Question about Kyocera FS-4000DN Laser Printer
Problem with printer kyocera mita fs 4000dn make anoise than intalled devoloper unit.
  • felko Jul 03, 2008
    hi this is Dilip my printer is fs 4000dn laser printer making noise when i installed developer unit.
    hi, this is Dilip. i am facing problem with fs 4000dn laser printer make sound when devoloper instal.
  • 25 Answers
Check the gear in the dev unit. also try and turn the mag roller by hand it might be jammed up
Posted on Nov 12, 2008
Call Service 7000: 0370082 Kyocera 4000dn
Toner motor lock error ,usuall ycaused by using non manufacturer toner ,you may need to get a new developer unit
Oct 14, 2013 | Kyocera FS-4000DN Laser Printer
Tengo un problema con la impresora kyocera fs-4000dn, que me sale el mensaje llamar servicio 7410:0052827, me gustaria saber a que se deve el problema. saludos...
tengo un Problema con mi empresora Kyocera FS-4000DN Laser Printe. me aparece comprobar caja de toner y no me deja imprimir les ruego q me colaboren muchas gracias por los servicios
Sep 23, 2010 | Kyocera FS-4000DN Laser Printer
Error llama 7410 0013444 impresora kyocera ecosys fs-4000dn
Drum unit non- installing error
The drum unit is not installed or not
installed properly.
The drum PWB EEPROM does not communicate
normally.
Causes:
- The drum unit is not installed.
- Defective connection drum PWB (YC1) and connect-L PWB (YC3).
- Defective drum PWB EEPROM.
- Defective engine PWB.
Check procedures/corrective measures:
- Install the drum unit
- Check the connection of connectors drum
- Replace the drum unit
- Replace the engine PWB
Aug 04, 2010 | Kyocera FS-4000DN Laser Printer
Kyocera FS-4000DN Laser Printer call for service 7000:0103031
that's just a toner motor error..most likely the toner was not put in properly..remove the toner than reseat the toner making sure it snaps secure into place..you should than be fixed
Jan 20, 2010 | Kyocera FS-4000DN Laser Printer
KYOCERA KM2020 erreur C-4000
cause
Defective harness between drum motor and engine PWB (YC11), or
improper connector insertion.
solution
Reinsert the connector. Also check for continuity within the connector harness. If none,remedy or replace the harness.
cause
Defective drum motor drive transmission system.
solution
Check if the gears rotate smoothly. If not,grease the bushings and gears. Check for broken gears and replace if any.
cause
Defective drum motor.
solution
Replace the drum motor.
cause
Defective engine
PWB.
solution
Oct 26, 2009 | Kyocera Mita KYOCERA/MITA - FS-4000DN Mono...
Accounting error report... i need to disable the software for the printer side only printer is now at a new account that does not have the software installed on the computers
consult your user guide or try kyocera tech support but if I remember right... you press the small circular button then job accounting... then 6482 and then select off... could be wrong... I haven't done it in a while...
May 12, 2009 | Kyocera Mita KYOCERA/MITA - FS-4000DN Mono...
Kyocera FS-4000DN, CALL SERVICE 6030:0159631
this error indicates a problem with the fuser unit.
if you are an end user, you will have to check warranty status with you nearest service agent and have the fuser replaced free or get a quotation if it is out of warranty
Mar 09, 2009 | Kyocera FS-4000DN Laser Printer
Looking for Kyocera Mita Ecosy FS-1010 Instruction Manual
A downloadable copy of the Kyocera Mita FS-1010 user manual is available here.
Good luck and kind regards.
Thank you for using FIXYA.
Feb 12, 2008 | Kyocera Mita FS 1010 Laser Printer
Kyocera FS-4000DN Laser Printer Logo
112 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
