Question about Arris SB5100 SURFboard DOCSIS 2.0 Cable Modem (50120900100)
System can't Install the MODEM Drivers
Hi Experts,
I Have a, lenova Laptop. Recently i took Cable Modem Connection (8mbps) with Motorola SB5100 SURFboard DOCSIS 2.0 Cable Modem. I did all the requirements (i.e plugged all the cables at exact places). I am getting a problem when i try to plug the USB it should ask for drivers installation. My system didn't ask for any installation process. Later i tried in different way, system showed the installation window but at last it is showing Installation was unsuccessful.
My system Status. 2 OS, (windows xp, windows 2003)
Windows 2003 D:\ i loaded SAP (in SAP i did Microsoft Lookback Adapter for single PC network)
windows XP c:\
i am trying internet connection in XP.
Please guide me to solve my problem.
Upendra.
parveendra@gmail.com
Please
  • Anonymous Aug 27, 2008
    i have no drivers for modem modelsb5101e
    Problem Solver:
  • 13 Answers
You would need to install the USB drivers from the Motorola disk as windows does not have these USB drivers natively.
Posted on Aug 17, 2008
Sb5100 surfboard motorola modem I can't get an Internet connection on my laptop. The only light lit on the modem is standby. I tried unplugging it to reset it but it didn't work. Please help!
the standy by feature is a button on the top of the modem. Press button and check that all your lights come on green (power send recieve and online). then you should have connection
Jan 09, 2011 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
IS THERE A WINDOWS7 DRIVER FOR the sb5100
Hi
Try to install the same driver for Windows xp
in windows 7 in Compatibility Mode
For running in Compatibility Mode in windows 7
Right Click the app and select the properties
select the Compatibility Tab
select the os =windows xp sp3
and dont forget ti tick "Run ad Administrator"
Download Here th driver(xp)
Feb 10, 2010 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Need to get wireless on my laptop,
No, the SB5100 is just a cable modem, not a wireless router. You will need to keep your sb5100 but you will need to purchase a wireless router if you want wireless on your laptop. If you can also plug your laptop into the sb5100 via an ethernet cable for your internet connection. Linksys and Belkin and others make wireless routers that you can use for your wireless connections.
May 01, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Laptop doesnt find connection to cable modem
download setup wizard to find connection from windows
Feb 12, 2009 | Acer Aspire One PC Notebook
I can't install modem drivers for SB 5100 motorola (usb) on my laptop having windows vista. An error is showing that no cable found connecting the modem and computer. Can someone help me how to set this...
Here are the current windows Vista drivers from motorola:
http://broadband.motorola.com/consumers/products/SB5100/downloads/542708-001-install-utility-b.exe
Hope this helps you on your journey
Let me know if you have anything else.
I also would recommend you use ethernet since you do not have to install any software to make it work.
You will need to reboot the cable modem when ever you change how its connected also Ethernet/USB or if it was connected to a different PC.
Please Rate
Jan 20, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Inability to connect to Internet
The easiest solution would be to use an ethernet connection. A second problem is probably on most cable modems you can either use a USB connection OR an ethernet connection you cannoot use both at the same time.
Dec 12, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Install
If the modem is already registered to your ISP then you can plug the modem to your computer using an Ethernet cable (CAT5) to your computer's ethernet port and to the modem's port as well.
If you want to use the USB cable then you need to install the drivers for it. You may go to motorola website and type in the model number of your modem to get and download the drivers.
Though, I suggest that you use the Ethernet connection instead.
Aug 02, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Motorola SB5101 Modem
reset the modem at the backside with a pen and restart the computer, check for all the leds and it should be stable
Feb 06, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Motorola surfboard sb5120 usb driver problem
Hi, Create a temporary folder say C:\Motorola and put all your unzipped Motorola USB drivers. Install your Cable Modem. If and when Windows asked where the drivers may be located, point to the C:\Motorola. If your modem has already been installed and operational and you simply want to update its current drivers > go to Device Manager and right click on your modem to update, likewise point to the C:\Motorola. Hope this be of some help/idea. Post back how things are or should you need further information. Good luck and kind regards.
Aug 30, 2007 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Cable modem Surfboard SB5120 Motorola
Dear friend you will get this drivers at downloaddrivers.com. and also you will get all drivers for other devicess.
Dec 14, 2006 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Arris SB5100 SURFboard DOCSIS 2.0 Cable Modem (50120900100) Logo
455 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
