Question about HP Color LaserJet 2600n Printer
Problem In Red Color
I am Tring To Print In Hp LaserJet 2600 Color Printer But There is Problem In Red Color
  • Eagle Scout Jul 04, 2008
    I have the same issue. Been having the problem since the printer was about 6 months old. New cartridges don't seem to help. Red ink on left side of pages is half as bright as on right side.
Okay, I found what appears to be the solution, you are not going to like it. Looks like it will take a good hour and possible not work if you scratch things. You have to go deep into the printer and clean mirrors. I think I will buy a new printer and it wont be an HP after this. Here is the discussion on the HP forum . Note the paper click in the post by Don, that will give you a PDF will the step by step instructions.
Posted on Jul 04, 2008
How to fix sensor error on hp color laserjet 2600
54.06
Error message
54.06
Description
Color density sensor error
Action
  1. Power cycle the printer.
  2. Calibrate the printer. Click here to view the document "HP Color LaserJet 2600n - Calibrating the printer" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314525).
  3. Change the Print Density settings through the HP Toolbox. Click here to view the document " HP Color LaserJet 2600n Printer - Change Device Print Settings in HP Toolbox" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00310627).
  4. If the problem continues, contact HP Customer Support Center for technical assistance athttp://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Apr 02, 2014 | HP Color LaserJet 2600n Printer
Only print in black from color laserjet 2600
take one demo page from the printer menu. if the printout is also in black your printer need to be serviced .
Oct 09, 2013 | HP Color LaserJet 2600n Printer
Will not print blue? HP 2600
SPACILLY FOR HP PRINTERS DONT USE THE REFIL CART
this problem due to refill cart replace with new one ur problem will be resolved
Jul 01, 2010 | HP Color LaserJet 2600n Printer
Hp lazer jet 2600N won't print red color what will fix it. Has a new cartridge
You may need to replace FORMATTER BOARD & DC CONTROLER BOARD ASSY which are located behind the printer. Both BOARDs are side by side together. Just open the back cover, you will see it.
Jun 10, 2010 | HP Color LaserJet 2600n Printer
HP Color laserjet 2600 only black print is commong
It a problem with printer fusing assembly. so you can checked it from service center.
Nov 23, 2009 | HP Color LaserJet 2600n Printer
Xp driverd for HP 2600 color
On the HP website for driver downloads we used the last set of drivers listed (script) that solved the problem of no color and 11x17 sheet.
Oct 22, 2009 | HP LaserJet 1000 Printer
Will this printer print on heavy card stock and
Yes the 2600 will print on heavy card stock and vellum paper. I had one and did some landscape proposals on this printer and also printed on card stock as well.
Oct 17, 2009 | HP Color LaserJet 2600n Printer
Hp 2600
It migh be that there is not toner in your cartridges. Try to print test page from windows.
Sep 23, 2009 | HP Color LaserJet 2600n Printer
Hp color laserjet 2600 n it will not let me print
There is an override sequence and it works well. Press the select button (checkmark) to indicate Main menu. Press right-arrow (RA) to select System Setup. Press Select , then RA to Print Quality, Hit select. RA to Replace supplies and hit Select. Now, RA to Override Out and Select. Confirm with Select again. Your 2600n will now run even with an empty toner cartridge.
Jul 08, 2009 | HP Color LaserJet 2600n Printer
HP 2600 Laser Printer
Clean the paper path. See the HP Toolbox online Help.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=446153&prodTypeId=18972&prodSeriesId=446153&objectID=c00316826
Jan 16, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
266 people viewed this question
Ben Johnson
