Question about Lexmark Optra T620 Laser Printer
929 service toner sensor error
It prints out 9 demo pages then error occurs. I've tried replacing the cartridge and the same thing would happen. I've also tried moving the encoder wheel on the cartidge a little bit and it moves likes it is suppose to. Also checked to make sure toner sensor was plugged in all the way. lexmark T620 929 service problem how to fix
  • reedm0289 Nov 03, 2008
    same thging
  • 412 Answers
Error: 929 Toner Sensor
A 929 Service Toner Sensor error indicates a problem with the toner sensor, the front harness cable, or the developer drive. It could also mean that the toner cartridge is defective.
The most likely cause of this error is the toner cartridge itself. This is especially true if it is a new cartridge and the error started after you installed it.
Take the cartridge out of the printer and locate the encoder wheel on the right-hand side of the cartridge. The encoder wheel can be found on the right side of the cartridge (usually over a bar code sticker). It is a thin, black, plastic wheel with small rectangular notches cut into it. This wheel will sometimes get stuck, but you can free it by turning it by hand.
Try moving the wheel forwards and backwards a little. If it does not turn correctly, you will receive a 929 Toner Sensor error on the printer when you try to use the cartridge it is attached to. Note: The encoder wheel moves only a little bit each way. It should not make a complete revolution. If it does, the wheel is probably broken.
Try to move it a little bit each way a couple of times to see if you can free it up. Caution! DO NOT force the wheel as you could break it.
If the wheel on the toner cartridge is stuck, try another new toner cartridge. ( If you do not have another new toner cartridge available, an old toner cartridge or another cartridge from a working printer of the same model will also suffice for this test.) Power the printer off and install the second toner cartridge. Then power the printer back on. If another toner cartridge clears up the 929 error, the printer is fine and the problem is with the toner cartridge. If the error does not clear, there may be a problem with the printer.
If you narrow down the problem to the toner cartridge, call the point of purchase and explain the situation to them. They may have a replacement policy. If they cannot help you, call our Technical Support Center and we will see what we can do to replace the cartridge that is causing the error. We will not be able to reimburse the price of the cartridge, but we can offer you an exchange. To do this, we may ask you to send in your cartridge first. Please note that we cannot offer an exchange on a refilled or refurbished cartridge. For this, you must go through the point of purchase.
Click here to order toner cartridges and other supplies for your printer.
If you receive this error with a second toner cartridge, you may want to check if the Front Harness Cable is plugged into the Toner Sensor. Do the following:
Turn off the printer and remove the toner cartridge.
Look inside the printer at the place where the cartridge goes (on the right). You should see the Toner Sensor. On the back of the sensor assembly, you should be able to see a white cable connector.
Push this white cable connector into the toner sensor assembly by pushing the connector towards the front of the printer.
If you continue to receive the 929 error, your printer will probably need service.
Source: Lexmark KnowledgeBase
Posted on Mar 09, 2009
Color Laser Printer Pink Tint
have you tried cleaning the charging wire and the transfer belt
Feb 17, 2014 | Ricoh Aficio SP C420DN Laser Printer
I have a HP LJ 4700 printer set up to a network. It will print black but not colour
1. Go to menu set as default.
2. Do color calibration.
3. Print PQ test pages, observe the colors, chk
4. Print demo page. chk
5. Print from different file/system..
Nov 28, 2012 | HP LaserJet 4700 Printer
How to fix error 929 toner service on an Optra T614 Lexmark Laser printer?
  • Take the cartridge out of the printer and locate the encoder wheel on the right-hand side of the cartridge. The encoder wheel can be found on the right side of the cartridge (usually over a bar code sticker). It is a thin, black, plastic wheel with small rectangular notches cut into it. This wheel will sometimes get stuck, but you can free it by turning it by hand.
  • Try moving the wheel forwards and backwards a little. If it does not turn correctly, you will receive a 929 Toner Sensor error on the printer when you try to use the cartridge it is attached to. Note: The encoder wheel moves only a little bit each way. It should not make a complete revolution. If it does, the wheel is probably broken.
  • Try to move it a little bit each way a couple of times to see if you can free it up. Caution! DO NOT force the wheel as you could break it.
  • If the wheel on the toner cartridge is stuck, try another new toner cartridge. ( If you do not have another new toner cartridge available, an old toner cartridge or another cartridge from a working printer of the same model will also suffice for this test.) Power the printer off and install the second toner cartridge. Then power the printer back on. If another toner cartridge clears up the 929 error, the printer is fine and the problem is with the toner cartridge. If the error does not clear, there may be a problem with the printer.
