Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
Ip problem When i put 192.168.0.1 in my web browser address bar it doesn't bring me to the security set up page but the page for my Qwest dsl modem, So i can't secure my wireless I am unable to get onto the http://192.168.0.1 to configure my security for my D-Link Router model WBR-1310
    Sergeant:
  • 313 Answers
That is telling me that your Qwest DSL modem is not in bridge mode, and is using the same IP address.
What model number is your Qwest DSL modem - it setup features are listed on :
http://www.qwest.com/internethelp/modems/
1. Change to bridge mode
a. If that model does not have it listed to change to bridge, make sure DHCP is turned off on the Qwest modem so the new d-link router can be seen.
If not sure, ask your Qwest ISP for help, it is there modem and they will be able to walk you through putting it in bridge mode.
Posted on Jul 03, 2008
    Sergeant:
  • 287 Answers
It is common to have this as the default IP to connect to equipment.
I suggest you unplug your modem while you set up your router. You can also change the default IP for the router while in the settings. be sure to remember the new IP or you will have to do a factory reset to get it back to default
I am trying to find my password for my d-link di-624 router-i have wireless setup but i have lost my password to load on my laptop to connect to the internet. I have a qwest dsl modem with wireless...
First connect your router to computer with ehternet lan cable then go to network adapter property.For that press windows key +R so you can see run type in run "ncpa.cpl" then press enter then you can see network adapter property. go to your network adapter tcp ip property and enable "ip get automatic" then it will get ip from router if dhcp enabled.Then go to command prompt type "cmd" in run so you can see command prompt.Type in prompt "ipconfig" then press enter then you can see all ip address gateway ip is your router ip address .Note that ip then type that ip in address bar of internet browser then you can see your router page.Also the default ip address to access router is http://192.168.1.1 or http://192.168.0.1 Try these ip hen you can see router page .But if you are still not able to see router page with above ip then need to reset it.press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . After seeing router page type user as "admin" and password as "admin" or blank or "1234" or password. then you can see configuration page of routerThen click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password.If you have to reset router for access it then also need to configure WAN ,wireless,DHCP on router . Let me know if you need further assistance. Thanks for using FixYa
Oct 19, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
Cant set security
According to you security settings of your modem is difficult for you.
But you don't have say the OS you are using there. It depend on modem and OS. while installing the driver supported your OS select the PPPoa/PPPoE. After installing go to the web explorer and type the link (IP add) of your modem at the address bar and enter in the modem settings. Your modem vendor will provide this IP or see the manual.
Then go to the security settings and set it pasword protected. Enable the NAT (Network Address Translation)with your Private IP address for security. You can follow the manual to set it properly
Mar 24, 2011 | Zyxel Prestige 630-C DSL Modem...
How can I secure my wireless internet?
launch a suitable web browser and direct it to the IP address of the
Router. Type in http:// followed by the default IP address, 192.168.1.1 in the address bar of the browser. The
URL in the address bar should read: http://192.168.1.1
hit enter. Use the default user name: admin and password: admin
Then login, this will bring up your dlink settings page.
Click "setup" at the top of the page then "wireless" on the left. For the security option on the page choose "WPA" then underneath choose PSK string. Leave everything else as default. You will see beside the option String: and a box to type in. This is your wireless password. create a password of your choice and click apply at the bottom. Your wireless network is now secured with that password. you will be prompted for it when you next connect wirelessly.
Apr 14, 2010 | D-Link DSL-G604T Wireless Router
I am trying to configure my netgear router to work with my dsl motorola modem
You can access your wireless router by first running you ethernet cable from pc to wireless, then in address bar, type 192.168.1.1 and this will enter the wireless router's software. If it asks for username and password, try typing admin for both.
Sep 03, 2009 | NetGear WGR614 Wireless Router
Just changed my dsl and I have a router too.
you'll need to use your web browser to access and configure the modem, like this:
1) connect your computer ethernet to the running modem, wait about 1 minute..
2) click start, run, type cmd in the run dialog, click ok
3) in the command window type ipconfig then enter. write down the gateway address, probably 192.168.0.1 or something similar
4)open your browser, wait for the error, then type that address into your address bar. that should get you into the modem where you can do it's setup.
Jun 08, 2009 | Alcatel Speed Touch Home Modem
Can't connect to 10.0.0.2
Googling that address will get you nothing. There are specific blocks of IP addresses that are not used on the internet. Instead, they are reserved for use in private networks. The addresses in these ranges are not available for use on the internet:
Class A networks: 10.0.0.0 - 10.255.255.255
Class B networks: 172.16.0.0 - 172.31.255.255
Class C networks: 192.168.0.0 - 192.168.255.255
What they are telling you to connect to is your DSL router which must be using the 10.0.0.2 address for it's own web-based configuration tool. If you open up your web browser and type http://10.0.0.2 into the address bar and hit enter, it should bring you to their configuration utility that is built into the router.
Apr 02, 2009 | Zoom X6 (5590) DSL Modem (55900003)
Belkin DI-604 router connection problem
Change the router's IP address to 192.168.10.1, The Qwest modem like Action Tech have the same IP address with the router.
To change the router's IP address you might needing to access the configuration page of the router, then proceed to the LAN settings.
Mar 24, 2009 | Belkin (F5D5231-4) Router
Ip problem
try 192.168.1.1 or 192.168.0.1 or 192.168.1.2
please reply if this helps ans please dont forget the power of the vote
p.s GOOD LUCK!
Jun 09, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
We recently got high speed internet from Qwest. It will not work. It keeps saying that the can't "ping" it. All light are green; power DSL, and the Ethernet. The internet is not. I have...
The DSL router/modem will receive an address from your ISP (Qwest) and will assign an address to the connected PC.
There should be a cable that goes from your DSL modem to your PC. It'll either be a USB cable (flat rectangular plug on the PC end), or a RJ45 (looks like a wider telephone plug).
If there is neither connection between the DSL modem and your PC, then the PC can't "talk" to the DSL modem, so it's not getting an address from the DSL modem.
Apr 06, 2008 | Computers & Internet
No access to set up modem or router
you might have configured your lan settings wrongly.
If your modem was setup for DHCP then you configure your lan to receive IP address automatically, DNS automatically.
If DHCP is disabled on the modem, you have to USE static IP Address for your lan ip and default gateway should be your modem default ip.
the default IP for modem is usually 192.168.1.1
if DHCP is disabled on the modem the sys ip is 192.168.1.3
So Configure your LAN setting as follow and Type http://192.168.1.1 in the address url.
Lan Settings:
IP Address: 192.168.1.3
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.1.1
click ok.
and type the above url, press enter the modem will ask you for username and password.
Good Luck.
Dec 27, 2007 | D-Link DSL 300G+ (DSL-300G+) Modem
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
167 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
