I have a proseries pv2400i dvd R video recorder and I cannot work out how to record a program from the TV or Sky. I can play a did. Help.
  • 21 Answers
SOURCE: Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Posted on Jan 27, 2009
Mike258
  • 1498 Answers
SOURCE: Recently, i;ve been trying to record tv programs
Hi Leah,
Good description and good job in narrowing down the problem. The lens is the remaining common denominator.
You need to get a CD/DVD lens cleaner. It should have a disk and a bottle of cleaning solution. They are available in the electronics dept of most chain stores.
A couple drops of cleaning solution on the feathery cleaning element attached to the disk, insert the disk into the machine and hit play. Takes just a couple seconds.
Best regards
Mike
Posted on Aug 17, 2009
  • 556 Answers
SOURCE: What DVD should I use to record TV programs. I
Most dvd recorders will only accept dvd+r's or dvd-r's, if yours will not accept dvd+r's then try dvd-r's.
Posted on Sep 02, 2009
57 varieties
  • 1653 Answers
SOURCE: dvd npt recording
This usually means that at best the DVD lens needs cleaning, so use a DVD cleaning disc and / or air duster to clean it or that there is a serious error with the DVD recorder itself an it will need replacing. Unfortunately this series of Tosh machines have had many issues with the DVD reliability.
Posted on Sep 11, 2009
SOURCE: Mikomi DS-8668 dvd recorder i
need to finalise disk when finished recording to be able to play on another machine
Posted on Mar 21, 2011
I have a toshiba rdxv60kb dvd recorder,,and can;t tune the programes into my sky box.
I have a toshiba Hdd & DVD / Video Recorder However I can not get it to work with my Sky setr up If I set thimer recording it does not work when I turn it on it will only work pn channels that are not from sky it will not instant record nor will it record programmes prerecoreded of sky HDD it will record everthing other than what I want.
My E-Mail Addres Is fj.gadkey_1@sky .com
My Home hone is uk 01527 545284
Nov 08, 2010 | Toshiba DVR660 DVD Recorder/VCR
Have DVD recorder (DMR-EZ27EB)How can I record from a satellite program when the DVD recorder is connected to the AV 2 input and the satellite via SKY box is connected to the AV1 input
Connect the sky to the tv using a scart from the one marked tv on the sky box.Connect a scart from the one marked vcr on the sky box to av2 on the dvd.You then select av2 as your record channel on the dvd.
Dec 08, 2009 | Panasonic DMR-E55 DVD Recorder
Connecting DVD recorder to TV and SKY box
A simple solution - aerial input socket error - wrong socket!!
There are too many choices on the DVD record/play machine. When the plug came out - it was pushed back into the wrong socket.
Nov 30, 2009 | Sony RDR-GX300 DVD Recorder
Recording from sky planner to dvd
Yep all you will need is a DVD recorder Philips do a good low cost version DVDR 3380 and a Philips DVD+RW ( this is the type that you don't need to finalize before you can use it in your PC)
All you have to do is make a connectiion to the video out of the Sky box using the suitable connection normally a SCART lead in to the EXT1 or EXT2 of your DVD recorder.
Play the Sky program in your planner and hit record don't forget to select the time you require 1 (HQ) 2,4 or 6 (SLP) hours. It will take as long as the program take to run to record it.
The best way to get the DVD-Video into your PC is to use the excellent TMPGEnc v4.0 Xpress from Pegasys use the Souce Video Wizard.
Then select the DVD-VR button this will read in the DVD content and then allow you to edit it and re-encode to almost any format.
If you select over 4 hours or recording most DVD standalone recorders will revert to Half D1 this equates to 360x576 instead of the Full D1 resolution of 720x576 (standard PAL for DVD-Video) you will need to use this filter to convert the half to full download it here Half D1 to Full D1
LOL
Sep 28, 2009 | Compaq Presario 5000 PC Desktop
Cannot tune -in my panasonic vcr. it plays tapes but will not record. I have wired together the tv, sky box and vcr in what seems the obvious way (and every alternative) but no joy so far. can you help?
The main aerial goes into the vcr,a fly lead then comes out of the vcr into the tv,a scart lead from av1 on the vcr into the tv.If you want to record from sky and the vcr has two scart sockets then connect a scart lead from the sky into av2 on the vcr,when you record from sky you select av2 on the vcr as your record channel
Sep 24, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
I AM LOOKIN FOR A SETTING UP DIAGRAM SO THAT I CAN RECORD FROM SKY TV, CAN U HELP?
your best way is to use scart cables 1 from sky to video/dvd recorder other from sky to tv your sky box should have 2 scart sockets
May 13, 2009 | Lite On Lite-On LVW-5045 DVD Recorder with...
I have a philips dvdr70
From the Sky box, plug one SCART lead to your recorder and plug another to your TV. Then plug a SCART from the TV to the recorder.
You can then select the SCART connector for the sky box to record programs.
This will work after the digital switchover. The switchover is only for 'normal' tv signals from your tv aerial
Jan 12, 2009 | Philips DVDR70 DVD Recorder
Sky+ DVD Recorder Tuning
You need to connect up the Sky+ to your recorder via scart. This will eliminate poor picture quality. The Sky box will be on ext1 on your recorder or something like that
Oct 12, 2008 | Televison & Video
How to connect DVR 1600 to LCD HD TV or ATT uverse recorder
has to be scarts, your reciver (sky, cable ect ect) to your dvd recorder, from that to the tv, all scarts, might help, regards mark
Feb 01, 2008 | Cyberhome DVR 1600 DVD Recorder
Souud delay on tv /amp
Instead of connecting each device (sky&dvd rec.) to the TV separately, I would simply hook up the sky to dvd recorder (connect the sky output and dvd recorder input), and then connect the dvd recorder output (must be called "play out") to one of the available recorder inputs (which could be a dvr, an empty tape input, etc)of your amp. However, you'll still have to establish a feedback between your dvd recorder and your amp. Therefore, if the dvd rec. supports it, you'll have to hook up the rec.out, which is on your amp.,to rec.in on your dvd recorder. After all these audio connections, you will only need to make a video connection among the sky, dvd rec., and tv. Get a video cable to hook up the sky video output to your dvd recorder's video input, then do the same thing between the dvd recorder's tv output and tv.
Apr 12, 2007 | Cambridge Audio Azur 540A Amplifier
Televison & Video Logo
120 people viewed this question
Top Televison & Video Experts
Electro Med Services...
