Question about Acer Aspire 5600 Series 5630-6951 Laptop
Acer laptop keyboard problem
My keys are stuck and i cant get them back to lower and capitals. I'm not sure which keys to press to unlock the keyboard to make it type normal again?
  • 22 Answers
Press the "CapsLock" key to return to normal.
Posted on Sep 12, 2009
What is wrong with my laptop? It is as if the shift key is stuck
Go into device manager in windows and delete it and reboot. If it comes back when it detects the keyboard and it works then it was a driver, if it does detect it or it wont work correctly then it is a bad keyboard. You can also try a plug in keyboard to see how it behaves, ps keyboards are not that expensive.
Oct 11, 2015 | Toshiba Computers & Internet
Third function keyboard
The purpose of a laptop's function key is to activate the secondary function of any dual-purpose key.
The function key can accidentally be locked into place if you hit the wrong combination of keys so that all of the keys only perform their secondary function.
The exact process for unlocking the function key will vary depending on the make and model of your laptop and whether you have recently used an external keyboard.
Check the manual that came with your laptop and locate the section on the function of each keyboard key.
Open a Web browser and navigate to the support section of the laptop manufacturer's website if you do not have the manual that originally came with your laptop.
Use the drop-down menus on the support page to choose the specific product line and then model of your laptop.
Click on the "Product Support" link and then navigate to the "Manuals" section of the page. Click on the link to open a PDF version of the manual for your laptop.
Browse down to the section about the functions of the keyboard keys.
Find the sequence of keys you need to press to unlock the function key on your laptop.
Press and hold the function key on the keyboard and then press the other keys required to unlock it.
Try using the most standard keyboard combinations if you don't have the manual or it does not give any information about the function key.
Press the function key and then the shift key and see if it successfully unlocks the function key. Attempt using the other standard keys in conjunction with the function key, such as the "F11," "F12" and "Ctrl" keys.
5
Plug a USB keyboard into the USB port on your laptop if you have recently used an external keyboard with the laptop.
Check the light above the "Numlock" key on the external keyboard and see if it is turned on. Press the key and make sure the light is turned off and then remove the keyboard to unlock the function key.
http://us.acer.com/ac/en/US/content/support
Acer Support
Nov 26, 2013 | Acer Computers & Internet
Letters are all capital caps lock is off
you may have the Shift lock activated. keep pressing the shift key numerous times at a fast rate to bring p a prompt to deactivate it.
Failing that, you may have a stuck caps lock button (even if the led is off...yes it can still be stuck) so replace it
Oct 20, 2011 | Acer NSK8458AN Keyboard
KEYBOARD ONLY PRINTS CAPITAL LETTERS . HOW DO I RETURN TO LOWER CASE LETTERS ?
Try pressing the Caps Lock key, (the Caps Lock LED will then turn off) this will return the letters to lower case.
Jul 27, 2011 | Computers & Internet
I can`t get any upper case functions to work on hp 2011 keyboard what key do i press
1.Make sure the "Caps Lock" key is not on. Though this will be obvious to most people, if your keyboard is typing in only upper-case letters it can't hurt to check. Look at the "Caps Lock" indicator light on the top right corner of your HP keyboard. If the light is on, strike the "Caps Lock" key on the left side of your keyboard. This will turn the "Caps Lock" off, allowing you to type in lower case letters again.
2.Make sure the "SHIFT" keys on your HP keyboard are not stuck. Dust and dirt can build up on a keyboard over time, which can cause certain keys to stick. If either of your keyboard's "SHIFT" keys get stuck, your computer will type in only capital letters. Use a toothpick or cotton swab to remove the gunk from the key, which should help it return to its normal position.
3.Unplug your HP keyboard and then plug it back it. This will remove the device from your operating system and then automatically add it back in. This can have the same effect, essentially, as restarting your computer. If your keyboard was typing in capital letters due to an error being stored in your operating system's memory, that error will now be cleared and the HP keyboard will function as normal again.
4.Update your HP keyboard driver. Click "Start" and then right click on "Computer." Click "Properties" and then "Device Manager." Right click on the listing for your keyboard and then click "Update Driver." This will update the computer software that is associated with your HP keyboard. If your keyboard was typing in all capital letters as a result of an error with this driver, the error will now be fixed and you can use your keyboard normally again
Mar 01, 2011 | HP D8597A Keyboard
I HAVE A LOCK WITH A NUMBER 1 ON AND CANNOT USE MY LOWER CASE KEYS> HOW DO I UNLOCK WHATEVER I HAVE LOCKED?
try pressing the caps lock key once, if still your caps lock key does not respond then possibly the key is stuck, try backing up your data first do a system restore when you think you can still use lower case on your keyboard then check if there will be changes, if still no changes occur, a long shot would be re imaging windows back to defaults again make sure you back up data first the then try again once windows is reinstalled if no changes then your keyboard works but the caps lock key is busted ^_^ I do not see any other option for the caps lock key to be troublshooted. ^_^
Jun 04, 2010 | Acer Computers & Internet
Acer Notebook Keyboard is locked
Just hold down Fn then press F7 or F8 keys to unlock keyboard.
Good luck.
Aug 14, 2009 | Acer Aspire 4315 Notebook
Cannot use letters of my laptop unless use fn key but not capital
You need to press the NumLock key to get the keyboard to get back to alphanumeric - it has a symbol of a lock with a number 1 on it. A LED should also go out/icon in your tool tray should disappear as well.
Jul 05, 2009 | Acer NSK8458AN Keyboard
Keyboard stuck in upper case
Is the caps lock light illuminated? If so, you might have to hold shift and hit caps lock to turn off the caps lock. This is an option for old typists who came from manual typewriters that you might have turned on by mistake.
Mar 05, 2008 | Acer NSK8458AN Keyboard
Acer Aspire 5600 Series 5630-6951 Laptop Logo
141 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
