The best or more professional way to run the cables is to drill a hole thru the firewall. You need to use wire ties on the cables and route the cables along the factory wiring harness. Try to route to the shortest distance and use a rubber grommet where you have the hole drilled in the firewall. The grommet will keep the cable from getting damaged by the sharp edges of the hole that you drilled. Also the largest possible diameter cable is better because you will get more amperage to the power inverter. Hope this helps :)
