Question about Shure Audio Players & Recorders
I have a Shure beta87 Mic, the plug where the cable connects to the mic got pulled out with the cable and lost in a club, is it possible to buy a replacement for it or can I send it in somewher e to have it done?
  • 1,512 Answers
Hi noahrock
You can get a replacement lead from a musical instrument store. It uses a standard microphone XLR connector. Be sure to get a decent quality item that uses Cannon, Switchcraft or Nuetrik connectors. You wont have problems with the plug coming off again.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards robotek
Posted on Jul 03, 2008
No sound
1st thing to try is a different XLR microphone cable. Sounds too simple, but sometimes it's the cable. If the mic has ever been dropped/damaged, OR has seen alot of saliva/spit from singing into it...it's possible the diaphragm has crapped out. At which point, get a new mic, because the SM-48 is not an expensive mic to replace with same.
Jan 06, 2013 | Shure SM48 Professional Microphone
My mic has a faint sound
Have you tried other microphones in this circuit or connected the microphone to another cable. If the problem stays with the microphone go to shure.com, look under support to find information on repair. If the problem does not go with the microphone you have another problem. Of course it could simply be indicating the gain has been turned down on the sound system.
Mar 20, 2012 | Shure Beta 58A Professional Microphone
Weak audio static uc2-ub handheld
Sounds like either local interference or it needs to go to Shure for repair. Can you try it in another location maybe 10 miles or further away from the present location. If it operates in the MHz band you need to replace it, it is illegel to use that band in the US..
Mar 13, 2012 | Shure Beta 87A Professional Microphone
I am having a poping sound after each breath. It can be heard distincly in the speakers. It may need cleaning, how is this done correctly? tnt39028@gmail.com beta87a shure wieless
I don't think cleaning is going to resolve your problem. Perhaps there is something wrong with your mic and it might need to be sent in for repairs.
Aug 29, 2010 | Shure LX2/Beta87 Professional Microphone
Shure sm58 mic stopped working ...
Check the wire connections where the xlr cable connects.
Apr 12, 2010 | Shure SM58 Professional Microphone
Shure sm58 just started outputting very low volume. It has been working fine with our system for years. Tried other sm58 mics on the same mic cable with same system setup and no troubles. There is still...
Check your wire connections inside the mic where the xlr cable connects to the mic. Hopefully your mic has never been dropped as this will damage it. The sm58 is pretty much indestructible, so check your cabling that you use, try a different channel.
Apr 04, 2010 | Shure SM58 Professional Microphone
Shure 58 when plug it has no sound
First i would check the cable. If cable seems good I would buy some contact cleaner and try cleaning the xlr pins on the bottom of the mic. Last i would take the set screw out of the side of the mic and carefully remove the xlr assembly. There are 2 wires connected to that and not a whole lot of slack so be careful. Basically make sure they are still soldered on.
Mar 27, 2010 | Shure Beta 58 Microphone
I think the connections in the mic are loose or its broken. how can i get it fixed & how much will it cost.
A common fault with all corded/cable microphones is that one of the wires inside the cable breaks.
- I am assuming you are talking about a cabled mic?
It's possible to repair the cable if you have a soldering iron. This is the cheapest way to fix your problem.
If you don't have one, suggest you buy a new cable from your local Shure stockist.
The other major fault that occurs with mic's is that they are dropped - and that will show the same symptoms as you have descibed above if it has been dropped a few times - especially onto hard surfaces or floors!
The cable will only cost a few £'s or $'s, should be less than 10.
Nov 19, 2009 | Shure Audio Players & Recorders
Shure 87a no sound
Send the mic to Shure for repairs. www.shure.com/service
Sep 12, 2009 | Shure Beta 87A Professional Microphone
Lost user guide sm58 wireless mic
The User Guide can be found on the Shure website.
Dec 19, 2008 | Shure ULX Standard Series Wireless...
65 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
