Question about Belkin ( F3U13306) (f3u133-06)
Change ethernet cable
Please tell me how to change the end of ethernet cable, the little piece broken. I have the cutting tool and the clear thingy that goes at both end. appreciate any help.
  • mrst76 Jul 15, 2008
    I pull the cord and the cable came of from the box. I have no way of connecting the cable cord back I took the back off to see can I put the end back. but it look like i will have to take a small box off. What should I do
    New Friend:
  • 83 Answers
Karl is correct. I made for some time but it is not worth it. You will spend more time and money trying to fix one. It is very tedious and will cause problems down the road. Buy a new one.
Posted on Jan 03, 2015
    Problem Solver:
  • 30 Answers
I suppose you talk about a patch-cable (with soft, flexible wires). It is very hard to get all eight wires in to reach the right position without opening the "twist" in them. Additionally you need a special tool to press the 8 contact-pins through the wires. My advice is - forget it! Go to a computer shop and buy a new cable for a few dollars.
hth, Karl
Posted on Nov 27, 2014
Hood release with broken cable 2002 odyssey
look under the dash see if cable is broken close to that end
grip inner cable with pliers and pull hard
if broken at the engine bay
work from under the car with a long tool to release the bonnet catch
if not sure how its done drive to a panel repair shop for a solution
Jul 14, 2016 | Cars & Trucks
How do I remove the parking brake release cable from a 1997 Ford F-150?
I will try to help you here, if you are talking about at the rear drum /or disc removal there is a spring connected to the cable and this spring needs to be pushed back so you can get the welded bullet end of the cable out of the retaining lever you can make this yourself or you can buy the tool the tool looks like a long piece of metal with a circle hole at the end with a space cut out for the cable to fit through it then you push back on the spring to release the tension and you will be able to get the cable end out from the emergency brake actuator lever it requires some force to do this so if you decide to get innovative and make your own tool use a heavy gauge L bracket shape bracket a big one is required so it won't bend and you will have the leverage you need and the space for your hands to hold it ,cut the bracket down just to where the first hole is leave some metal here don't cut straight to the hole now at the center of the hole in the bracket cut a slice in it big enough for the cable to fit through it and your done put it on the lever to push the spring back and your in like flint a home made tool and a job well done how about that the other way is buy the tool about $20.00 bucks if you can find it the bracket described above is about $3.50 and at home depot / Lowes or what ever hardware store you can find and comes with the ability to create your own tools and a problem solving mind YEAH! YOU CAN DO THIS LATER MAN!
Aug 25, 2014 | Cars & Trucks
Spliced starter wire
Okay Panda cub,disconnect battery cables,get wire cutters and cut out bad part,take to Autozone and tell them you want a piece of wire a little longer but same guage and some connectors and a crimp tool.Slpice the end about 3/8 and stick in connector and crimp,and do the other side.Get electrical tape and wrap up,
Jan 20, 2013 | Chevrolet Monte Carlo Cars & Trucks
Have problems with little vacuum lines, they are broken
Any auto parts store sells vacuum tubing in bulk. Just get as much as you need and replace the lines piece by piece. Cut with scissors to get a straight cut. Diagonal pliers cut on a slant and the end result looks sloppy.
Oct 27, 2012 | 1992 Ford Explorer
I tripped over my earthernet cord and it broke the pice that lock the cord in place ---the port hole that click and lock it in place
Ethernet, cable with broken RJ45 end,
buy a new one, its sold everywhere, or put on a new end but the tool will be like $25, so....
my guess 8ft cable
even walfart has-em'
https://www.walmart.com/search/?page=1&query=ethernet+cable&sort=price_low#searchProductResult
Apr 11, 2017 | HP Pavilion dv6628us notebook
How to fix the Ethernet plug
The broken ethernet plug on the cable can be cut off and a new one can be crimped onto the cable. You need a special crimping tool and the wires needed to be arranged in a specific order in the connector.
If you do not have the skills and the tool then I recommend you purchase a new cable.
Mar 24, 2012 | Computers & Internet
My warrior keeps cutting out sometimes backfiring.i put octaine booster in clears up a little bit soon as gas up gets bad again.changed plugs run premiem gas still cutting out spitting and ...
Hi, Jamesw302002 and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a "LOAD" test "WARNING" you can have 12.5 volts or better but little or zero amps and the battery must be replaced.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage check for spark leakage in the dark.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Warrior idles but backfires when throttled weak sporatic spark help
Acceleration cut when going WOT
Yamaha XV1700PCRC Service Manual
OEM parts for Yamaha
Yamaha XV1700PCR Road Star Warrior Owner Manual
Feb 28, 2012 | 2003 Yamaha Road Star Warrior
Hi, I have a 1999 Camry LE 4-cylinder automatic. The car is not shifting into gear. I popped the hood up and noticed that the transmission control cable (shifter cable) connection to the neutral saftey...
I think the cable is molded into the little plastic piece. see if you can see the end of the cable. see if it looks like it broke, or was cut. if not, the molding came undone, and the cable pulled from the anchor in the plastic thing.
Aug 15, 2010 | 1999 Toyota Camry
Yellow Ethernet Cable
Ethernet cables can come in all colours (very unhelpfully). The cable you need has RJ45 connectors at either end, which are clear.
It goes by many names: you are looking for Cat5e or Cat6, ‘straight’ or ‘patch’ cable, which is used to connect, say, a computer to a router. Do NOT use ‘crossover’ cable.
Netgear has some info here (a little out of date but OK:)
http://kbserver.netgear.com/kb_web_files/n101561.asp
Jan 07, 2009 | NetGear WGR614 Wireless Router
Belkin ( F3U13306) (f3u133-06) Logo
1,162 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
