Question about Canon MV600i Mini DV Digital Camcorder
No image through lens
When i switch my camera on, i can see all the settings displayed but it is on a black backround, i.e. no image appears on the lcd screen or through the viewfinder, yes i have removed the lens cap.
i therefore cannot record any images but i can record the sound. i can replay and view previously recorded stuff on the screen, through the viewfinder and onto the television.
  • clubbingnut Aug 26, 2008
    Hi there.
    I have the same problem described by another member on this forum. I purchased my mv600i camcorder and it was running without issue for some time.
    I now only get sound and not visuals when I try to record footage. I was advised to check out a link on this site but it no longer works.
    Does canon fix this even if the warranty has run out? what steps do I need to take to get this resolved please?
    any advice much appreciated
    Problem Solver:
  • 9 Answers
Hi
This series of cameras have born with the CCD defective!
It's a shame!, However if you replace the whole canon ccd assy
Dy1-8509, you'll spend a lot of money, while it's possible replacing only the ccd chip (ICX281)  that you can find online anywhere (i.e. Ebay.com)  for a littke money amount.
Obviously it's necessary having experience in soldering smd components!| Otherwise you've ti buy the whole assy !!!!
I've the same trouble in my mv600i and in order to make my machine working(only in a  temporary way) , I've heathed all the pins of icx281.....and now it's working again, but  the camera  is not 'reliable', and today I've ordered a new icx281 .. here (for instance)
http://cgi.ebay.it/ICX281-CCD-TELECAMERA-MOVIE-CANON--SAMSUNG-SONY-JVC---_W0QQitemZ290337707446QQcmdZViewItemQQimsxZ20090808?IMSfp=TL090808136001r11444
Posted on Sep 28, 2009
  • 2,039 Answers
See this link. In the search window type 37383, then check the "Search by case ID" box below it, and click on Search. Your model falls within the list of models affected by this problem, and Canon should repair it for you regardless of warranty date.
Posted on Jul 03, 2008
Olympus e420 no live view black images
are the photos on the memory card? LCD could be shot or loose.
Mar 12, 2014 | Olympus Cameras
Red pixels
Try connecting an external monitor to the computer and check if the external monitor displays the same thing. If the external monitor is fine then you would need to fix the LCD of your laptop. or have it replaced.
If the external monitor displays the same thing, then you would need to update the video driver in your computer. You can use RadarSync to automatically update the drivers.
David
May 30, 2013 | Computers & Internet
I have Panasonic Lumix DMC TZ3 camera and it suddenly stoped working when i switch on the lcd is black first i thought my lcd has problem but i can see images from my memory card very well only when i go...
Hello
First, if the camera turns on and the lens extends properly, toggle your "display" button until the screen image returns. (you can turn the display off via this button and is most likely the issue).
Otherwise, it would indicate a greater issue that would require the camera to be sent in for service.
Mar 10, 2011 | Cameras
Photos have a black corner. Sometimes upper right, sometimes lower right. The black corner covers approximately 5% of the width and height of the image. Can I fix this myself?
This might also come from a problem with a dealignment of one of he servo-motors (horizontal or vertical) which center the lens during anti-shake adjustment.
If your camera vibraets at start or shows a vibrating image on display then this is the problem.
Then the lens is often out of axis and black corners appear on the display and of course on the picture...
I have not found the solution but have posted a request !
It may only be some disconnected part near the lens but unfortunately nobody shows pictures of HOW to dismantle the Z5 ! and WHERE are these 'bloddy' servo-motors or alignment devices ?...
Sep 14, 2010 | Konica Minolta DiMAGE Z5 Digital Camera
Camera switches on but no display on screen it is black. when switch on camera screen shows canon logo and beeps then goes black on image shown on screen
The black screen problem means the lens sensor is spoiled due to over exposure to heat. Its better to give it to cannon service centre. If your camera is under warranty period its well and good they will replace the lens sensor for free of cost.
Thank you
Jun 10, 2010 | Canon PowerShot A60 Digital Camera
When I take a picture, the display and picture are black.
The shutter is jammed shut, lens unit needs to be serviced.
Jun 10, 2010 | Canon PowerShot SD850 IS Digital Camera
The display image unseen and the screen is dark
display shows ,saf, memory card ,charge symbols but not the capturing image on the display screen.After some time the camera is switches off.
It is sony cyber shot DSC- T33 .
Dec 10, 2007 | Sony Cyber-Shot DSC-T33 Digital Camera
Black Display Screen
first check the iris of the camera if it is opening,you will see this when you look inside the lens of the camera when you turn on and off the switch at camera mode if the iris is opening....if the iris is ok the second problem may occurs of your camera is the ccd image sensor....
Oct 31, 2007 | Sony Handycam CCD-TRV68 Camcorder
Blank lcd screen
wires have come off the ccd ! canon will fix free of charge,go to canon support
May 31, 2007 | Canon MV600i Mini DV Digital Camcorder
No image displayed through viewfinder or lcd screen
could be one from a batch with faulty CCDs - check out this fixya link (solution 2) - http://www.fixya.com/support/t115316-canon_mv30 - it's copied from a page at imaging-resource.com - my MV600i was out of warranty and I sent it back to Canon at the end of 2007 and they got it going again free of charge within the week - unfortunately within weeks a very similar fault appeared and now they're trying to charge me for the repair !!! even though they say repairs are under warranty for six months -
May 23, 2007 | Canon MV600i Mini DV Digital Camcorder
Canon MV600i Mini DV Digital Camcorder Logo
244 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
