Question about HP LaserJet 3050 All-In-One Printer
Hp 3050 error 49
When i switch on the printer i get an error 49 on the printer asking me to switch off and on but the error does not disappear neither can i print, fax or copy. i have checked a number of manuals but still no soln, a friend told me it could be the main board any ideas
  • 2 more comments
  • Sandeep Shrivastava
    Sandeep Shrivastava Jul 15, 2008
    give the error 49 turn off then on
  • Anonymous Sep 13, 2008
    PRINTER READS "49 ERROR TURN OFF THEN ON"
    AND THIS GOES ON EACH TIME I COMMAND A PRINT JOB.
  • Dheeraj b Feb 28, 2009
    Sometimes When I give print then "Error 49" Comes and Printer Reboots Automatically And After Rebooting Print out comes or Printer Reboots Again.
  • Anonymous Apr 01, 2009
    i have same problem
On the menu setup and then mover to usb opption. choose full usb (do not choose hight usb) now ii's ok!!!
Posted on Jun 15, 2009
49 error can occur when the printer receives a corrupt print job and needs to be cleared.
I would suggest you to cold reset the printer, do the following:
1. Press the menu button, then right arrow to Main Menu- Service. Press Enter.
2.Press the right arrow to Service - Restore Defaults, then press Enter.
3.Wait for the printer to initializeand com to ready.
Posted on Apr 02, 2009
It is comm. error. replace the formatter board. it is a board that use to connect usb.
Posted on Jul 30, 2008
49 service error ff04
your printer driver is corrupt or the files your printing are corrupt- most 49.xxyy errors are down to software external to the printer. not sure?.
disconnect the printer from all network points and cycle the power - when it is ready perform a path print test ( found under the diagnostics menu on the printer itself ) and you will likely find no errors ( if by some horror of horrors you do get 49.xxyy error then you will need to replace the firmware chip - Very Very unlikely) -
what to do--
remove the printer and uninstall from the workstation - reboot the PC - re install the latest driver for your operating system downloaded from HP website
re connect the printer - print away !!
Jan 28, 2014 | HP LaserJet 4600dn Color Printer
79 error in hp laserjet 3050 all in one printer
Turn off the printer wait 2 minutes, then switch on check. up date firmware, replace formatter assm.
Sep 09, 2011 | HP LaserJet 3050 All-In-One Printer
49 error on HP laserjet 3050
Internal Embedded Software Error. Manual says to power off for 30 seconds. Power it on and let it initialize. If the error persists you will need a tech.
Aug 15, 2011 | HP LaserJet 3050 All-In-One Printer
I have prblem in hp laserjet 3050 49 error
Hello and Welcome
Error 49 is usually a critical firmware error which cause the processor on the formatter to abort operation.This type of error can be because of invalid print commands,corrupt data,or invalid operations. Sometimes electrical noise in the cable can corrupt data during transmission to the printer. Other causes include poor quality parallel cables or poor connections,
To solve this try this solution step by step:
  • Turn the printer off and then back on.
  • Try printing a job from a different software application. If the job prints, go back to
  • the first application and try printing a different file. If the message appears only with a certain software application or print job, contact the software vendor for assistance.
  • f the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or PC.
  • Turn the printer off.
  • Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in slot J1.)
  • Remove all EIO devices from the printer.
  • Turn the printer on.
  • If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each
  • device.
  • Replace a DIMM or EIO device if you determine that it causes the error.
  • Remember to reconnect all cables that connect the printer to the network or computer.
If the error persists, final option is replace the firmware or best & final option is to just contact to any HP service provider
I hope this solution will be helpful for you. Anymore help, I am here to help
THANKS and keep Visiting FixYa
Apr 02, 2011 | HP LaserJet 3050 All-In-One Printer
Model - HP Laserjet P2055dn. Issue - 49 Err 64003D5, Turn off and then on . Tried many times, keeps showing the same error after turning on. Change the network cable but no use
Had the same error. Turned out the pdf I wanted to print had an empty page. When I removed it, the error disappeared and I could print the document.
Mar 13, 2011 | HP P2055DN LaserJet Monochrome Printer
The error "49. FF05 SERVICE ERROR" is displayed on
If the error can be reproduced, use the following sections of this document:
  • Product-specific documents Product specific document are available on the HP support website at the following url http://welcome.hp.com/country/us/en/support.html . Select your product and use the search string Product specific 49 errors to locate your product specific 49 error troubleshooting document(s).
  • Clearing the error
  • Validating the firmware
  • Stack Trace Random error troubleshooting
  • Hardware troubleshooting (if applicable)
Power-cycle doesn't eliminate error If the error cannot be eliminated by a power-cycle, use the following sections of this document.
  • Hardware
Feature-specific error The error has been narrowed down to a specific feature.
  • Software, Sending, Faxing, and environmental troubleshooting
Oct 26, 2010 | HP LaserJet P3005d Printer
I have three hp all-in-one laser printers 3050. On two of the printers the solder holding the usb cord is broken due normal use of unplugging the printer from the computer. I'm told this is the most common...
the device may need a firmware upgrade to deal with pdf signals that cause error 49 errors. these can be found with all documentation and software at hp.com, good luck.
Mar 27, 2010 | HP LaserJet 3050 All-In-One Printer
HP 3050 Engine Comm error
I have a HP 3050 three in one and I keep getting a engine comm error
Aug 02, 2009 | HP LaserJet 3050 All-In-One Printer
Cannot scan
hi,
first thing keep u r printer cd ready.Second uninstall your printer from add and remove programs and also disconect the printer from computer.Know re start your pc and install printer drivers with cd dont connect the printer untill it askes to connect. once setup asks u to connect connect the printer cable to your computer.Once the setup is finished then trie scanning from printer to pc. It will work.
Achanak3
Oct 02, 2008 | HP LaserJet 3050 All-In-One Printer
HP Laserjet 3050 won't print - os X
Power off printer, disconnect all leads such as USB, network, etc and power on again.
Does it power on to the normal state?
Are there any messages on the control panel or light patterns (eg off, on, flashing etc)?
Dec 30, 2007 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 3050 All-In-One Printer Logo
3,715 people viewed this question
Ben Johnson
