Question about Panasonic Audio Players & Recorders
Car cd player shuts down and needs resetting every time it is turned off
  • 2,071 Answers
Shut down problem mostly occur in the power supply section, and power amp.When resetting it works , there is crack or cold solder joint of the parts,you better to reheat or resolder that section i mention . or find a technician to do works this is not cost too much because reheating only.....
dont forget to rate me
Posted on Jul 03, 2008
2004 cadillac srx cd player jammed
I had the same problem. disconnect the battery cables. then reconnect them. this will reset the cd player and it should relaese all your cd player problems.
this happened twice to me and the above worked fine both times.
Jun 11, 2009 | 2004 Cadillac SRX
My jensen mp7610 car cd player
I asked a friend of mine and he didn't charge me ANYTHING. What happened to free advice? What has happened to helping each other out? This is bogus!
Sep 28, 2008 | Jensen MP7610 CD Player
My cd player works intermittently
i dunno wot is happenin but the same thing is happenin 2 my cd player nd it reli annoyin! please sum1 help!!!
Aug 28, 2008 | JVC KD-SX980 CD Player
At high volume sound shuts off, subs still work
You most likely have a shorted or damaged speaker, which is causing the internal amp chip to shut down (but does not affect the preamp outputs). A test you can do is to fade to one speaker at a time and turn it up to se if it shuts down. Repeat with each speaker until you find the one that causes the fault. Then replace it.
Dec 08, 2007 | Pioneer DEH-2100 CD Player
No Power At All
I have the same problem with my sometimes. Sometimes it is working fine and when I turn the car back on, it won't go at all. On the back of the head unit, there is a reset button. Press the reset button then press the power button and it should work.
Oct 14, 2007 | Lanzar VBD1200 CD Player
No sound.
Disconnect speakers one by one and reset the unit each time. If the speaker is blown, or the wires are frayed, it will shut down the internal amp. Also check the fuse in the back of the radio first, it should be near the wire harness. Power cycle the unit as well, unplug it from the power source, plug it back in. Hope this helps.
Aug 16, 2007 | Clarion M475 CD Player
HU Shuts Down - "Protect" Blinking
if it is only doing it over 30 then you need to turn down the bass level on the deck and make up for it with the subs sounds like its putting out too much juice. also if your car has a factory amp for your door speakers ect make sure that your factory speakers are the same ohms as the cd player which is 4ohm ,most fancier car speakers are 2 ohm. if that is the case the amp on the cd player is going in to protect mode to prevent frying your factory amp if you have one. check all your wiring from the cd player to the car and make sure it is all properly hooked up and there are no crosed wires. or wire hooked up incorrectly. also make sure the amp wiring kit is big enough gauge for the amp. make sure its not the amp that runs your subs that is cutting off the HU.
Nov 21, 2006 | Kenwood KDC-X890 CD Player
KDC.716S Mech error issue
Try the tiny reset button on the front just below the volume down button.
Nov 10, 2006 | Kenwood KDC-716S CD Player
23 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
