Question about HP Photosmart 945 Digital Camera
PH 945 Problem
Idid remove the batterys and sd card but the probleme stay the same. please help if you can
  • 2,712 Answers
Looks like you will have to reinstall the firmware from the manufacturer's website. If you are unsure how to do this, then I suggest you contact a service center
Also pls change the rating from Inappropriate to at least Helpful or Thanks for trying here:
Posted on Jul 03, 2008
How do you put a sim card in
Depending on the Phones Make and Model and what type of SIM card you are NEEDING if SIM card didn't come with PH?
You can go online and look at diagrams of the Various SIM cards. Most SIM card fit Behind the Battery of your Smart PH. You must carefully remove back of ph most smart phone have a small indention to assist with removal? If not either use your nail or THIN OBJECT (Fake Nail Tips Work Great, Even your Nail, plastic/Wood Tooth Pick or any thin enough non metal to open seal ) Then carefully remove back of ph then Battery the SIM card slot will either be on the side or Top or bottom behind Battery space Slide Sim card in with Metal connector sides down in direction indicated then replace battery and back of ph. Some Phone come with a Internal SIM Card for Programing of phone, the other SIM card Slot is for Memory make sure if this is what is NOT Situation your PH? Some even have Duel SIM Slot they Usually can be programed with either type of SIM Card Purchased these are for the new I call Free-agent Phone meaning you Purchase your Phone and Choose your Carrier Such as Straight Talk ect.
Apr 01, 2017 | Cell Phones
When the power is turned on, the lens stays in the camera, it starts beeping and it tells you to turn the power off and on again
1) Remove SD Card.
2) Remove Battery.
3) Hold power button for 10 seconds.
4) Install Battery.
5) Attempt to power on.
6) If works, reinstall SD Card and you're ready to go!
Thanks and please rate if this helps you!
Mar 29, 2011 | Sony Cyber-shot DSC-N2 Digital Camera
Does Hp 945 work without a memory card
Yes, but the camera has only 32M of internal memory so you won't be able to take and store more than a handful of pictures. For "real" use you'll need one or more SD cards. Make sure you get SD cards 2GB and smaller, not SDHC cards.
Aug 18, 2010 | HP Photosmart 945 Digital Camera
My hp 935 is saying that the memory card is locked. I have turned the camera off and back on again. It still does not work. I have taken the batteries out and back in and nothing. I do not know what to do....
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Mar 11, 2010 | HP Photosmart 945 Digital Camera
I got a 4gb memory card-SanDisk and the camera says it is unreadable.i had a 512mb card and it worked fine.
Hi Tomcat,
this will not work.
The HP 945 does not support 4GB cards.
4GB (or more) are SD-HC (High Capacity). This is new format which only will be supported by newer camera models.
Jan 10, 2010 | HP Photosmart 945 Digital Camera
Sidekick Lx screen is white with 4 black symbols on it
well dude i can help you i JUST fixed my friends cell we were searchin online fo a solution..
do this step as follows
1. remove the backpiece
2. remove the battery
3.remove the sd memory card the battery back in the supportive slot attach the backpiece
6. power up the fone
and wallahhhhh!!!! ^_^
the memory card is the problem
he placed the card back in the fone and the problem continued ...
u may need to purchase a new sd card
Nov 20, 2008 | T-Mobile Sidekick II
HP Photosmart 945 Digital... Problem
Remove the batteries and SD card for about 5 minutes. Reinsert and see if that resolves the issue..
Jul 02, 2008 | HP Photosmart 945 Digital Camera
Card locked?
hi, if that would have happend to me the first thing i would try is to clean the SD card socket with alcohol.
open the camera and gie it a try.
Jul 11, 2007 | HP Photosmart 945 Digital Camera
Hp 945 Digital Camera
hi there, try another SD memory card, i had the same problem.. but then i bought a new card and the problem was solved... best regards, Richard.
May 06, 2007 | HP Photosmart 945 Digital Camera
Green light turns on but no screen...please help thanks :)
I had this happen when my sd card was damaged when the battery compartment cover was bumped and opened when the camera was in the process of saving a picture. Remove your sd card and then see if you can bring the camera up and take a couple of pictures using the camera memory only. If you can do this, then buy a new sd card. What ever is on the damaged card may be lost
Dec 16, 2006 | Apex Digital Digitrex DSC-4500Z Digital...
HP Photosmart 945 Digital Camera Logo
75 people viewed this question
Top HP Cameras Experts
Fred Sops
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
