Question about Acer Computers & Internet
I had to reboot my acer now my hard drive is almost full. How I make space for it. Also i have an error 1 in my mass control. Help I didn't now that acer laoptops had so much problems. I plug the cord and spaks come out, battery never lasted more than half and hr. send to acer 3 times. nothing fix help me fix this junk laptop please.
    Master:
  • 788 Answers
Backup you files and documents to DVD then reload Windows using the restore DVDs or CDs the notebook came with. This will solve your space issue as well as your mass storage controller error.
Also sounds like you may need a new AC adapter and battery, both should be faily easy and inexpensive to purchase on eBay. Just search by you Acer model number and both the AC adapter and battery should show up. I would at least get the AC adapter, sounds like there is a break in your cable. I got one for my wife's Acer for under $30.
Posted on Jul 03, 2008
Hardware error code 11p in computer monitors
1 - Push the Active button on your remote control
2 - Push in the number code 1-4-0-6-1-1 into the remote control and then push the Select button.
3 - Select the Full System Reset option and then select again to confirm this.
4 - This will initiate a reboot of your system that will clear out your hard disk drive.
for more help visit Cbr tech solutions
Mar 16, 2014 | Apple Computers & Internet
Tip
PXE-E61 ERROR The error PXE-E61: Media test failure usually means the hard disk...
PXE-E61 ERROR
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty.
First - re-seat the hard disk and reboot the computer. If this does not work then reboot and go to the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Next - to determine if the hard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an USB mass storage device (external hard drive) and you cannot open the various folders and files, this confirms the hard drive is faulty.
The hard drive needs to be replaced in the laptop or desktop computer and Windows installed including the laptop or computer's device drivers plus your programs etc. to get a functioning laptop or desktop computer again.
on Mar 20, 2010 | Computers & Internet
ACER 4630z will not boot up
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 17, 2013 | Acer Extensa 5620 Notebook PC
My acer netbook "D" drive is nearly full
Go to your drive C:, right-click, scroll down to "properties".
An option will pop-out. Look towards the down part and select Compress...... Then click "this"< then "OK".
This will compress your hard-drive and give you more space.
I hope you understand this.
Good luck.
Nov 28, 2012 | Acer Aspire One A150-1006 Notebook
C drive too full
If there is a large number of unused space on other partition you could directly allocate the free space the your system partition, but keep in mind backup your important files is recommended no matter which way you use when re-partition hard drive, learn more from this link: http://www.extend-partition.com/help/allocate-free-space.html
Aug 09, 2012 | Computers & Internet
My notebook is very slow & on going unsolved problems,i was looking deleting divers and resetting notebook is this correct & how do i go about this.ive not tried to fix anything as yet,ive backed...
First of all, check the free space on your hard drive, if it is showing as almost full, this will be slowing down your computer. Use the maintenance command under properties to delete and clean up all dead data (cookies etc)
After that, delete the rubbishware that you do not use. I suggest you download this application to do this with
http://www.revouninstaller.com/revo_uninstaller_free_download.html
Now see if this improves the problems, if not and you are showing a decent amount of hard drive space, I suggest you run a command line virus scan and check for viruses and malware
I suggest this:
http://www.freedrweb.com/cureit/?lng=en
Run this in safe mode, allow 1 hours for it to scan and then do a deeper scan by setting the scan to C:/
After the scan has been completed, reboot and back in my computer, go to the C drive, properties and "check volume for errors"
Jan 14, 2011 | Acer Aspire 5100 Notebook
Acer 5315 HD C is full HD D empty
Very likely the answer is yes, IF: 1) there is enough space and 2) that D drive is not being used for something else. Check on what is on the D drive. It's usually reserved by the manufacturer and contains OS restore files (used for restoring your system after a crash). Don't delete these, but if there is enough free space, just create a new folder and put your files in there.
Jan 31, 2010 | Acer Aspire 5315 Notebook
Acer 3680. only half of the harddrive works.
check it on the bios the size of your hard disk, if its 80 gb then go to the control panel after booting open the administrative tools, open computer management, then select disk management, check the hard disk there, if there is an unpartitioned space , then convert it to the partioned space
Nov 09, 2008 | Acer Aspire 3680 Laptop
I have an ACER ASPIRE 5720 laptop - it is less than a year old and it is showing the memory is full - the memory is meant to be 32 GB and from what I can see from the programme menus there is less than 4...
Hi j0shuatsb,
Acer like many other manufactures seem to design their system to fail or have issues just after their 1 year warranty is up. Like other Microsoft windows operating systems, when you receive an error message that you're memory is full. This does not mean you have run out of RAM = memory. You're notebook can only run a max of 4GB of memory. The error message refers to hard disk drive space. Depending on you're operating system, windows will lock out so much drive space so it can move about. All notebooks also have a hidden partition which holds drivers & programs used in combination for running the system restore.
This hidden partition can range in size from 2GB up to 4GB.
This also lessens you're total hard disk drive space. Bottom line is there is nothing wrong with your memory.
What you need is a larger hard disk drive. Notice the Technical specifications from this link:
http://www.acer.co.uk/public/page9.do?sp=page4&dau34.oid=24360&UserCtxParam=0&GroupCtxParam=0&dctx1=17&CountryISOCtxParam=UK&LanguageISOCtxParam=en&ctx3=-1&ctx4=United+Kingdom&crc=512458878
It does not show what size you're SATA hard disk drive is.
Since you are still in warranty, now would be the time to increase you're drive size. On another note, if you're HDD is the standard 160GB than there is an issue with your current HDD.
Please run a full system virus scan.
Suggest you back up all you're personal data on to a DVD & run you're system restore CD including a format to help you regain you're HDD full space. A temporary fix would be to uninstall any non needed programs through Add/Remove programs. This should free up some space. Many Acer programs you do not use at all or need should be the first to go.
Mike
Aug 08, 2008 | Acer Computers & Internet
Maxtor diamondmax plus 9 6y080l0
IDE AND SATA CONTROLLER PROBLEMS ON MAXTOR DRIVES.UNINSTALL CONTROLLERS AND REBOOT,DO NOT PLUG IDE DRIVE IN.THEN REBOOT AGAIN PLUG IDE DRIVE AND LOOK IN DEVICE MANAGER IF DRIVE IS RECOCNIZED CORRECTLY.(ASUS BOARD) OR INTEL CHIPSET PROBLEMS.
May 20, 2008 | Computers & Internet
Computers & Internet Logo
51 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
