Matherboard foxcon i915
I want to know that matherboard foxcon i915 Contains sata or ide
    Problem Solver:
  • 5 Answers
Just do a search for foxconn support and you will get a link to their support website It is quite user friendly and you can get manuals and driver downloads even for distant past products. Had to go there myself.
Posted on Jan 15, 2014
    Genius:
  • 2,785 Answers
Both
Posted on Jul 03, 2008
Pi945 matherboard not support 250 GB hard disk Give me answer please
which type of hdd ? ide ? or sata 2 ?
try to update latest bios firmware
Aug 30, 2016 | Hard Computers & Internet
Subject to not support To inset win xp3 intaling running main probl apperaring not detecting dard disk device some contains prompting on bluescreen background
windows xp dose not contain by default sata drivers, u will need to change the windows cd whit 1 that got sata drivers, or u can go to bios and search where is write: sata mode=AHCI and change it to IDE
Sep 23, 2011 | Computers & Internet
Need a dvd drive for a et1831-7 emeachine
If your optical data cable is long gray and flat then you have a PATA/IDE drive and if your optical data cable is small and contains 7 small pins it is SATA You can look up both IDE and SATA on google to check. Then you can order a matching hard drive off of a website. I strongly recommend www.newegg.com. As long as you order the matching cable type you can order any model make or color for your computer.
Apr 11, 2010 | E-Machines eMachines Desktop PC
Looking for hard disk 320GB for my asus matherboard p5gd2-x which HDD sopport this matherboard help!!!!!
pretty much any brand will work. looking at the specs tho get a sata type drive as it appears you have 4 on that motherboard
Storage Controller Type(s) DMA/ATA-100 (Ultra) x 1, Serial ATA x 4
Dec 02, 2009 | Computers & Internet
I want to install a 2nd dvd burner. But I don't know how to hook it up. My new pc does not have the ribbons like my old one does.
If your 2nd DVD burner is on IDE interface, you may need to get an IDE to SATA cable. Please refer to the picture below as to how it looks like:
Oct 29, 2009 | Compaq Presario 5000 PC Desktop
How to install Redhat Linux 4.0 on Acer Power Series with SATA.
So did you try to install with and IDE dvd drive? Might be a BIOS issue, update bios or get a ide dvd drive somehow...
May 06, 2009 | Acer Computers & Internet
It wont start.. what is sata?
You have to make sure first, what is your HDD type? is it IDE or SATA (Serial ATA).
Check it out: http://www.wisegeek.com/what-is-sata-or-serial-ata.htm
You should plug the data cable, to your hard disk. Remember, there's no way to plug your SATA cable to IDE HardDisk because the connector are not the same (I don't know if there's a converter between it).
So, make sure it first. If it IDE, find IDE data Cable, and make sure it plugged to your MainBoard and Hard Disk. Do the same procedure if it is SATA Hard Disk, only this time you should connect the SATA cable from your mainboard to your SATA Hard Disk.
Mar 11, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Dll gx280 case
first off does the motherboard have both sata and ide connections or just sata or just ide? (sata are small about maybe 1/2 inches in length and 1 mm wide and a ide connection is approx 5 inches long with about 4 inches long with over 100 pins and about 1/2 inches wide) i know that the opliplex 520 are nothing but sata so if it uses the same mobo as the 520 and you have ide then its imposible to install on your computer unless it either has a ide connection or you get a ide pci or pci-e controller card and install that onto the computer. but for the most part a ide connection needs a ide cable and a sata connection needs a sata cable.
Jan 23, 2009 | Dell (2336V) Motherboard
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
