Question about Lenovo R61 T7300 Notebook
Lenovo R61 won't get to login
Hi there.
I went to make dinner and came back to my Lenovo R61 and it was completely out of battery power. I plugged the cable in and it ran through the start of the Windows XP setup. The hard drive light flashes like it is starting to work and keeps going for several minutes. It then continues to blink but nothing appears on the screen.
    Genius:
  • 1,019 Answers
I,d suggest To charge the battery Fully.
Then power up the laptop, with A/C Adaptor connected.
Also check your models user manual, regarding the sleep/hibernate mode. the laptop may have gone into one of these modes. Usually a ( zzz ) Icon Key or Similar.
Also when booting press the LCD/VGA Button.
If all else fails, try to see if your laptop, has a hard-reset button or switch. ** Sometimes this can be a small hole ** On the underside of laptop. *** Only use with laptop Powered Off ***
Mike @ Compurepair.
Posted on Jul 03, 2008
How to reset lenovo thinkpad r61?
Please follow the steps below to reset the lenovo to factory settings
Note: All your data will be lost. So keep that in mind.
So take the backup of your data first in a separate HDD or flash drive.
1. Switch off the Computer
2. Press the power button and then immediately start tapping f11 key on the top of your keyboard.
3. You will hear a beep sound and then stop pressing it.
4. You will get the screen says windows is loading files. Wait untill it finishes.
5. Select the default language which is US and Click on next .
6. Enter your login credentials (username and password) if you use to login to the windows.
7. Then you will get the system Recovery Options screen where you need to select the last option "Lenovo Product Recovery"
8. Again preferred language will be English US and hit Next.
9. Accept the terms and conditions and hit next and then hit Yes on the warning.
10. Then it will start resetting the Lenovo Think pad to the factory default with no previous data. Same as when you purchased it.
If you have any query you can ask before restoring the Computer.
Hope this helps you. Reply if that fixes your issue.
Sukhiii
May 07, 2014 | Lenovo ThinkPad R61 Notebook
My lenovo R61 laptop shutdown instantly and on the laptop after trying many times of startup button
Are you sure your battery is charging? Maybe your battery is completely dead.
Feb 26, 2012 | Computers & Internet
It lenovo R61 it has a password whenever you power on the notebook it shows you a lock, i av tried so many ways but i aint lucky
try opening the bottom compartment doors. look for a the cmos battery. If you take the cmos battery out(looks like a watch battery), short out the battery terminals for 60 seconds, this will likely dump any cmos locks/passwords, and default them. Worth a try . Please disconnect all power cords and take the main battery out first. Cheers
Aug 26, 2010 | Lenovo R61 T7300 Notebook
When i am starting my lenovo R61 which has vista installed, it is not starting at all. The AC power light and the battery lights get on along with wireless light. The other two lights will on and off after...
Drain Flee power
Steps
Disconnect AC adapter,
Remove Battery
Press and hold power button for 30 seconds.
Reconnect adapter and battery
Start your pc and go to safe mode and check power settings.
Depending on your OS check event log /windows error log to find out what is causing the problem. And disable the service or reinstall driver needed.
Aug 10, 2010 | Lenovo ThinkPad R61 Notebook
The battery cannot be charged
hi ashwani879, try these steps:
turn off the pc remove cables on your laptop remove the battery Press and hold the power button for 5 seconds reinsert the cables and battery Turn on the pc plug the adapter and check if the battery is charging. If not, please call this number 1-800-426-7378 for possible replacement of the battery..
May 20, 2010 | Lenovo R61 T7300 Notebook
Lenovo R61 Dead
The power supply in most computers has a fuse, either internal or external, that can blow without you noticing. Basically, you've been on battery operation this whole time, and the battery's finally gone dead.
It will be necessary to open the case and examine the power supply section. It may be possible to replace the fuse yourself, but any operation of this nature that involves opening the case will void any warranty you may have.
Sep 06, 2009 | Lenovo R61 T7300 Notebook
I tried to switch on my laptop and it started booting and suddenly went off.From then on its not even booting.Nor does it show the green light which comes on, when you plug it to a power source. Its...
When you plug in the adapter into the laptop a LED lights up to indicate that it is connected to the mains supply and is charging.
A faulty adapter or the connector is not making proper electrical contact, this causes the LED not to illuminate. Wriggle the connector plug to see if the charge light comes on, if it does then the loose connector needs repairing.
Check the adapter with a multi-meter, the voltage reading should be a slightly higher than the voltage that is printed on the label on the adapter. If the voltage is more than 10% below the nominated voltage then replace the adapter it is faulty.
May 09, 2009 | Lenovo R61 T7300 Notebook
LENOVO R61 COMPLETE DRIVERS FOR FREE INSTALL
try download at this site www.driverguide.com hope it helped.send me a message for more concerns.
May 04, 2009 | Lenovo R61 T7300 Notebook
Lenovo Thinkpad R61 7732 Hissing Sound
hi
try running a test on youe battery frim control panel
or
try and boot the system in safemode and check if it works there if Yes then its an OS issue if no the boot in bios and reset the setting to default and try agian
Jun 16, 2008 | Computers & Internet
Open Questions:
Lenovo R61 T7300 Notebook Logo
161 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