  • If you narrow down the problem to the toner cartridge, call the point of purchase and explain the situation to them. They may have a replacement policy. If they cannot help you, call our Technical Support Center and we will see what we can do to replace the cartridge that is causing the error. We will not be able to reimburse the price of the cartridge, but we can offer you an exchange. To do this, we may ask you to send in your cartridge first. Please note that we cannot offer an exchange on a refilled or refurbished cartridge. For this, you must go through the point of purchase.
If you need further assistance contact Lexmark Technical Support.
Aug 12, 2011 | Lexmark Optra T614 Laser Printer
What means "943.02 Service Black TMC Sensor"?
A 94x.xx TMC Error indicates that the printer has failed to detect the Toner Metering Cam for a specific cartridge. This error typically occurs when the cartridge or developer are misaligned or incorrectly seated
Please click on the link http://bit.ly/ozldpC to see instructions on how to go about the procedure.
For further assistance, please contact Lexmark Technical Support.
Feb 20, 2011 | Lexmark X543dn Laser Color All-In-One...
I have a lexmark T520, just replace the old cartridge because it was leaving ink marks down sides of paper, smudges. Replaced with the new cartridge and it makes a loud popping noise. Now it's giving an...
Hello thanks for using Fixya
To solve it try this:
If you receive this error with a second toner cartridge, you may want to check if the Front Harness Cable is plugged into the Toner Sensor then Do the following:
If you continue to receive the 929 error the final option is your printer will probably need service.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using Fixya
Feb 11, 2011 | Lexmark T520 Laser Printer
Our Dell 5210N printer gives the error: 929.00 service toner sensor. What should we do
  • The most likely cause of this error is the toner cartridge itself. This is especially true if it is a new cartridge and the error started after you installed it.
    1. Take the cartridge out of the printer and locate the encoder wheel on the right-hand side of the cartridge. The encoder wheel can be found on the right side of the cartridge (usually over a bar code sticker). It is a thin, black, plastic wheel with small rectangular notches cut into it. This wheel will sometimes get stuck, but you can free it by turning it by hand.
    2. Try moving the wheel forwards and backwards a little. If it does not turn correctly, you will receive a 929 Toner Sensor error on the printer when you try to use the cartridge it is attached to. Note: The encoder wheel moves only a little bit each way. It should not make a complete revolution. If it does, the wheel is probably broken.
    3. Try to move it a little bit each way a couple of times to see if you can free it up. Caution! DO NOT force the wheel as you could break it.
    4. If the wheel on the toner cartridge is stuck, try another new toner cartridge. ( If you do not have another new toner cartridge available, an old toner cartridge or another cartridge from a working printer of the same model will also suffice for this test.) Power the printer off and install the second toner cartridge. Then power the printer back on. If another toner cartridge clears up the 929 error, the printer is fine and the problem is with the toner cartridge. If the error does not clear, there may be a problem with the printer.
    5. If you narrow down the problem to the toner cartridge, call the point of purchase and explain the situation to them. They may have a replacement policy. If they cannot help you, call our Technical Support Center and we will see what we can do to replace the cartridge that is causing the error. We will not be able to reimburse the price of the cartridge, but we can offer you an exchange. To do this, we may ask you to send in your cartridge first. Please note that we cannot offer an exchange on a refilled or refurbished cartridge. For this, you must go through the point of purchase.
  • If you receive this error with a second toner cartridge, you may want to check if the Front Harness Cable is plugged into the Toner Sensor. Do the following:
    1. Turn off the printer and remove the toner cartridge.
    2. Look inside the printer at the place where the cartridge goes (on the right). You should see the Toner Sensor. On the back of the sensor assembly, you should be able to see a white cable connector.
    3. Push this white cable connector into the toner sensor assembly by pushing the connector towards the front of the printer.
  • If you continue to receive the 929 error, your printer will probably need service.
May 20, 2010 | Dell 5210n Laser Printer
Infoprint 1120 929 service toner sensor error code
The problem is caused by one of the following (normally it's the cartridge that's faulty, very common on Lexmark's and IBM Infoprints)
The toner sensor is not operating properly, the developer
drive assembly is not operating properly or the print
Jun 09, 2008 | IBM Infoprint 1120 Laser Printer
well i was having the same problem and what i did was open up the side of the printer. the same side that the toner sensor is on. the sensor consists of three metal parts. i took a screwdriver and pressed them on the outside. i pressed them in and up to ensure that the sensors are connecting. and i have not had that problem since.
Nov 02, 2007 | Lexmark T630n VE Laser Printer
Lexmark Optra T620 Laser Printer Logo
3,213 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
