Question about Hotpoint VLXR1020A Top Load Washer
Washing machine wont circulate the clothes, the thing inside wont move
Go to wash clothes, water fills and drains but wont wash the clothes basically just soaks the whole time.
  • Anonymous Mar 23, 2014
    Have to wash again
    Sergeant:
    Champion:
  • 330 Answers
Check the belt, either loss or broke
Posted on Jul 03, 2008
  • Frank Chen Jul 03, 2008
    or jump out of the track
Maytag bravos mct washer keeps filling with water on drain and spin cycly
first thing to do is a reset. unplug it for 5 min and plug back in to see if it resets to factory settings.
Jan 21, 2018 | Maytag Washing Machines
Inside of the washer really smells moldy.How can we fix this?
fill it with water on hottest wash
add a whole tub of oxy on wash
do a cycle till you get to second rinse and empty
drain
and repeat the wash add cheep thin bleech this time {not thick stuff} use the thin cheep 3L from super markets
and run thru the wash on hottest
wont smell now ...
also check your waiste system has a U bend on the outlet
needs one to stop bad water coming back to the pump
take out all plastics and wash them and soak them in bleech
Feb 01, 2014 | Speed Queen AWS17NW Top Load Washer
My 12 year old AEG OKO LAVAMAT is making a grinding sound when it fills. It's fine at all other times. I've tried cleaning out the filter, and running it empty.
This is usually caused by the recycling pump running empty whilst the washing is still soaking up the initial fill water. as the water begins to soak the clothes it then starts to pass through the drum into the pump and the whole thing quietens down. running empty will not work. to test this theory try opening the drawer very slightly and filling it manually with a hose before starting the machine, (ONLY TO THE NORMAL LEVEL) and see if the noise is still as bad.
Feb 09, 2013 | AEG Washing Machines
I want to keep the water in my Roper top load washer overnight so it will soak the load of whites I have started but the machine drains.
You should be able to select a soak cycle without having to turn off the water supply, but it may time out eventually and drain the tub. This p[events oversoaking the clothes
Oct 13, 2012 | Roper RAS8445KQ Top Load Washer
The waste doesn't drain all the way.clothes remain soaking wet and often during a separate drain cycle it flashes: sud
if you are using to much detergent the washer won't drain correctly and if it's a front loader you'll damage the spider gear and then it's time for a new washer.the detergent eats at the metal and the gear on the back of the tub falls apart,i've found pieces of it in the pump on some washers,you should be using 1/4 of a cup of detergent in a front load washer,if you're using a whole cap it will suds up,the pump can't move the suds,when the suds sit for a while it turns back into water,take out the clothes,fill up the washer and drain it out,flush it out a few times to get all the suds out and cut back on the detergent
Jan 14, 2011 | Washing Machines
Will fill and drain, not agitate or spin though
I am having the exact same problem with the same brand machine.  I put in a load of clothes to soak till the morning, but in the morning, the washing machine would only fill, spin, and drain.  The agitator would not wash the clothes, so they came out with the soap of course still crusted in.
Jan 22, 2009 | Roper Washing Machines
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Not draining
it will be the pump they have a small fan inside them they get weak and with the pressure of the water they stop spinning which doesnt push your the water through the motor fast enough to drain properly replace and you will see the difference
Aug 22, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint VLXR1020A Top Load Washer Logo
162 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
