I have a G5 Mac with a Power PC Dual Processor. When my computer seems to be doing too much it goes to sleep mode. At first I thought it was a over heating issue and then I thought it was a power issue but neither seems to be the case. Any idea what's wrong?
    Sergeant:
  • 284 Answers
Check the setting of the G5, you might have it going into sleep more sooner than expected.
also g5 do tend to heat up, check for burned capacitors, also the fans has to be running at a certain speed, the computer will tell you if it in sleep mode.
click on apple logo / system preferences and display
it should be there
Posted on Jul 03, 2008
My monitor seems to be stuck in sleep mode
This happens when there is no communication with video card. Check cables, re-seat video card, make sure monitor is set to correct mode. VGA (15pin blue), DVI (white), or HDMI.
Aug 28, 2012 | Dell desktop and monitor- Inspiron 530...
Getting a imac g5 all in one power pc 1.8 gb os x 10.3 computer. can i upgrade to snow leopard v 10.6.3 with disc ?
Unfortunately Snow Leopard requires a intel processor to work so the G5 imac will not be able to run the system.
Jun 24, 2011 | Apple iMac G5 Desktop
When I press the power button, I hear a dial tone chime 3 times, the power light flashes 3 times, and the fan runs but the computer does not start. It's a single-processor G5 desktop Mac that I bought...
Three tones is not a good sign, should hear only one. Go to Apple website, go to "support" and then G5 and there's is trouble shooting guide, (sorry, I'm not at my computer - I'm replying via my phone) Try starting in "safe" mode. Press shift key when you hear the chimes
Jan 09, 2011 | Apple Power Mac G5 Desktop
Power Mac G5 usb front+others does not always work does not seems to have power flowing with the USB ports. boots well, sleeps well. what can be the problem? thanks, AM
You may have more things plugged in that the computer wants to supply power to. I suggest getting a self-powered hub. I did that and those issues went away for me ... mostly. <grin>
Nov 30, 2010 | Apple Power Mac G5 Desktop
Apple Power Mac G5, 2 ghz Dual processor (not Intel) freezes and fans go on full if left idle for a period of time (roughly half hour or so). Run disc first aid, zapped PRAM. Not sure what else to do at...
It sounds as if it could be a thermal issue.
Open the side and clean out the dust from inside the Mac.(Use a clean 1" paint brush)
Take the main processor fans out and clean the heat sinks for the processors.
If you are still having the same issue, then your only option is professional help.
Nov 29, 2017 | Apple Power Mac G5 Desktop
My computer goes to sleep and sometimes I can't wake it up.
When is asleep try to close the lid completely and open it again. This works for mine sometimes.
Jul 23, 2010 | Dell Inspiron 530 Desktop Computer...
Cannot install final cut pro.....the software says my macbook pro(macbook3,1) does not have minimum system requirements. my mac.... 2.2 ghz 800mhz core 2 duo 4gb ram 2x2gb @ 667mhz GeForce 5600m gt 128mb...
yes it seems that your laptop dose not meet the minimum requirements to install final cut pro software.you will need to purchase a laptop with the correct requirements,sorry.
ken
Apr 04, 2010 | Apple MacBook Pro Laptop Computer with...
Switching from Power PC to Intel Dual Core
You would have to buy a whole new unit, G% processor is not interchangable physically with the intl/
Jan 07, 2010 | Apple iMac G5 Desktop
Hello, I have an X800XT Mac Edition graphics card with a G5 2.0 dual processor and the problem I'm having is that when I boot up my G5, it goes through the spinning weel process, but when it's finished and...
I am going to recommend a hardware approach first and then a software approach, to this issue, in order to assist you. At the end of these procedures, is a general support link from Apple for additional support for no picture in your iMac G5 display
I am seeing more of such display issues like this, and more often than not, if the problem does not have to do with the firmware, it may be a damaged or corrupted file which can hinder the iMac G5 from normal start up functionality.
PMU Reset (try this first)
The PMU (Power Management Unit) is a micro controller chip on the logic board that controls all power functions for your Mac.
• Shut down the computer.
• Unplug the computer's power cord.
• Press and hold the power button for 20 seconds.
• Release the power button.
• Attach the computers power cable.
• Press the power button to turn on the computer.
* Boot to your desktop.
This procedure may help but if it does not, follow the procedure below
-SAFE BOOT MODE-
• Reboot your Mac
• Upon restarting your Mac, press the Shift key.
• Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
• When you see the Spinning gear, release the Shift key.
• Allow the Mac to continue booting up. Also this may take a little while
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Mac and try just once more. It may have just frozen up the first time around for you.)
• You are going to enter the Safe Mode (which looks like your main desktop environment - the only difference is certain startup items are disabled.)
• Once within the Desktop in Safe Mode
• From the Finder Menu, click Go> Go to Folder
• Type in this line: /System/Library/StartupItems
• This path, is going to take you to the System Library folder which has all of your Mac OS X Startupitems.
• Remove all of those folders to the Trash.
*Reboot your Mac normally and see if you can access your normal User desktop environment.
One of these two procedures should help resolve the blank display issue you are experiencing,
Additional Support Link:
Apple Support iMac G5 - No picture on display
Regards,
-Mactechtrainer
Dec 11, 2009 | ATI Radeon X800 XT Mac Edition AGP Video...
Why my MAC G5 turn off when the sleep mode is on
You may have your energy settings set to turn off the Mac after a specific time of inactivity. The power on / off option is in the Schedule button in the Energy Saver pane in system preferences under the Apple menu.
Jun 06, 2009 | Apple iMac G5 Desktop
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
