The cooling fan relay is located in the engine compartment just behing the left headlamp...not under the dash. There are cooling fan test connectors built into the wiring harness near the left strut tower. The cooling fan relay is controlled by the cooling fan temperature switch located on the rear of the engine. There are 3 temperature sending units on your car if it is equipped with a temperature gauge. If not, there are 2 sending units, One is for the computer and the other is for the fan relay.
The one for the cooling fan will have 2 wires, one Tan and Orange and the other Brown and White.
The cooling fans and cooling fan relay get their power from fusible links built into the wiring harness near the starter relay.
Could some please tell me where the air conditioner control module is located on a 1994 ford tempo pls [email protected]
I BELIEVE IT HAS A FAN MODULE LOCATED NEAR THE TOP OF RADIATOR. THESE USED TO BE A COMMON PROBLEM.
