Question about Toshiba 120GB (MK1234GAX) 5400rpm 8MB Notebook (2.5 inch) [HDD2D16 9.5MM] 120 GB Hard Drive
Award bios cannot find or located properly wired Toshiba MK1234G.
No sign of the Toshiba MK1234G 120 Gb HDD drive presence when attempts to find it with the BIOS are executed and, of course, it is not available to the OS (WINXP). Laptop is a Toshiba Satellite M70. All the IDE wiring/cabling is exactly the same as the new replacement HDD which works perfectly.. The faulty HDD appears dead in the water and invisible to the BIOS and to the computer as a whole. Is there any repair software or mechanical/technical repair to restore access to the HDD?? Robert ZL2ROB, New Zealand
Skype address = zl2rob. Echolink = zl2rob
Email zl2rob@xtra.co.nz
  • 188 Answers
SOURCE: Toshiba A65-S1065 hdd compatibility
The hard drive should work fine thats a standard IDE drive.
For the overheating problem you probably just need to clean the fans with a can of compressed air. That series gets clogged pretty easily. Just blow from the bottom of the laptop where you see the fan towards the outlet in the rear.
You can boot from a USB floppy drive to do a bios upgrade - you can get USB floppies for $20 or so.
Or i have loaded a bios from a bootable CD (you can make one from Roxio or Sonic record now if you make a bootable floppy first - get one Here:
Posted on Dec 24, 2007
SOURCE: Can not change Bios Boot Device
remoove battery n start
press f8 n safe mode
shut down n restart
press/dell/f2/f10/f12 key
then u will go to bios setup
if changes is not saved then change cmos battery
Posted on Jun 18, 2008
SOURCE: 80 gb toshiba laptop is not detected in the bios.
When you power up the computer press F1 or F2 or "del" key then go to advanced .
Then disable SATA .
If already disable then enable it then save settings then check.
Let me know if you need more assistanse.
Thanks.
Posted on Aug 31, 2009
  • 1121 Answers
SOURCE: I have a new mk6034gax HDD from Toshiba which is
the hd has a internal registers, for oem old moterboards. you need to reset this registers and program correct values.
you may find this utilities on toshiba website on service
area
Posted on Nov 27, 2009
Slow toshiba K-2518A portable drive
Speed gradually reduces as u fill the HDD...how mush is your HDD filled?
Dec 27, 2013 | Toshiba 120GB USB 2.0 Portable External...
Alert! system protection failure password:.... toshiba satelite pro
Using a Backdoor BIOS Password Some BIOS manufacturers implement a backdoor password. The backdoor password is a BIOS password that works, no matter what the user sets the BIOS password to. These passwords are typically used for testing and maintenance. Manufacturers typically change the backdoor BIOS passwords from time to time.
AMI Backdoor BIOS Passwords Reported AMI backdoor BIOS passwords include A.M.I., AAAMMMIII, AMI?SW , AMI_SW, BIOS, CONDO, HEWITT RAND, LKWPETER, MI, and PASSWORD.
Award Backdoor BIOS Passwords One reported Award backdoor BIOS password is eight spaces. Other reported Award backdoor BIOS passwords include 01322222, 589589, 589721, 595595, 598598 , ALFAROME, ALLY, ALLy, aLLY, aLLy, aPAf, award, AWARD PW, AWARD SW, AWARD?SW, AWARD_PW, AWARD_SW, AWKWARD, awkward, BIOSTAR, CONCAT, CONDO, Condo, condo, d8on, djonet, HLT, J256, J262, j262, j322, j332, J64, KDD, LKWPETER, Lkwpeter, PINT, pint, SER, SKY_FOX, SYXZ, syxz, TTPTHA, ZAAAADA, ZAAADA, ZBAAACA, and ZJAAADC.
Phoenix Backdoor BIOS Passwords Reported Phoenix BIOS backdoor passwords include BIOS, CMOS, phoenix, and PHOENIX.
Backdoor BIOS Passwords from Other Manufacturers Reported BIOS backdoor passwords for other manufacturers include:
Manufacturer BIOS Password VOBIS & IBM merlin Dell Dell Biostar Biostar Compaq Compaq Enox xo11nE Epox central Freetech Posterie IWill iwill Jetway spooml Packard Bell bell9 QDI QDI Siemens SKY_FOX SOYO SY_MB TMC BIGO Toshiba Toshiba Remember that what you see listed may not be the actual backdoor BIOS password, this BIOS password may simply have the same checksum as the real backdoor BIOS password. For Award BIOS, this checksum is stored at F000:EC60.
Her is a list of back door bios password resettes
Jun 20, 2011 | Toshiba Tecra A8-EZ8311 Notebook
Laptop don start because pc dont see hd
go to the bios when you turn it on, and undo or restore settings to default, maybe that will work, and check if hard drive stars first make sure. first cd room then hdd
Nov 19, 2010 | Toshiba MK1234GSX 120 GB SATA Hard Drive
New larger hard drive can only be detected as Primary Slave
Floydage, some ribbons are different in the orentation of pin#1. try a differnent cable...but you said that you tried that right.? have you tried to make sure you have the latist BIOS. It could be this paticuler drive have a different bios it self...and yes drive's do have chip's and software in them. If nothing ells just load the OS to that drive anyway and than change the drive letters in windows.
Feb 16, 2010 | Computers & Internet
I am not able to copy large files like 5 GB to my Toshiba 400 GB portable. It says there is no disk space. Any help!!
in fact your hdd is formatted in FAT32 filesystem for compatibility reasons but this file systems only can read files below 3 gigabytes or so, if you want to copybigger files you should backup all your hdd info and reformat it to NTFS filesystem that can handle these files
Dec 12, 2009 | Toshiba 120GB USB 2.0 Portable External...
Gigabyte 945 gzm s2 doesn`t recognize HDD Western Digital 320 GB
You might need to change your bios settings from ide to sata. Have you already checked the bios settings? If everything is in order you might have a bad board. What have you tried so far?
Nov 20, 2009 | Gigabyte GA-945GZM-S2 Motherboard
Bios Upgrade so to recognise new 320GB size Hard Disk Drive
first check jumper settings in harddisk.
also check there is no unpartrtioned space.
right clik on my computer then go to manage
then go to diskmangement
If there iks any unpartitioned sapce of 184 gb then create partition.
Mar 26, 2009 | Computers & Internet
Toshiba laptop
You don't have a USB thumb drive plugged in do you? Remove any discs ( CD, floppy etc ) & check the BIOS boot order to start with.
Apr 18, 2007 | Toshiba P25-S670 Notebook
Toshiba 120GB (MK1234GAX) 5400rpm 8MB Notebook (2.5 inch) [HDD2D16 9.5MM] 120 GB Hard Drive Logo
107 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
