter are hexigon shapped, so you can't just use a screwdriver. I found my Black & Decker electric screwdriver had that same shaped hole that it held the bit, so I just pulled out the bit and used the screwdriver that way. Worked like a charm.
Feb 09, 2009 | Jenn-Air JED8430 Electric Cooktop
Electric stove top
Follow the wire, It should go to a junction box within 4 feet. It may be behind a cabinet. Remove the box cover and unscrew the wire nuts. It usually uses armored wire and this is clamped to the box. Release the clamp . Turn off breaker or remove the 2 fuses first.
Jun 08, 2008 | Cooktops
Removing and reinstalling
There should be removabe clamps attatched to the bottom of the cooktop which tighten with a screw to the bottom of your countertop. Loosen the screws to the countertop, then remove the screws that attach the brackets to the cooktop. The cooktop should then be able to be pulled out.
Apr 07, 2008 | Jenn-Air 30 in. CVE3401 Electric Cooktop
Cooktops Logo
203 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
