Question about Coleman Campfire Grill
Broken pump plunger / colman 426e
Hi im trying to find a part for my colman stove ive broken the rubber on the pump as far as i know you have to replace the whole part as it seems a complete unit hope you can help i know you dont have the product name here but maybe you can help i just cant get the part anywhere thanks dave.
This site has all the parts you could ever want
Posted on Oct 14, 2008
Hotpoint WDD960 F13 code, water not pumping out.
hi if you wash small childrens clothes such as small socks they can get between the door seal and drum. they then get trapped in the rubber hose between the drum and pump which would create the problem you are would find this hose under the washer.
Jun 25, 2013 | Hotpoint Ultima WF860 Front Load Washer
Replacement starbucks french press plunger
Yes. I would like that plunger. Our top lid knob also came off. Right now, tho', it is the rubber on the plunger that is failing. Don't think we can fix that.
Dec 22, 2012 | Starbucks Coffee Makers & Espresso...
Hi I have purchased a 2nd hand Colman 431 stove . The instruction Manual wasn't with it. Looking for instructions Please. Hope you can help. Rob Tyler Toronto
I am not sure what to tell you, other than go to Colman's website for a manual. That will at least give you a parts list if you ever need it. But, these stoves are generally solid and reliable, with few things to know about.
What I do to operate:
  1. Set up stove: lid up and wings out, tank fully pumped (works best if no more than about 2/3 to 3/4 full) and installed with nozzle firmly into the socket above the right burner.
  2. Little lever on left of valve assembly--turn upward. Open valve a little bit to get fuel flowing to burner. Give it just a few seconds then light burner with match or lighter (watch your fingers!). It should light off pretty readily.
  3. Open valve a fair bit (anti-clockwise) and let it burn for up to a minute until the flame changes from yellow to mostly blue, and mostly around the burner and not up in the air. Turn little lever on left of valve downward.
  4. Re-pump tank to maintain pressure.
  5. Use valve knob to adjust flame intensity, and cook away.
  6. To use second burner, the key thing os to remember that it draws from the same valve, so when it is on the main burner goes down a bit.
  7. The knob for the 2nd (left) burner is a little flip-out on the left end of the stove. Open slightly, and light the burner. Only do this after the main (right) burner is burning blue.
  8. Use the main valve (on the tank) to adjut the total fuel flow, and the little handle for the left burner to adjust how much of the total flow goes to the left side. (You cannot burn the left without the right being on.)
  9. Pump as required to maintain pressure.
  10. The only real "part" that you might have to strip or replace is the "generator" which is the tube from the valve across the top of the right burner. The liquid fuel is vaporized in there, and is what needs to get warmed up when you start.
Feb 01, 2011 | Coleman 10' X 10' Sundome Tent 9160K101
Generator sizing
Yes, there is. the difference is in the feature that each
Sep 26, 2009 | Coleman Gas Grill Stove
I have lost all pressure in my coleman 502 camp stove. It worked well a few times but up camping it lost pressure after having worked well making coffee but after getting back to camp after a trip out...
If you didn't oil it it might do that. or you should check the position at witch you are holding the plunger. the instructions say that the plunger turns left and right but mine doesn't do that DON'T FORGET TO COVER THE HOLE IN THE PLUNGER THOUGH IT TOOK ME A WHILE TO FIGURE THAT OUT THE FIRST TIME
Aug 30, 2009 | Coleman Sport & Outdoor - Others
Broken hinge Colman cooler
I have three colman coolers with broken hinges. I would like to find some new hinges to replace them . model # 6270 6273
Oct 03, 2008 | Coleman 36qt Xtreme Cooler
No Power, DEAD
I would pull the stove back, first to check the plug, and then, the cord. If all is well, and breakers are good, you might need to call, then
Jun 17, 2008 | Whirlpool AKZ159IX Oven
Open Questions:
Coleman Campfire Grill Logo
214 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
