Black sludge deposits in water inlet of washing machine, and around inlet to toilet pan
    Novelist:
  • 177 Answers
What is your water like in your area? I know of one community not far from here and they have a Magnisum problem and their is black stains on the inlet area of the washer.
Posted on Jul 03, 2008
How do I do a Ohms test on water inlet valve for a maytag wc284 dish washer
I have a Maytag WC284 in one of my rentals. It recently would overflow occasionally. This was apparently due to the inlet valve (or fill valve) not shutting off completely. We replaced it with PartStore.com's suggested substitute (154637401). After that it would not fill the bottom of the dishwasher sufficiently. I am betting that the substitute valve is defective or some sludge or mineral deposit has plugged its inlet.
May 28, 2012 | Maytag Dishwashers
My WMS38 Hotpoint washing machine has the wash, rinse and spin and final spin lights on but nothing happens when the start button is pressed
Assuming tap water is turned on. If there is no water intake, the machine will not start. Check for the sound of water pouring in the machine. Check the water inlet filter, if it is jammed with foreign materials such as rust deposits, small stones, soil etc. Then check for the proper functioning of inlet water solenoid valve. Sometimes the valve gets stuck.
Nov 25, 2011 | Hotpoint Washing Machines
The machine is indicating an IE fault
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle. There are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly wm_inlet_filter_removal(1).jpg
Mar 02, 2011 | LG WD-1280FHD Front Load Washer
Slow filling with cold water
Hiya,
this can be a water presure issue with your mains or maybe the inlet tap to your machine is not open fully i would surgest checking the connection tap is open fully & allowing the maximum amount of water through to your machine.. if you sink taps run slow then this would be a sign of your water mains presure needing attention.. presure can also be reduced by using water around the house at the same time as the machine is on for example running a bath, dishwasher, flushing the toilet etc.
Hope this helps
Apr 23, 2010 | Zanussi FJS1225W Front Load Washer
What is the black deposit on the liner at door
This can be sludge build up more so on an older machine clean with diluted bleach solution ,,,dont leave on rubber long time as it may perish if weak to start with.
Apr 03, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
I just did a load of whites and everything has black spots on it now.
do you do many boil washes ? if not sounds as though two things. (1) could be that you need too do a 90/95 degree wash, no pr wash, on max spin speed this will cost about 87p with 200 grams of bicarbonate of soda, straight into the drum (you find this in the cooking section of the super market) it is the stuff put into cakes.this will de sludge the machine and melt all old soap powder away that is deposited around the outter drum or carbaron as it is known or (2) worst case is, that that is greese from the bearings and may need replacing hope this helps this could cost about £150 if not insured
Jan 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
When flushed, not enough water flow to empty sides and waste
make sure water level is sat at factory settings. there should be a black line that reads WATER LEVEL. If this is not the problem. then you have calci buildup. get a gal. of muratic acid,plunge all water out of toilet bowl. then dump in at least 1/2 gal. let set over nite. with water turned off. get up turn on water then flush. You mite have to do it twrice. hope this helps you.... duane.
Sep 28, 2009 | Kohler Barrington Pressure Lite Elongated...
Cold water continues to flow into the wash drum after the wash cycle is completed
Hello Friend, Your solution is simple. You need to replace the water inlet valve. The cold water inlet on your valve is blocked with hard water deposits or dirt and debri from water lines, causing it to not close completely. This condition is allowing water to enter through the valve when it's supposed to be closed. Replacement is easy. Just replace water inlet valve and your problem will be solved. Happy to help, Tim.
Jun 22, 2009 | Washing Machines
TOILET WILL NOT FLUSH FULLY
pour some CLR into an empty tank - allow one flush and let it sit for a day then fill tank and flush again. hard mineral deposits are clogging the holes.
Mar 11, 2008 | Tecnik TKL9260 Front Load Washer
Washing Machines Logo
138 people viewed this question
Top Washing Machines Experts
