Question about Coleman Heating & Cooling
I have a Coleman 6770 A Series roof air on my trailer. It won't blow cool air. Is this a compressor problem? And if so, would it just be cheaper to replace the whole unit than to try and repair this one?
  • girlnextdoor Jul 12, 2008
    Hey thanks alot for you're responce. Turns out it was just a burned up wire. I replaced that, and now it works like new. Thanks again, i appreciate it!!
  • 828 Answers
Before the compressor is condemned, is it running at all? Is it getting the proper voltage? If the compressor will run and still does not cool the system could be low on refrigerant.
A replacement compressor is normally more economical than replacing the entire unit. It could be something as simple as a open thermostatic control.
Posted on Jul 03, 2008
My trailer roof top a/c is not cooling propeerly
Try regassing it. It may help solve this problem.
Jun 02, 2012 | Coleman Heating & Cooling
I have a 2010 30' cougar travel trailer, we have never used the air conditioner which is a coleman mach model, when I put it on auto and cool it blows cool air but never gets cold am I suposed to
Check the temperature of the air coming out the vent If it's more than 10 degrees below the air going in it's ok. If it's the same temperature, the condensing system may be not working. The compressor may just be a quiet one!
May 18, 2012 | Coleman Mach III Air Conditioner
I have 2 Coleman roof ac's on my 34' coach that are ducted. The fans work and the compressors come on but the air isn't cold enough to cool the coach. The front unit temp only goes to 70 deg....
Are there any filters? If they are clogged the unit will not work properly and the temp will not drop as much as it should as it cannot absorb the air in the trailer or room.
Aug 02, 2011 | Coleman Mach 15 Air Conditioner
How can I tell if the compressor is coming on on my Coleman 13500 roof top A/C unit? It blows air but not cooling. Thanks
When the compressor starts you will hear the unmistakable noise associated with it...there is a definite hum from the compressor...check the t-stat on the unit... they often go bad..
heatman101
May 19, 2011 | Dometic Rooftop RV Air Conditioner
I have a coleman roof top air conditioner on my 2006 Jayco travel trailer. The air conditioner will start to run and the fan blow air but it doesn't want to cool down. Is there somehting I should do or...
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Jul 27, 2010 | Coleman Mach III Air Conditioner
My coleman mah 3 roof top will not blowon fan side
Sounds like you have either a bad fan motor or a bad fan motor capacitor. When you turn the unit on with the fan not working, the compressor (the humming noise) runs and gets real hot real quick resulting in the compressor cutting off ( the nothing after) on it's inside high temp switch. This is what the compressor is designed to do so that when this happens, it does not burn the compressor out. Replace you fan capacitor, give the compressor an hour to cool, then try it. In most cases and if I'm correct, the unit will run just like you want it to. Good luck.
Please rate solution
Sep 09, 2009 | Coleman Mach III Air Conditioner
Coleman mach 3 rv roof mount ac
You will need 12 vdc (battery or converter) for controls to work, and 115 VAC (hydro) for fan & compressor to work. With your fan obviously working, that tells me you have both already but compressor may not be kicking in. Do you hear a "moaning" sound or see lights dim when switched to cool?
Aug 17, 2009 | Coleman Mach III Air Conditioner
Recycling to soon?
sounds like the unit is low on freon. it will need to be serviced so the leak can be fixed then recharged.
Jun 01, 2009 | Coleman Mach III Air Conditioner
Heating & Cooling Logo
122 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
