I have a ZyXEL P-660HW-TI ADSL wireless router used as the gateway and wireless AP (also the wired ports are used for LAN). It has no VoIP ports. I do have a 2nd ADSL router (not used: no wireless, 1 LAN port) which HAS a VoIP port. Can the two be configured so that I can have VoIP available?
  • farzin884 Jul 03, 2008
    Thank you. Back to the drawing board!
I have zyxel p-660hw-t1 router. the problem here is - cannot ON. i've change the adaptor but it still can't on. how to repair it?
Posted on Apr 18, 2011
    Sergeant:
  • 284 Answers
No because the VOIP need to be loged in first. if you have the voip first then the wireless router and you turned off the router dchp section part of the wireless modem then perhaps it will work, plus you need a voip account.
Posted on Jul 03, 2008
Beetel 450TC1
Yes. Simply disable NAT and DHCP service. You want it to be just a bridge, with wireless AP mode on.
Use one of the LAN Ethernet ports to connect it into your home LAN
Nov 28, 2013 | Computers & Internet
Zyxel P660HW-D1 Router. Which settings need to be changed to turn it into a repeater and connect with my main broadband router.
Can't use a router as a repeater in a wireless sense. You could set it to AP mode and run an ethernet cable from a lan port on your other router to the WAN/uplink port on the Zyxel. If it doesn't have AP mode then you could have it in gateway mode run have a different subnet on the Zyxel with DHCP.
Oct 29, 2011 | Zyxel P660HW-D1 Router
My nat type is strict and when i try to play my PS3 i have connection issues. How would i get my nat type to be open?
Zyxel routers don't support Nat 2 confirgurations for the PS3 software. You can fix some issues by powrforwarding the speciffic ports that the PSN uses. To do so follow this ismple guide:
http://portforward.com/english/routers/port_forwarding/ZyXEL/P-660HW-D1/PlayStation_Network.htm
It may vary from game to game so you should choose what speciffic product are you trying to use here:
http://portforward.com/english/routers/port_forwarding/ZyXEL/P-660HW-D1/P-660HW-D1index.htm
Mar 06, 2011 | Zyxel P660HW-D1 Router
Router requires resetting with MAC PC
My first suspicion is that you may be experiencing an ip address conflict. If your iPhone or PC is using the same IP address as your iMac, only one of them will be able to communicate (and possibly neither of them). This should occur only if one or more of these devices are using statically assigned IP addresses. Check the internet configurations for your devices and make sure they are all set to use dynamic (DHCP) addresses.
For reference, a manual for your product can be found online at P-660HW Series - Ultra High-Speed Wireless ADSL 2+ Gateway for ...
There are several models and versions of your product, and the manuals are different for each, so knowing the exact model and version of your unit would help in diagnosing this problem.
May 16, 2010 | Zyxel P660HW-D1 Router
After configuring network TCP/IP automatic Dns server automatic or preferred and alternate dns as given by isp, setting router to mode router encaps..pppoa (second trial RFC1483) multiplex..llc virtual...
ftp://ftp.zyxel.com/
this the web site download the user manual from this site what ur configuration go thought it i think you get it and maybe the problem in the pppoa line its working or not just check it
Apr 02, 2009 | Zyxel Prestige 660HW Wireless Router...
Zyxel P 660HW T1 how to apply DMZ mode for a CCTV
Network - NAT - Port Forwarding - Default Server, Put the IP of your CCTV Hardware/PC
This IP will accept connection on all ports.
I never did this yet so any success please reply.
Mar 26, 2009 | Zyxel Prestige 660HW Wireless Router...
ZYXEL P-660HW-T1 V2 WIRELESS ROUTER MODEM WILL NOT CONNECT TO MY ISP
is your router connected to your ISP ? (does your dsl led light up ??)
if no! check your wires from phone to router!! and check your SPLITER !!! (i had the same problem, i got bad spliter !!! NEW BUT FAULTY !!!)
chears
Sep 23, 2008 | Zyxel Prestige 660HW Wireless Router...
TCP connection
hi i two laptop one is sony and is working perfectly with wire connecter to router n with wireless but i buyed another laptop toshiba and try router connection its working brilliant but when i try connecting wireless its keep asking me a network security key or passphrase for zyxel and under that it say the person who set up the password can give u the key or the passphrase
please help me my email is ashwaq_20002001@yahoo.com
Jun 18, 2008 | Zyxel Prestige 660HW Wireless Router...
Internet Connection
give the dns value properly in the zyxel p660 and re-installed the driver of the usb adpater
Jun 04, 2008 | Zyxel Prestige 660HW Wireless Router...
Using just the VOIP part of a Belkin all in one router??
You will probably need to set it up differently, I do not know the belking router, but normally the VOIP functions only work on the wan port of these routers so you should make the connections as follows:
INET ---> (wan) DLINK (lan) -----> (wan) BELKIN (voip) --> Phone
|--------> Wired Computers
|--- ) ) ) Wi Fi computers
On the DLINK enable DHCP and set a fixed IP for the Belkin router, either by setting the belkin in an IP outside the DHCP pool or setting it from the DHCP server.
This configuration workd well with a DLINK and a Motorola (vonage) router I have.
Apr 23, 2008 | Computers & Internet
Computers & Internet Logo
345 people viewed this question
David Payne
David Payne
