Question about Dell E153FP 15" LCD Monitor
HELLO hi am Ernest from Ghana and have something to tell you guys, i really need your help concerning the repairs of flat screen monitors and fixing certain serious problems with computers, eg, if the flat screen does not powers at all, if the screen does not display any thing while the machine will be working alright, i get to know this by giving it to a different external monitor, and when the cpu is working alright but does not displays on the screen, i have wash the board and still the same so tell me something please, thank you , mail me to
  • 558 Answers
You have a problem with blown (bad) capacitors on the pwer board google blow capacitor image and you will find them inside the flat panel soldering will be required.
Posted on Dec 09, 2008
The sound is great, but the picture has gone to gray with horizontal white lines across the screen. It is 20 years old, and probably not worth fixing, but i will ask anyway, just in case it is a simple...
Hello Sat, hi, its a failure of the horizontal output transistor responsible for high voltage. This transistor is needed to be replaced. you need a TV tech guy to have this fixed. have it checked first, the trouble is common to CRT type TV really easy to fix. for a tech guy.
Dec 07, 2010 | RCA Televison & Video
I have a Cornes 1503T flat screen monitor that is white on the the screen with mutli color vertical lines on the screen /monitor, it is 8 years old, Is it dead or can it be repaired It is used in an...
The picture board on your monitor is bad, since the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care
Jul 01, 2010 | Cornea CT 1501 (White) 15 in. Flat Panel...
The screen boots up with the commands and then it
The picture board on your monitor is faulty or bad, since it goes black after booting, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself. in order not to complicate issues.
Take care.
Apr 21, 2010 | Gateway 19" Widescreen Flat Panel TFT LCD...
Have a samsung syncmaster 920NW flat monitor. though the LED is solid green the screen is black. suspecting blown capacitors. how to i remove the covers to inspect he capacitors & replace. thank you in...
Hi, something you might want to try is holding the monitor at an angle and looking at it in moderate to bright light (with the comptuer running). If you see an image on the screen, but it's extremely dark, it's probably the back-light that's gone out. The back-light goes out often on LCD monitors, and can be replaced or fixed by someone with the time and know-how. Most of these modern monitors don't use traditional capacitors (air or fiber dialectric), but rather solid state capacitors that don't really "blow" like the old ones used to. If one of these new capacitors did blow, you wouldn't be able to see it like the old style ones (split top). If the green light comes on, then it's probably not the pwoer supply. If the light stays green and doesn't go amber, then it's probably not the video input section. My money's on the back-light. Hope this helps!
Mar 04, 2010 | Samsung SyncMaster 940MW 19" LCD Monitor
Screen comes on then goes out in 5 seconds. The backlight goes dark but the seen is working, just can't see it. The backlight is out...
mark587, Did you shine a very bright flashlight 1" from the screen to try and see the WIN-desktop ?? Even though the screen appears BLACK. Your words above said: JUST CAN'T SEE IT Did you really NOT see anything? Have you seen any of the longer video clips of "LCD Monitor Disassembly" on YOUTUBE? Some BLACK screen "symptom" lcd displays can be repaired for less than $10 in parts. Capacitors! Also check videos on lcd repair. Then get back here to fixya and I or any of the guys can help you decide what to do with your display whoose screen is now dark and lifeless. After doing the YOUTUBE thing you may even tell us what you will do!!! Hope this was helpful. Yes we do want to hear back from you. please rate this response on fixya. I'm louie12fix on fixya or lmistyrel @ Bye for now.
Oct 07, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
Monitor fades and turns blue
this sounds like a transistor issue concerning the ccfl lamps the power transistors are deteriorating and they will eventually go bad you can have them replaced and that should fix the issue. otherwise I would say have the capacitors that feed the ccfl's may be getting old and need replacement as well, its not something the average customer will want to do but if you have a service center that does electronic repair then that would be bst.
Hope this helps
Jan 30, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
MAG innovision 900w 19" LCD flat panel
Well, you need replaced a new backlight inverter. if you got a AC Adapter with this monitor. The backlight inverter it to your left a small rectangle piece. Monitor without AC Adapter, the inverter it to your right... it's a large piece of power supply w/ buit-in inverter. OK! Wanna repaired it yourself...
First of all, inspecting the inverter closely...if you're lucky you can see a over-heated capicators with a bulged caps on top. Those caps need to be replaced. if you're not sure....just replaced all the caps.
Good lucks! Have a nice day!
Oct 08, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Contrast window keeps on popping in the monitor
Hi, it might be that a sensor in the monitor is sensing change in ambient light and therefore reacts by auto adjusting the contrast. when you push auto, it will do just that and auto react. Why not try manual and set it to your desired setting and let it run that way. But then again, of course it is possible that something is really wrong with the monitor and you would need a qualified service personnel to diagnose/repair it. Hope this be of some help and pls post again how things turn up. Kind regards.
May 18, 2007 | AOC LM520 (Gray, Silver) 15 in. Flat Panel...
How to fix flat screen monitor
If this is Windows XP you problem may be solved by holding the CTL and Alt keys down pressing the up arrow key. Let us know if this worked for you and please don't forget to rate this posting.
Mar 06, 2007 | Dell E153FP 15" LCD Monitor
Dell E153FP 15" LCD Monitor Logo
67 people viewed this question
Alun Cox
