Question about HP PSC 2355 All-In-One InkJet Printer
Horizontal bands across image
The cartridges are relatively new, about 3 quarters full. Strong bands are being printed across the page, close and regularly spaced. Makes the picture look as though it's printed on cloth.
  • OzzieProf Jul 03, 2008
    In the end I bought a new black cartridge, and will return the faulty one to HP under its limited warranty, to see what they do. Appreciate your advice.
  • 2,071 Answers
Here's some possible problems and you may simply have to eliminate these areas to try and find out just what is causing your printers problem: a wrong cartridge; a bad cartridge; an expired cartridge [check the age date on the cartridge or the box it came in]; possible dirty electrical contacts for the ink cartridge causing problems; sometimes even that the pull tape was not removed correctly; possible dirty Encoder Strip/Sensor Strip; possible DIRTY and or DRY Carriage Assembly causing problems [usually not simply no ink printing at all], or even corrupted Printer Drivers causing problems [download new drivers from HP.COM]...First simply try cleaning the electrical contacts carefully and gently, with Distilled Water on Q-Tips or on a lint free rag. Its more likely that the electrical contacts on the ink cartridge, or inside the Print Cartridge Holder Assembly, may simply be dirty. With your printer turned on as normal, simply open the Top Cover and the Print Cartridge Holder Assembly will move over to around the center position. With the print cartridge holder assembly in the approximate center position, simply unplug the power cord from the back or side of the printer. That holder assy will now easily slide back and forth by hand and you can easily remove the cartridges for cleaning. Using damp Q-tips [not wet or dripping], gently and carefully wipe off the copper colored electrical plates on the cartridges and the electrical contacts inside the holder assy. Its best to use "Distilled Water", because it has less chemicals and minerals in it, than tap water and regular tap water can actually cause additional problems. Use new dry Q-Tips to dry off all the electrical contacts after cleaning...The only way to really eliminate a possible bad cartridge [even if it happens to be a new cartridge], is to actually replace it, or test it in another printer that uses the same cartridge and was working ok with its own cartridges installed. Unfortunatly, that is usually not practical, unless you know someone that has the same printer or uses the same cartridge in their printer..
Posted on Jul 03, 2008
    Brigadier General:
  • 6,966 Answers
It would seem that the printer heads need cleaning.Pls go to the "Printers & Faxes" and right click on "HP Deskjet D2300 series", select and click on "Properties". Pls click on the "Printing Preferences" button, click on "Printer Services" button. On your version, pls see if there is a maintenance or utility tab/button and check for head cleaning. Additionally, pls verify that the printer is not set to "Fast/Economical Printing" in the printer's "Printing Shortcuts" tab.
Incidentally, there are Printhead Cleaning Cartridges specifically fr the purpose of cleaning print heads.
Other things you can try:
1.You might try blotting the color cartridge on a damp tissue, or perhaps after soaking the printhead for a few minutes in a saucer of hot water.;
2. try replacing your ink cartridges;
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
    Master:
  • 497 Answers
If horizontal bands appear at regular intervals ensure the Autowipe function is turned off. Also ensure Preheat values are returned to default (Init Settings selected will return all user settings to default). Perform a test print from multiple applications to verify problem is not application or RIP specific.
  • Yaz  S
    Yaz S Jul 03, 2008
    Also rotate
    image 90 degrees in application and ensure blur filters are not
    used, resend file to printer. Perform a test print from multiple
    Do not use printers internal test print to verify banding problems
    as this is vector data which may exhibit normal vector dithering
    patterns. Replace all cartridges of affected color to isolate problem.
  • Yaz  S
    Yaz S Jul 03, 2008
    hope this works
    All the best!
    Thank you for using Fixya
    Genius:
  • 2,785 Answers
Plz check in the printing properties you are using the correct paper.
you can also try by printing in draft mode, if the problem is not solved then you can try by changing the paper.
If every thing fails then try by reloading the printer drivers and clean the cartridge contact point with the printer.
Still problem is not solved then try with another cartridge
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
Feb 12, 2010 | Canon PIXMA MP980 All-In-One InkJet...
Lines running horizontally across the printed colour page
Checked ink cartridge's, two had dried out, still had ink in them but the exit apertures were blocked.
So new set of ink cartridges and problem fixed.
Thank you
Jim
Feb 05, 2010 | Canon PIXMA MP610 InkJet Printer
HP Laserjet smudges across entire page
More than likely you have a bad toner cartridge.
Inkworks
866-381-0541
Nov 03, 2008 | HP DeskJet 5650 InkJet Printer
PRINTING PROBLEM
You printer cartridges need to be cleaned,aligned properly...printer software can do that...
PLEASE RATE ME AS ( FIXYA ) <blue boxes>............
Oct 19, 2007 | Epson Stylus D88 InkJet Photo Printer
White line across printed page
Hi Alms, Is there any chance you can post a scan of one of your faulty pages. This would help to assess the fault. If you print several pages, does the image move further and further down the page with each copy? Is the white band repeated down the page? If so measure the distance between each band - this will help identify the faulty component.
May 21, 2007 | Minolta magicolor 2200 DeskLaser Printer
Blurred bands in prints
Try changing ink cartridge. Print only "grayscale" and if that happens, you need a black cartridge changed. If, not color
Mar 16, 2017 | HP DeskJet 460WF Mobile Color Printer
HP PSC 2355 All-In-One InkJet Printer Logo
61 people viewed this question
Ben Johnson
