Question about Ruud UBHC Air Conditioner
Old Ruud Air Conditioner
I have an old Ruud A/C electric split unit w/HP and need the wiring schematic for the inside air handler.
Model LJ(LI) QA-08108
Serial HM2392 3332
  • 20 Answers
All heat pumps follow the same schematics universal get a hold of any heat pump schem and you should be able to aplie it to yours
Posted on Jul 23, 2008
2 1/2 ton. home is about 1200-1400 square feet ?
Apr 18, 2016 | Ruud Matching Split Air Conditioner
Ac blower motor attic
that is a model number for the outside condensing unit. to find the motor size for the inside unit, you will need the model off of the inside unit, gas furnace or electric air handler.
Aug 15, 2013 | Ruud UAKA048 Air Conditioner
We want to change speed on air handler for unit Ruud UBHC-21A00NFA. We disconnected BLACK wire (Hi speed) and put in place of it RED (Lo speed). Is this correct to get Lo-speed on unit? Is there lower...
Hi, It depends on the make and model of the blower motor. You'll need to check this against the schematic (normally located within the electrical cavity) and work it from there. Some are two speed, some three. You can also look at the wires coming from the motor and check those that are taped off. There may be another wire, but check your schematic before changing any of the motor leads to the control board.
Best regards, --W/D--
Apr 28, 2011 | Ruud UBHC Air Conditioner
I have a Ruud Model # UACC-036JAS. Any idea on
Hi, yes the number you are showing me 036 indicates its a 3 ton unit. For every ton of cooling, you will have 12,000 btu's of cooling. 36 divided by 12=3 ton unit. Its showing me also its a Ruud Handler 2.0 ton which would be a Model# UACC-024JAS? If your mobel number is the one you gave me, UACC-036JAS, this is a 3 ton unit, absolutely no questions. I hope I have been of help to you. I am a licensed air conditioning / Refrigeration /Heating Contractor. Let me know if I have been of help.
PS If this is a split system with the indoor air handler and condenser outdoors, both coils must be the same tonnage for it to work for you properly. You can't have a 2 ton indoor evaporator coil with a 3 ton condensing unit.
Jun 28, 2010 | Ruud Handler Air Conditioner
I have a Ruud air-conditioner/heat pump and it blows 5 amp fuse.
It sounds like the thermostat wire going to the condenser is ground, It either got pulled loose and is touching the housing or as in most cases the wire got cut or was chewed by an animal. You need to turn electric off to both devices and physically inspect the thermostat wire going from the air handler to the outside unit, also inspect where they connect inside the unit. When you find the break, cut and strip each individual wire and securely wire nut each conducter red to red white to white and so on. There you go all fixed. That's when I give you the bill for $75...except this time you write that check to yourself. Good Luck
Jul 14, 2009 | Ruud UBHC Air Conditioner
what is leaking the inside unit air handler or outside compressor
Jul 05, 2009 | Ruud UBHC Air Conditioner
Old rheems ahd a reeset for head pressure on outside unit. May have took out the transformer. Check inside Air handler to see if there is five amp auto fuse in the fan board it may have blown. Rus
Jun 14, 2009 | Ruud Matching Split Air Conditioner
Electrical Schematic for Ruud URGG-10E37JKR
just a maybe , write to RUUD AT P.O. BOX 17010 , 5600 OLD GREENWOOD ROAD ,FORT SMITH ARKANSAS, 72917-7010, OR CALL 479-646-4311 AND SEE IF THEY CAN TELL YOU WHERE TO CALL FOR SAM.
Sep 20, 2008 | Ruud UAMB Air Conditioner
Wiring connection for a Ruud air handler & seeking its wiring diagram.
we are trying to install a goodman heat pump with a rheem air handler, the orange wire is hook up and the unit is still staying in the heat mood. does anyone have a wiring diagram for the air handler, their is some white wires in the air handler one with a purple strip and one with a black strip we need help
Jan 05, 2008 | Heating & Cooling
Ruud UBHC Air Conditioner Logo
339 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
