Question about Refrigerators
Fault e8 displayed on beko ap930 fridge freezer
  • 1 more comment
  • ffdasilva878 Feb 19, 2009
    E8 is displayed, but the fridge is working fine e.g. ice dispenser,etc...
    Can anybody replace the ice cube tray sensor cover? if so...how?
    I'll be very appreciated if anybody can help me with this. Thanx
  • Richard Perkins
    Richard Perkins May 11, 2010
    Is everything working or is there something that is definately faulty?
    I've requested clarification of error codes from Beko. Just awaiting their reply now.
    I will post again when they reply, and hopefully give you directions to a fix.
    Thanks for using Fixya!
I had the same error message and the ice cube dispenser stopped working. On examining the workings, I found that the wire that should have been connected to the ice cube tray had sheared somehow (???) - a simple splice with lots of insulation tape has apparently fixed the problem.
Posted on Feb 22, 2009
    Genius:
  • 1,036 Answers
E8 is an Ice sensor failure (according to Beko)
From the listings, I think this is it. -
Clicky here
Beco wanted to send an engineer out with one to fit it. I'll let you guess the quote.
- It was more than £2.50 though.
Thanks for using Fixya! If this works for you, Please rate as fixya for others to follow. Thanks.
Posted on Jul 07, 2008
Why does the new fan in my Beko AP930 not come on. It worked for 30 minutes when I first installed it.
Three possibilities: 1) new fan motor failed or is jammed by something
2) power is not getting to the new fan. 3) The fan run circuitry is not getting the 'run' signal from the temperature sensing system.
Jul 23, 2014 | Beko Fridge Water Filter Ap930 Ap930x...
Why won't the new fan on my fridge freezer work
The new fan motor may have failed!. Check the power supply to the fan motor. If the fan motor was not designed for the very cold air (-20 F) it simply stuck.
Beko fridge freezer modle ap930s my fridge is freezing everything inside is this because the thermostat is not working?
Change the thermostat.
http://www.acmehowto.com/howto/appliance/refrigerator/repair/tempcontrol.php
Nov 28, 2010 | Refrigerators
Error code E3, BEKO AP930
Hi, the error code E3 on the BEKO AP930 you have a problem with the fridge thermostat open circuit....
Take care
Jul 23, 2010 | Refrigerators
Beko ap930 no water geting to to ice tray
For me, this problem was because the tube was blocked with ice (the part of the tube inside the machine), which is why the tube popped off the back.
Try defrosting the freezer, or pushing hot water through the pipe with a syringe
Oct 28, 2009 | Beko 24 in. D3421F Free-standing...
Beko AP930 with Error code E0 in LHS of display .... what does this mean ? .... nothing in manual
Error codes are printed on underside of plastic cover on top of fridge. Warning electrical components inside! Error code E0 is the FREEZER door not being recognised as closed, switches are normally ok may be problem with printed circuit board. Freezer will work as normal but engineer should be called.
May 08, 2008 | Refrigerators
I havew a Beko AP930 displaying error E8. The instruction book does not explain error codes. Can anyone help?
have the same thing and it is a small sensor on the ice maker that can miss align,ours is under warranty and is being repaired its just a case of re-positioning it...ps make sure water filter is changed every 6 months
Apr 25, 2008 | Refrigerators
I own a Beko AP930 side by side frost free fridge freezer.Yesterday an error code appeared on it ,the code is E8.Could you please tell what this means.Thanks.
Just had this fault fixed on my 930. It is the ice sensor just under the ice cube tray - mine had a broken wire (from rotating several times a day for over a year!)
Fiddley but easy fix yourself with a "leggo" block connector to re join the wire if that is the fault, or ring Beko on 01923 654659 (very helpful company to deal with) for a part.
Part number 4344740185.
The other suggestion about the water filter I respectfully believe is wrong!
Apr 21, 2008 | Refrigerators
Refrigerators Logo
1,832 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
