Question about ASUS P4SP-MX Motherboard
ASUS P4SP-MX motherboard no POST and no beep without ram
My computer won't boot and won't display a post message on the monitor. when i took out the ram it won't beep. what could be the possible problem for this? could it be the ram, video card, cmos battery, mobo, or the processor itself? please help.
  • McAngel Jul 16, 2008
    ya i have the same problem.
    And i try, remove every hardware and install everything again but it doesn't work.
    When i boot the pc, the green led on the motherboard turns on and the fan starts, but i dont have any image or any beep from it, and it does start's the hard disk, disket drive and DVD/CD-ROM.
    I allready make a reset to the bios and repleace the cmos battery but still the same.
    In asus site there is no solutions to this kind of problems, there is anyone that can help me please!?!?!?!?!?
    Thanks
    ps: Sorry if there is any ortograph issues/error's but Im PT.
    ( Portuguese ) LOL
    President:
  • ASUS Master
  • 1,314 Answers
Try removing everything attached to it. The only thing should be the cpu and cpu fan. Turn it on. If it is the same, then it is your motherboard. If you do get the beeping, then start installing things one by one starting with the memory.
Posted on Jul 03, 2008
  • theboxingcan
    theboxingcan Oct 07, 2012
    Dang, totally should have tried that! I can't believe how many good suggestions I'm getting.
No Hard drive found
I am in agreement William.
What do the Radial Aluminum Electrolytic Capacitors look like?
http://capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=Lut7MX5Dd_A
http://support.asus.com/Download.aspx?SLanguage=en&m=P4SP-MX&p=1&os=
Post back in a Comment.
Regards,
joecoolvette
Mar 27, 2013 | ASUS P4SP-MX Motherboard
Asus motherboard p4sp-mx - long beep at start and nothing happens
Try cleaning the RAM as shown in the image below:
If you're still having same problem, replace the RAM. hope this helps
Sep 26, 2009 | ASUS P4SP-MX Motherboard
ASUS K8S-MX PC powers up but no display on monitor and no error codes. Hard drives spin and sounds as if it is in boot routine
OPEN UR CPU AND OUT UR RAM FROM MOTHERBOARD AND START UR PC WITHOUT RAM IS IT BEEP OR NOT IF IT BEEP THEN CLEAN UR RAM AND RE INSERT IN MOTHER BOARD AND THEN START UR PC IS IT OK
IF NOT THEN PICOUT BATERY CELL 2032 FROM MOTHER BOARD AND THEN START UR PC
IS IT BEEP WITHOUT RAM AND CELL IF YES THEN CLEAN UR RAM AND RE INSERT IN MOTHER BOARD AND THEN START UR PC
IF IT IS OK THEN CHANGE UR BATTERY WITH NEW ONE
IF UR PC BEEP WITHOUT RAM BUT NO DISPLAY WITH RAM THEN CHANGE UR RAM WITH NEW ONE.
Jul 01, 2009 | ASUS K8S-MX Motherboard
No boot and beeps
The exact fault code indicates RAM or a problem accessing the RAM.
Check that you are using recommended/Approved RAM as ASUS and ASROCK (the budget arm of ASUS) are notoriously fussy with RAM.
If it all checks out then your northbridge could be dead and it will probably be scrap.
Feb 21, 2009 | Asrock K7S8XE Motherboard
No display on my asus P4GE-MX mother board
Is there any beep from the motherboard? First thing that you need to check is the RAM. unplug the power cord and remove the RAM. Now, plug in the power cord and try switching the Comp and see if there is a any sound from Mobo. It should idealy warn you that there is no RAM with continous BEEP. If that happens, the Mobo is fine.... Grab a new RAM and try it out. The system should boot now. (If there was "No RAM warning beeps" when you switched on the system without RAM). There are many issues that may put down the Mobo but in most cases its the RAM that stops functioning... Try this and see if it helps. Please post your result here so that we can see if you need further assistance.
Feb 09, 2009 | ASUS P5PL2 Motherboard
Soundcard driver
For the soundriver of an SoundMAX as used in most Asus motherboards (including P4SP-MX) under Windows XP, pls try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 10, 2008 | ASUS P4SP-MX Motherboard
Pc is not booting and no display in monitor
First, try resetting the CMOS. If it is not working, replace the RAM. Could be a damaged RAM
Sep 11, 2008 | ASUS (P4BGV-MX) Motherboard
Monitor doesnt switch on
Can you try another monitor?
Since you did try another video card (AGP). I posted (In you're other post), you have to make a bios adjustment under Advanced menu. Once you're P4SP-MX bios is set to boot to the AGP or set to Enable. The bios will no longer try to load the on-board VGA card. I am not being picky about the statement I am going to make ( so don't be offended). Monitor's only receive signal. They do not send signal to PC, just receive. The odds of two video cards not working is high. You did mention you have not heard P.O.S.T (A single beep), which is a test of the motherboard. There could be a loose connection in you're PC. I would remove the memory first. Clean the contacts with alcohol on a cotton swab & blow out the memory slots with canned air (allow time to dry). Than firmely reseat the memory. I would than re-check all data & power connectors within the PC, making sure all are securley connected. With respect to the AGP card, I would do the same. Remove, clean & reseat. Most older AGP's require additional power. Some use a power cable that is also used to power a floppy drive & others use a 4 pin molex (see link),
http://pinouts.ru/connector/4_pin_Molex_power_connector.shtml.
When you are in the bios & within the Advanced menu you may also need to set the bios to read you're AGP card to the correct speed. (EX: 1x,2x,4x). Page 2-19 in you're manual. Once all these checks & cleaning have been completed, try again. Boot the PC and hopefully you will see display on you're monitor.
Post here. Let me know how thing go. Don't assume anything, check all.
Luck!
Mike
May 12, 2008 | ASUS P4SP-MX Motherboard
Won't boot
usually long beep is RAM
Apr 01, 2008 | ASUS P4S800-MX Motherboard
ASUS P4SP-MX Motherboard Logo
1,016 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
