Question about HP LaserJet 1320n Printer
Light printout My laserjet 1320n printer giving light printout.....
    Genius:
  • 2,785 Answers
Try with new tonner
Posted on Jul 03, 2008
Density Adjustment in HP Laserjet 1320
Firstly I doubt that economode is set by default, but maybe the printer is in
economode for some reason.
Secondly I would normally expect the problem to be the toner cartridge but
assuming you have checked this my suggestions are as follows.
1. Run two internal prints from the printer.
a. By pressing the green "go" button briefly.
b. By holding the green "go" button for 5 seconds.
The first print should give you an indication of the print quality, if it
is good then the printer itself is probably behaving normally.
The second print will tell you exactly how the printer is set up. This
includes whether economode is on or off and what print density it is set for
(default is 3, range is 1-5).
2. If economode is on or the print density is lower than 3 the easiest way to
fix this is to do a cold reset on the printer as follows.
Important note: This will reset the printer to factory defaults, the only
setting that is critical is the jetdirect setting. Since you stated that your
printer is a 1320 and that you are running DOS I am assuming that it does not
have an "n" (for network) suffix eg 1320n. If I am right in this assumption you
can ignore the jetdirect comments above, if it is a network printer the second
printout from 1a should provide the jetdirect information which you may need to
keep for future reference.
Cold Reset Procedure:-
a. Turn the printer power off
b. Press and "hold" the green "go" button whilst turning the printer on.
c. Continue to hold the go button for at least 5 seconds and until the amber
attention light turns on (triangle with ! in the middle), this should occur
before 15 seconds elapses.
d. Release the go button.
Factory defaults should now be reset and you can check using 1a whether any
changes occurred.
Dec 30, 2016 | HP LaserJet 1320n Printer
I am trying to install my HP LaserJet 1320n printer. However, after I select the correct printer port, it asks me to select the software to install from a list. I have Windows XP and the HP LaserJet...
Go here and download the North American full printing solution. This is exactly the same as having the CD and will self install the printer when it runs, just make sure the printer is disconnected when you start the install. Or you can just download the driver and then point the install to the driver file.
Apr 15, 2011 | HP LaserJet 1320n Printer
Is there a counter for pages printed on my 1320n
No, the page count is not on the test page. You need the configuration page. Press the GO button and hold for 5 seconds. The yellow light will come on and you can release.
Apr 05, 2010 | HP LaserJet 1320n Printer
Printer wont print after ink cartridge change
Hi pater_g:
Have you tried to reinstall the old cartidge to see if it would give a different problem ( light print ect.) if not try that. If the problem stays and you just can't communicate with the printer try rebooting you computer or go to www.hp.com/support to download a new print driver. I hope this helps you.
Apr 17, 2009 | HP LaserJet 1320n Printer
Light print out
plz try with new tonner
Jul 03, 2008 | HP LaserJet 1320n Printer
HP Laserjet 1320n Error Lights not in Manual
hi friends......
shivachadra is here.....just i faced this problem "Attention, Ready, and GO LEDs are on solid"
and i got solution in troubleshooting....just vi refixe the connetion of laser scanner........its the error of comunication between laser scanner and formatter....
May 27, 2008 | HP LaserJet 1320 Printer
HP Laser Jet 1320n series
The HP LaserJet 1320 has a USB port and a Parallel port.
The HP LaserJet 1320n has a USB port and an Ethernet port.
USB-to-Parallel converter cables, like this one, are designed to attach a parallel device to a computer's USB port.
But you need to do the opposite (attach a USB device to a computer's parallel port). A USB-to-Parallel converter cable will not do this.
Feb 29, 2008 | HP LaserJet 1320n Printer
Unable to communicate to a 1320n laserjet printer
unistall the driver completly and install again so after that click shared printer and them try it
Sep 25, 2007 | HP LaserJet 1320n Printer
HP LaserJet 1320n Printer Logo
44 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
