Question about Carrier 38CKC042 Air Conditioner
Model number for furnace
The following number was found above the serial number-on the firewall near the jets-58RAV095-16 -- Service series 130. Thanks-I believe this to be the model number you requested from me in an earlier response.
    Novelist:
    Champion:
  • 230 Answers
Great! That is it. Now you have the model numbers for all of your hac equipment.LOL. Anyway I do have this manual and I an send it to you via email if you like. It shows the jumper that I told you about as well as a picture of the circuit board and instructions on how to change the blower delay. Just shoot me an email. Good Luck!
Don,
cservice@square1hvac.com
Posted on Jul 03, 2008
Where can I download a diagram of inside of furnace?
It should be on the inside of the blower compartment door.f not, go online and google the model and serial number, which is found on the inside of furnace on the upper compartment.
Sep 04, 2015 | Heating & Cooling
What was production year of Kenmore Refrigerator series 60821, Model 106-8608260?
Hello Nancy;
My name is Peter. I am a retired field service refrigeration technician.
The production year is based on your unit serial number. Both the serial number and month and year of manufacture is on a label in your fresh food section, on the side wall near the top.
Jan 01, 2015 | Kenmore Refrigerators
My bryant furnace fan will not turn on. Everything is sequencing, the induction fan starts and the flame lights, but the fan will not turn on. The capacitor reads 4.86 uf. Any suggestions?
Your fan delay relay is not functioning. On most furnace fan controls, there is a fan delay relay that delay the fan from turning on until it senses the temperature increase, typically around 130 degrees. once the relay senses the temperature increase it closes a contact inside the sensor and turns the blower on. It is the same device that keeps the fan running once the furnace turns off. Just take the Model number and serial number to your local dealer and get a fan delay relay and replace it.
Dec 07, 2014 | Bryant Heating & Cooling
Just bought a 1931 Desoto, the serial number on the registration is 3A17410. I can't find anything with that number. Is it possible the number is a body style or engine serial number?
This is way out of my league, but here is some info that might help.
Before 1954 there was no uniform VIN number used in the USA.
In the years leading up to 1931 Chrysler Corp and a few other car companies used a FEDCO plate on the dash or firewall for the serial number ID of the car. The car was registered by this number by some states, and some used the engine number. Starting in 1931 the serial number was changed and moved to the door post. So a 1930 car should not have a plate on the door post.
The engine number was always stamped on the block. Also keep in mind 1931 Chrysler products were carried over into the 1932 model year, including Desoto.
The serial number depended on the make and model unlike cars of today. A series 31 model started with a number 6 or 8, while a series 32 model started with letters like SA or CFS, a series K started with the letter K, and so on. Actual serial numbers were seven digits.
On most models the serial number is also stamped on the frame near the front spring support.
You can do an internet search for DeSoto FEDCO numbers and serial numbers to get a general idea of how the serial numbers were arranged. You can also contact Chrysler Historical Society to see if they have the build card for your car. The build card would have both the original engine number and serial number. There are other resources including the Antique Auto Club of America.
Jan 26, 2014 | Cars & Trucks
How many tons is this Carrier unit? Model #38AH-034---610AA Serial #OBO1F65263
This is a 30 Ton Hi Efficiency Gemini series unit from carrier you can matched to either of these air handlers.
40RM028 40RM034
Model is broken down in sections
38AH = carrier Gemini series units from 20 to 120 tons the numbers following the dash represent the size 024 = 20 028 = 25 034 =30 044 = 40 054 =50 the list goes on in increments of 10 untill it reaches 130 tons 134=130
Hope this helps
Best of Luck
Jun 01, 2011 | Carrier Heating & Cooling
Where will I find the model and Serial numbers of my RUUD Furnace and Airconitioners?
Hello, usually you will find the Furnace model # on the inside of the Furnace near in the burner compartment. The AIr conditioner model # will be on the data plate on the outside unit.
Mar 02, 2011 | Heating & Cooling
I have the Model number and serial number but am unable to find the BTU's on mty furnace...Help please?
if you have the model number of the furnace, then you have the btu input of the furnace. The model number usually starts with letters, then the three numbers following the letters are usually the btu input of the furnace.
For instance if it said 075 then it would have an input rating of 75,000 btu/hr or if it said 125 then it would have an input rating of 125,000 btu/hr.
Hope this helps
Nov 16, 2010 | Heating & Cooling
Heater won't heat very long
there isnt a pilot if it has jets , it has a Hot surface ignitor. you should see a glow and then the jets light , if its running for a few min it may be overheating, have you changed the filter recently? you should also have a flash code you can locate when the furnace shut off and is no longer doin what its supposed to look thru the bottom door peep hole and watch for a series of red flashes. if you remove the cover after retrieving the flash code there will be a chart on the inside of the cover that will tell you why the furnace is shutting off. by the way the model # you gave is for the A/C coil above the furnace, not the furnace.
Oct 10, 2009 | Heating & Cooling
Furnace model number
I believe I have the manual for this unit. Just shoot me an email and I will send it to you. It describes in detail how to do this blower off delay.
Don,
Jul 02, 2008 | Carrier 38CKC042 Air Conditioner
Carrier 38CKC042 Air Conditioner Logo
178 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
