Question about Sony SA-VD900 DVD SolutionHome Theatre System System
Dvd totv cannot get sound from tv through to the home theatre system
  • 151 Answers
IF you have a cable running from the tv to your system from the audio output you may have to turn on or turn up the output in the tv menu,some SONY tv s are like this. If you have done this and are useing a amp like a ONKYO or YAMAHA etc you will have to go to the input assign in the setup menu and tell the amp were the cable is pluged in and which type.
hope this helps.
Posted on Jul 03, 2008
Toshiba tv has no sound but does with DVD player on, how do I regain sound for tv shows
is the dvd player a home theatre system?if yes,does the tv play sound via the dvd home theatre speakers when it is on?if yes then maybe you should double-check your audio port connections between the two for correct configurations
Jan 04, 2016 | Toshiba Televison & Video
Audiovox DVD Home Theatre System Sound Issues
check the audio settings make sure they match where you plugged the source. and if all of your sources run into the tv first you will need to have an audio out to the reciver
Apr 25, 2010 | Audiovox 150W DVD Home Theater System -...
Getting sound to TV from DVD Home Theatre System
lght304su home cinema,how to connect to tv to get sound through
Dec 29, 2009 | Sony DAV-SR2 System
No sound from home theatre system for TV
Have you plugged in the audio output of your tv to your home theater system? if not try it, sometimes it helps.
Jun 09, 2009 | Sony HT-DDW700 System
Ghosting of picture from a Panasonic home cinema system
There must be a fault in the screening of the internal wiring to the scart outlet in the home theatre system. I simply changed the way the player was connected to the TV and the interference disappeared:-
1.) I used the RCA video outlet instead of the scart lead. Picture quality was not compromised. FYI the Panasonic Plasma TV I have has only RGB video input sockets at the back, so I used a scart to RCA adaptor to overcome this problem of connecting old technology to new.
2.) The surround sound when playing DVDs is generated directly from the home theatre system so there was no need to connect the audio from the home theatre system to the TV
3.) I used a pair of RCA leads to connect the "audio out" from the TV to the "audio in"on the home theatre system to provide the option of TV sound through the home theatre system.
Mar 18, 2009 | Panasonic Televison & Video
Sony Model DAV ? SB 500W Home Theatre System
Please check at rear of TV for Digital Optical IN port as home theater should have optical out port at rear. If you got any optical in port in TV, just connect optical wire between TV and home theater.
2nd option is check Line Out pins at rear of home theater system, if found, hook red-white RCA cable there and put it to same input in TV where you hooked Video (composite or component) cable.
Let me know the results to help you more.
Jan 07, 2009 | Sony DAV-SB500W System
Panasonic 50? Plazma TV TH 50PZ 800A + Sony Model DAV ? SB 500W
that is possible
the home theater has so many in puts on your dvd and out puts.
there is a way
1 you can buy a vedio/audio converted to rf signals, this will mean both signals entering tv using rf.
2 get your vedio out from dvd and audio out, feed that to a converter, vedio in and audio in okey
Hooking Up The Theatre System to the TV and Cable.
this means you likeley have your cable box connected correctly, if you have it connected to a standard definition input (AV in or coaxial) make sure the that the dvd player is not in progressive mode.
Jan 27, 2008 | Panasonic SC-HT680 System
T v and home theatre sony bravia
As most home theatre systems offer no analogue audio input and only use the audio coming from the dvd being played the short answer is no.
If your home theatre system has a digital input and the tv has the corresponding output then yes you could me able to connect the two. Otherwise you could try to get hold of a analogue to digital converter and convert the tv's audio out to digital.
Jan 11, 2008 | Audio Players & Recorders
Sony SA-VD900 DVD SolutionHome Theatre System System Logo
91 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
