Nokia 1650 Type: RM305 phone not ring then ringtone click restart problem. Hi bathtubs/whirlpool try to my advice just go to Setting and select to Factory Reset and default password 12345.its back to normal setting.
you want to goto settings in your mobile phone and select restore factory setting, in that type the security code 12345 and press ok .then the problem will be solved
HELLO MY FRIND THIS IS NORMAL PROUBLEM GOTO YOUR SETTING RESTORE FECTORY SETTING {CLICK OK} SECURITY CODE IS 12345 YOUR PROUBLEM WILL SOLVED 1000000% ITS MY GURRENTY IDRISH 911
Reset you phone to "Factory Default" by entering 12345 as the code. To do this, go to "settings" scroll down to the bottom and select "Factory Default" or "Factory Restore" and enter the code as mentioned above and press "Ok". This will restart your phone or if not will directly reset you phone to the factory default (the condition of the settings when you purchased). If this doesn't fix, you need to update the firmware, i would suggest you to get it done from the mobile repairing shop.
Good luck.
Thanks for using FixYa.
it is occur for your phone memory full. as a result your ram is too much slow. so the way is restore your phone. for it need your security code is 12345.
