Question about Magic Chef Refrigerators
New magic chief freezer/fridge, and reset for compressor keeps tripping. Lights on but nobodys home. It's the small 10 c/ft model.
  • 828 Answers
Sounds like the compressor has gone bad. The reset you are speaking of is and overload protector. If it is still with-in the warranty, contact the dealer from which it was purchased to have it serviced. If it is out of warranty consider it may be time for a new one.
Posted on Jul 03, 2008
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Our fridge compressor won't run after a power outage, can it be reset?
compressors use a small start / run capacitor to start the compressor
modern fridges do not like spikes from power outages and many power boards and electronic components fail because of this and I am inclined top use a surge protector before the fridge cord plug
I went google and typed in --fault code 88-88 for samsung fridge model rf26aewp and the first site up is error codes /messages/ blinking
the site is support-us.samsung>popup>iframe
there is a detailed answer there with a list of fault codes as well and what they indicate
there are other sites that also refer to the fault that you have
Dec 15, 2015 | Samsung RF267AEWP - 26 cu. ft. French Door...
I have a small magic chef freezer that opens from the top. I has about 3 or 4 cu. ft. of freezer space. Lately a buzzer has been going off every 15 or 20 minutes. It buzzes for about 5-10 seconds and then...
With the time as the compressor gets old the buzzing will increased, its not a bid deal, just set the thermostat to 1 during the winter, saves you energy and give the compressor more time to rest.
Sep 28, 2011 | Magic Chef Chest Freezer MCCF5WBX
Kenmore Elite Trio Refrigerator not cooling
No, it is not a failed condenser. You need to see if the compressor is running though. When it runs you shaould have a fan in the freezer running, a fan underneath the fridge running, and the compressor should be running. I would be willing to bet that either the compressor is bad, or the start relay on the compressor.
Sep 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Amana fridge/freezer compressor problem
Unplug unit.
It's not possible to tell which without replacing the starting system. Hard start kit would be fine. RCO410 is common. If it starts the unit the next check would be an ampmeter clamped onto one of the power leads. The ampmeter for refrigerators of that age may read around 2-5 amps when running. If it's much higher than 5 Amps after it's running be prepared to replace the compressor. Maybe it won't quit today...but it won't last with high amperage. If it doesn't start with this kit you need compressor.
Sep 08, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Defrost timer might not be working
The timer is located behind the fridge , down by the compressor .
Aug 23, 2009 | Magic Chef CTB1821AR Top Freezer...
Magic Chief compact fridge motor gets hot but does not cool
Look In the rear bottom where the wires plug into the compressor. There will be a plastic cover plate over the connecting wires. Remove it. Unplug the white wire. note the white wire was plugged into a small black box (3/4"x3/4") pull the black box out. It is connected by 2 prongs. If you open this up you will find a small metal disk that looks like a watch battery. pop it out and clean the contacts. put it all back together and it should work fine. I believe it is the thermostat and many times gets bad contacts and can even crack over time. The compressor will "click" on but the bad thermostat tells it "no"
Jan 06, 2009 | Magic Chef MCBR440 Compact Refrigerator
Fridge keeps tripping electricity
I assume by "earth leakage" you mean it is on a GFI circuit? Some older GFI outlets are sensitive to and do not work well with motors or other inductive loads like your refridgerator compressor. As for the compressor feeling hot, this is usually normal.
If this is a GFI outlet, try replacing it with new unit. If it is a GFI breaker, try replacing that.
Dec 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
FAN WORKS, BUT FRIDGE AND FREEZER NOT COOLING,COMPRESSOR KEEPS CLICKING ON AND OFF
sound like the start components are weak on the unit. you can get new start components or get a three n one control that repalces the starting components and all that you have to do is wire it up just like the diagram on the bag. or the lem could be low voltage gpoing to the refriger ator. The manufactures reccommend that you never run a refrigerator on a extenstion cord of any kind. It is also a good Idea to take the refrigerator electrical outlet off of any type of GFI receptical of any kind. you don't want to come home to a defrosted mess just because the outlet decided at that Tibme to trip.
Dec 27, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
292 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
