Try updating the facebook software for mobile or try downloading older versions. If it doesn't work, try downloading the java software. ( java always works)
hi you can get the unfreeze codes to unfreeze your samsung j700 mobile from this site mobileunlocksolutions .if you need to unlock your mobile from the network then you can get the codes from the above site which i mentioned here and the instruction about how to use the codes in your mobile from this site mobileunlockguide here they provide you the free guide about how to use the codes in your mobile.
My dear: Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator Enter The Puk code and Yes Enter The pin code and Yes So Puk code Open and Problem will Quickly Solved
It is NOT officially possible to install
java games on all Samsung handsets (ex smartphones) via USB or
Bluetooth. The only Method is using OTA/GPRS via a download server. Go
to http://www.waphq.net,
Click Browse, Select the .jar file, Click Upload (note the ID), Go to
the provided WAP URL on your phone's browser Enter the ID and select
download.
No, usually Samsung phones doesn't allow to install java through PC.
You need to install it through Mobile Net (WAP)
And for samsung phone's java apps i always prefer http://www.wap.getjar.com
First select your Phone, then the type of app, and the most important thing is to check that specific app/game.. to be 100% tested under that phone
There will be a small tag with that app's discription, only try those with 100% Tested.
If I was helpful, kindly do Rate!
Every phone has a different maximum jar size limit and when you accour this rate you will get this error message. There is no solution to solve this problem. You can't install this jar to your phone.
