Question about Whirlpool 24 in. ADG6340 Built-in Dishwasher
Whirlpool dishwasher ADG6340 fault code
Last time used washed 4 flashes on button
please help
  • Anonymous Feb 03, 2009
    on 40 degrees ie short wash it seems to go through cycle but then starts flashing 4 times and grinds to a halt. I hold it in and it seems to empty. If I use a 50 or 70 degree wash the water doesn't even heat up - it's a very short cycle - nothing is really clean and we still get the 4 flashes. Any ideas?
  • 641 Answers
SOURCE: My dishwasher has a fault
I am not familiar with your dishwasher, but could you explain the problem you have (does it stuck, on which stage etc..)and maybe this information will allow us to help you.
Posted on Jun 25, 2006
SOURCE: Whirlpool ADP5966 fault code F8
just choose another prog setting and hold the start button in for a few seconds.
Posted on Sep 30, 2007
  • 49 Answers
SOURCE: whirlpool dishwasher adp550
f4 is a drain error, machine is still sesing water has not pumped out after 4 minutes of draining
1st check and see if water is still in bottom of machine if so check for blockeges under sink where drain hose cnnects to drain pipe.
if water has drained out you may have an water sensor fault or worst case an electronic control board fault
to reset machine hold the start button in for at least 3 seconds and it should do a drain and stop
Posted on Feb 19, 2008
SOURCE: Whirlpool ADG 6340 Dishwasher
fault 7 is a fill fault . If you take the left side panel off you will see a white plastic tank . The sensor in the tank has failed
Posted on Jun 23, 2008
SOURCE: Whirlpool dishwasher Fault codes
Fault code related to Flow meter. Cleaned the connections and reconnected.It worked fine for 2 weeks and failed again.Replaced the water chamber which contains the flow meter and the issue is resolved. The water chamber cost me 87euro including postage from Quinnspares in Co.Derry Ireland.
Posted on Jan 28, 2009
Error code 4 philips whirlpool dishwasher
Hi Kevin , it seems like you have debris clogging your sump motor . Remove the lower spray arm and remove the five T15 screws then remove the motor cover . Next with a wet vac clean all debris in motor . Make sure theres nothing under the float switch .
Dec 06, 2013 | Whirlpool 24 in. ADG6340 Built-in...
My Whirlpool GU2400XTP83 stopped during the wash cycle and there is a blinking light above the "light" cycle button. I can not reset the dishwasher, stop or start it.
To reset the dishwasher push in this order the,
the control will be reset...but more importantly how many times ina row does the light will indicate what error code its displaying??
example if it flashes 4 times then a pause then flashes 4 times again its displaying the error code#4
7 flashes then pause then 7 flashes its displaying the error code#7 ect ect
Sep 05, 2011 | Whirlpool 24 in. GU3200XTP Built-in...
The clean light is flashing on a whirlpool dishwasher-model du1048. The manuel says the dishwasher has malfunctioned and to check the heater circuit. How do I do that?
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Feb 17, 2011 | Whirlpool 24 in. DU1055XTP Built-in...
ADG6340 not washing well. Now tablet doesn't dissolve sometimes.
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
May 14, 2010 | Whirlpool 24 in. ADG6340 Built-in...
Fault light flashing,
Is it please possible for you to add additional comments in your query about dishwasher problem
1. make and model number of dishwasher
2. are there any fault codes or lights showing up - which ones
3. at what cycle does the operation stop - eg still washing and there is water in dishwasher - is it warm/ cold, rinse is starting (can hear the pump) but stops halfway, rinse is complete but does not dry..
4. how old is the unit
clarification on above will help understand the problem better.
Jan 03, 2010 | Whirlpool 24 in. ADG7540 Built-in...
Front light flashing
Solution to the problem:
Discovered that the dishwasher was covered by our household insurance policy. Phoned and arranged for it to be repaired or replaced (no charge). Engineer coming on Friday.
Jun 10, 2009 | Whirlpool 24 in. ADG6340 Built-in...
Kenmore dishwasher will not start
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers.
The problem is usually attributed to water supply temperatures being too low when filling.
Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models).
There is a reset sequence that you can try to clear the fault.
Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times.
The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button.
This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher.
This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line).
The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits.
If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is.
The flashing light will be a series of flashes, followed by a pause.
If you indeed have a component problem, it will depend on the number of flashing lights in the sequence.
Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 27, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Whirlpool dishwasher adp550
Feb 19, 2008 | Dishwashers
what does the green light say hit cancel it may be a reminder that the dishes are clean if you give me the complete model i can look up the tech sheet a stuck button can also flash rapidly cancel will clear it
Jan 09, 2008 | Whirlpool 24 in. ADG6340 Built-in...
What flashing are you referring to ? This could very well be a fault code.
Whirlpool 24 in. ADG6340 Built-in Dishwasher Logo
469 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
