Konica Minolta DiMAGE X50 Digital Camera
Problem for Konica Minolta DiMAGE X50 Digital Camera
Message Unable to use card.
By pegbink1 on Jul 03, 2008
The camera just started giving the message unable to use card. It will take pictures when the card is removed. Just started doing this. Can you help?
Thanks, Peggy
Same Problem
May 18, 2009
-   I have the same problem. The problem occured when I was shooting a in video mode and while it was prosseng to changed the switch to photo mode.-   marcam905
Dec 27, 2008
-   I just started having the same problem. I read the manual and the card that I was using wasn't on the list of cards that has been tested to work with my Nikon. The card I had first was from Kodak. I am now trying Sandisk. It is working now. I'm still a little leary that it will start acting up like the Kodak card.-   rhardage
Oct 19, 2008
-   the SD card (kingston) already has photos in . While i continue to use it to take photos, suddenly it jus shows unable to use card. all existing photos cant be retrieved from pc or camera. in the camera, it shows unable to use card. in pc, it shows msg please insert the disk-   geenais
Solution #1
posted on Jul 03, 2008
Not Rated)
Richie_asg1
Rank: Guru
Rating: 87%, 434 votes
I've seen quite a few problems regarding memory cards recently.
Most of the time it is the card at fault as it just does not store data anymore. I haven't yet determined if it's time/ use/ temperature or handling which is causing the faults.
Can you describe what happened prior to the card not working as it may help solve future problems?
Some older cameras cannot use the newer - larger cards (even though they fit), and some cards won't record panoramic data.
Try resetting the camera first. - Remove batteries and card for 10 minutes, then reload them.
If you normally use a PC to download the pictures, see if you can access the pictures from there.
If half have gone, or are corrupted, it's time for a new memory card. Films were 1 shot, now cards only last a few years, but still saves you £ / $ in the long term.
If the new card doesn't work either, you will need to re-install the camera software (or Driver). This should be on a CD or you can go to their website to download it free.
Thanks for using Fixya! If this solves the problem, please rate as such. Thanks.
Was this helpful?
Yes
No
Popular Solutions for Konica Minolta DiMAGE X50
Questions and Unsolved Problems for Konica Minolta DiMAGE X50
Do you recommend Konica Minolta DiMAGE X50 Digital Camera?
Answer
Answer
Hi I am going to Lapland and need to know how or what setting to have my camera on for snow. I dont... (More)
Answer
Konica Minolta Dimage x50 digital camera won't take still pictures. Red light flashes when in still... (More)
Answer
We are having an issue with our Konica Minolta Dimage E500. It turns on but the lens does not seem... (More)
Answer
I have the same problem too. The cam havn´t been dropped or mistreated in any way, still... (More)
Describe your Digital Cameras problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Digital Camera Experts
Top Camera & Camcorder Repairmen
in Newport, KY
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
