Question about Whirlpool AWM8143 Front Load Washer
Whirlpool AWM8143 sixth sense
My front washer makes sometimes a lound noise as if I would be washing boots in it. The code F06 shows on the display. Do you know what this code mean ? Thanks for any clues...
I had this same problem, an intermittent F06 fault.  The F06 code means a tachometer fault.  After some fault-finding, I did manage to fix it.  If this error code happens to you and you know a bit about electronics, try taking apart the timer and looking for dry joints between the main board and the perpendicularly-mounted microprocessor board. Over time vibration can cause the soldered joints between the two boards to crack and fail intermittently. 10 minutes to disassemble plus 2 minutes with a soldering iron could save you a $400 repair bill.
The service manual is available for download on the web if you google hard enough.  If you have a CRO available, the tacho waveform should be a nicely-formed sine wave with a frequency proportional to the RPM.
Posted on Jul 16, 2008
Try replacing the brushes this may solve the problem
Posted on Jul 03, 2008
I have a whirlpool sixth sense washing machine. the door open light constantly flashing although the door is well shut. No programmes work
We had the same issue: the cycle would start then stop, with the door open light coming on. It turned out to be a faulty contact in the door. Took a technician 15 minutes to fix.
Aug 04, 2011 | Whirlpool AWM8143 Front Load Washer
I have this written in my machine F06 what is that meanning
The F06 code will indicate a drive motor tachometer error.This means the control is unable to properly detect motor speed and the machine will shut down. If the failure occurs during high-speed spin, the door will unlock after 3 minutes.
The error code F06 is likely a loose connection in the harness between the motor and the (MCU) or between the (MCU) and the (CCU). It could also be the tachometer circuit in the motor or an intermittent internal component connection within the (MCU). Since the (CCU) has already been replaced, the failure is likely a loose harness connection or the (MCU). I recommend calling a service technician to check the connection.
Hope this helps.
Shane
Mar 15, 2011 | Whirlpool AWM8143 Front Load Washer
Whirlpool awm 8142 faul code f06 ja and i start it again, the new fault code f09 and the machine stops... whats wrong whit it!
F/06 error code, Drive Motor Tachometer Error
F/09 Overflow Condition
If the Overflow contact on the pressure switch is Closed for more than 60 seconds and Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service.
~Check the drain hose and make sure it is not plugged or inked.
~Check Wire Harness connectors to the Drain Pump, Pressure Switch, and ~Central Control Unit (CCU)
~Check/Clean Drain Pump Filter of foreign objects
~Check for Drain Pump Failure
~Check the Inlet Valve for proper shut off
~Check the Pressure switch for proper operation
Nov 15, 2010 | Whirlpool AWM8143 Front Load Washer
Hi I have a Whirlpool 6th Sense Washing Machine - AWM8143. I is washing and spinning perfectly well and there are no error codes. However when it spins the machine makes a grating squeaking noise that is...
hi,
looks like there is some friction between the main and outer tub of your machine. there is generally a mechanism for smooth spinning of the machine in good rpms for wash-spin cycle. this could be because of rust formation, or mud collection. please refer your manual and remove the 3 screws behind the lower front plastic cover, and look for rust formation. scrape the rust and try spinning again.
cheers
Jul 26, 2009 | Washing Machines
FP code appearing on lcd disply
remove pump and check pump for foreign objects stopping impellor turning, worked for me hope this helps
Dec 26, 2008 | Whirlpool AWM8143 Front Load Washer
Fault code F11 on whirlpool AWM8143 6th sense mwashing machine
got this from another site....
Starting to see these fault codes pop up in these otherwise fine machines. The F/11 code is just a generic code generated when there’s a communications error between the two main control boards in the washer. These two boards are the motor control unit(MCU) and the central control unit(CCU).
A common problem is the wiring harness jiggling loose; remove and reseat it and that usually fixes it. If not, then you’re looking at spending some money on control boards. Yes, I said boards, plural. The really sucky part is that there’s no way to definitively and conclusively prove which board, the MCU or the CCU, is at fault so, unfortunately, that only leaves the parts changing monkey method: replace both boards,
But, on a brighter note, the electronics are covered under warranty for 24 months. If your machine is older that this, then you’ll need to shell out some shekels
tnx 4 using fixya,
drcool
Oct 05, 2008 | Whirlpool AWM8143 Front Load Washer
W/pool awm8143 not finishing cycle fault F06 flashing on display
Mar 29, 2008 | Whirlpool AWM8143 Front Load Washer
Washer will not complete a cycle
hi,
i have a whirlpool 6th sense washing machine, it has come up with clean pump, does anyone know where the pump is on the machine, as i have lost my instruction manual.
regards
jackie
Nov 08, 2006 | Whirlpool AWM8143 Front Load Washer
Whirlpool AWM8143 Front Load Washer Logo
662 people viewed this question
Dan Webster
Dan Webster
Sal De
