Question about Denon Audio Players & Recorders
Hi' I have a Denon 3910 that is connected to an Infocus Projector via HDMI out on the Denon to DVI on the Infocus(One end of the lead is HDMI the other DVI) .problem has always been without the projector being turned on the audio pulses on and off (wants you turn on the projector the pulsing stops)...Easy to get around though, for my CD/SACD/DVD-A playback I turn off the video circiutry with Denons "audio only" switch/settings for pure music playback(I just turn of the video in player which stops the pulsing). The problem has gone one step further as from last night with the video and audio now pulsing together with projector turned on (you can't watch a movie now at all without the pulsing effect).I tried connecting the Denon 3910 to component RGB to the Infocus projector and it works perfect in low Rez(no pulsing),the problem seems to be HDMI only. .. I first had the Denon 3910 back in 2005 connected via DVI out to DVI in on the Infocus and the pulsing problem never arose, untill I upgraded my cable to an expensive HDMI lead with an DVI adaptor one end for the projector..It's a 10 metre lead and takes afair bit of installing so I left it installed.. P.S. I just ran the old DVI lead to test it(Denon to Infocus) and it now pulses with it connected as well. Any advice would be appreciated .
    President:
  • 624 Answers
You can try this reset method, if it doesn't work it will probably need service by a professional. Remeber that all setting will be lost, make sure you know them so you can put them back in after you are finished.
At the player stop condition,
press 3 buttons for DVD operation
(“PLAY”,”OPEN/CLOSE”, and “ SKIP”) until
“INITIALIZE” appears and disappears in the display.
(“Initialized” appears and disappears on the TV screen.)
******All user setting will be lost and its factory setting will be
restored when this initialization is made. Be sure to memorize
your setting for restoring again after the initialization
Posted on Jul 03, 2008
Infocus 5000 won't recognize my computer
How about a little more information?
Does the projector turn on?
has it ever worked?
What type of interface (VGA, DVI, HDMI, RCA)
What type of computer (notebook or desktop)
That being said, double check your cable connections and make sure you tell your computer to look for the projector (Dell laptops used to use FN+F8 to switch from laptop to projector). Windows 7 has a menu choice "Connect to Projector". Mac computers - check system preferences and make sure the projector is ON before you plug it into the Mac.
Nov 25, 2012 | InFocus ScreenPlay 5000 Multimedia...
Looking at purchasing a used HP MP3135. In purchasing a HDMI female to M1-DA male adaptor, will this allow me to connect my laptop etc via HDMI cable? We also would like to connect a Wii and HD TV, how do...
HP available M1 to VGA (included )
Optional M1 to DVI (available on HP accesories)
To connect laptop via HDMI to Projector you need a HDMI to DVI adapter + Cable M1 to DVI (you get ONLY Video on DVI Output)
To connect Wii to projector you need a M1 to Composite
look the manuals on page 20-30
You can download the user guide on
http://h10032.www1.hp.com/ctg/Manual/c00063031.pdf
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 22, 2011 | HP mp3135 Multimedia Projector
What cable to i need to connect my InFocus projector to my lenova laptop?
Most laptops and projectors have VGA ports. So a monitor cable (not an extension cable) is needed; this is a cable with two male HD15 ends. The projector above has the following input available: Mini D-Sub 15 (Analog) (VGA), Component, and S-Video. If your laptop has DVI or HDMI you will need an adapter to go to the VGA.
I hope this helps.
Feb 25, 2010 | Philips cBright XG2 Multimedia Projector
PS3 to Infocus LP 350 projector using HDMI
M1-DA is a type of DVI connection that produces both analogue and digital signals, the easiest and most quality source cable for you to get is a HDMI to M1-DA cable which is now widely available for purchase.
Infocus should have included this cable in with your projector, but instead the power at bee decided to put a M1-DA to DVI-D cable instead when most visual devices now support HDMI and not DVI nowadays.
Thanks
Sep 04, 2009 | Sony Playstation 3 (PS3) Console
Hdmi connection problem
it does do dvi-d for computer, but does not handle high-definition video. it does not have the same resolution.
Mar 14, 2009 | InFocus Proxima DP6155 Multimedia...
Infocus screenplay 4805 not communicating with PS3 console.
Try pressing the "auto image" button on the projector itself. This sometimes solves these types of problems.
Nov 15, 2008 | InFocus ScreenPlay 4805 Multimedia...
No HDMI video signal to projector
cheak out put on samsung to set it at 720 hdmi out ect might nee dto use red green blue or s video to see menu
Feb 05, 2008 | Samsung DVD-VR357
Display resolution through dvi input HELP!
For the record I have a playstation 3 running to tx100 through hdmi to dvi adapter. It does all resolution no probs, including 720p,1080i and 1080p (which tx100 does do smoothly through dvi). My denon upscaling dvd player works fine too. In fact the tx100 looks totally awsome with PS3 games and Blu-ray.
Maybe your dvi lead is the wrong type (i think there are 2 types) or perhaps you could test with a differrent piece of DVI kit in case it's your pioneer causing probs? Hope this helps.
Jan 14, 2008 | Hitachi PJTX100 Multimedia Projector
DVI connection
on your projector first, set it on auto search, power on the DVD player. Check the cable or replace the cable.
Nov 18, 2007 | InFocus ScreenPlay 4805 Multimedia...
157 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
