Hi, I just read what you have posted on my LCD TV troubleshooting guide, it does not sound like bad T-CON board because you do not get the sound, you disconnected the main T-CON connector from the main board and get the glowing screen but you still do not hae sound.
In the LCD TV, you can discoonect the backlights inverter board power cables (cables from power supply to the backlights inverter board), and the T-CON board cables from the the main board to the T-CON, you should still get the sound since there are no feedback singals from the T-CON or from the backlights inverter boards to tell the main board that they are bad or not.
If you are 100% sure that you do not have sound on all the input modes then I would suspect the main board problem.
At least the backlights ineverter is good.
Do you get the 12v at the T-CON board surface mounted fuse?
Testimonial: "Very helpful. Gave me some useful troubleshooting advice."
Thanks a bunch for the reply Budmrtn, I was beginning to lose hope anyone would be able to help with this stumper at all.
I disconnected the inverter board and the tcon board cables like you said and then tried all the audio inputs again with no difference from before. No audio signal coming from the speakers or from a set of headphones that I tried plugging into the output jack.
I tested all the wires going to the tcon board (at both ends) and the most Igot was 5 volts DC. There were some 3 volt signals and some 1 volt signals as well but I could not find any 12VDC anywhere going to the TCON board.
I do have what appears to be a good 12V DC coming out of the power supply going to the main board though. So if you are certain that there is supposed to be 12VDC going to the Tcon board then it's getting blocked somewhere on the main board.
I will try to follow the 12VDC signal through the main board and see if I can spot any obvious problems.
I'd still appreciate any further ideas or suggestions you might have.
Thanks.
Joe.
It's also possible that the speakers are somehow turned off in the menu but since I can't access or even see the menu I have no way of knowing.
Joe.
The 12vdc from the power supply module is used for the audio amplifirers for the speakers.
The T-CON uses SWITCHED 12VDC to power the T-CON board.
Did you find the surface mounted fuse on the T-CON board?
Can you post the pictures of the T-CON board? So I can see if it has more than one fuse on it.
Like I said multiple times before (sorry, hehe) I found only 1 surface mount fuse on the TCon board and I measured 5 VDC on either side of it when the tv was powered up and on. I'm assuming that means it's good. Still stumped. Any more suggestions / help very welcome.
Only 5vdc for 32" LCD PANEL does not sound right, I may be worng since most of the 26" and up LCD panels use 12vdc to power the T-CON board, but without diagram I cannot be sure. This will be tough to troubleshoot without diagram, I hate throwing in board until it works cause it can get real expensive. Keep me inform if you are able to get it to work, thanks.
Luckily I found a donor tv set with smashed lcd panel for next to nothng. Swapped out the Tcon board from that one and everything works fine in mine now. Thanks for all your help.
Thanks for posting the progress. What voltage are you getting at the T-CON board fuse?
Hehe, now that its working I'm too lazy to diassemble it again to test the voltage at the fuse. It was kind of clumsy to get at while all the necessary cables were still hooked up so I dont want to risk accidentally shorting anything out if I don't have to.
I was tinkering with the thing trying to find a problem with 12VDC so I decided to disconnect the one wire coming from the power supply providing the 12VDC to the main board. Suprisingly this had absolutely no effect. The screen looked exactly the same as when it was hooked up and the sound still didn't work. So I tried supplying the main board with an external 12VDC supply (an adapter spliced in) an this had no effect either. Audio / video acted the same. This makes me believe that the 12VDC supply from the power supply board is good and the problem (if any with the 12VDC) is further down the line if that makes any sense. Still baffled. Joe.
As far as I can tell the TCon board ony has one surface mounted fuse on it labelled F1 with a little 3 printed on it located just above the main input connector. I have a picture of it but nowhere to upload it to sorry. Joe.
As far as I can tell the Tcon board has only 1 surface mounted fuse labelled F1 with a little 3 printed on it and its located just above and to the right of the main input connector. I have a picture of it but nowhere to upload it too sorry. I will try to test for 12VDC at that fuse once I get it back together again.
