Toshiba 36ZP180 CRT TV. It keeps switching off at irregular intervals. Sometimes does not do it for days - other times it will switch off after 30 seconds - and then refuse to stay on.
  • geeteese Dec 02, 2008
    My Toshiba 36ZP180 CRT TV keeps switching off as Craiglowe has described up above. Is this a Toshiba problem?
techman
  • 3130 Answers
SOURCE: toshiba 42wt29b. screen keeps turning blue
MMMM Hard call here. The fact that it does try to come on blue maybe an indication that the power supply regulator circuit is good. It could also be a shorted blue tube and when it comes on its overloading the screen drive and the set goes into overload protection shutdown. The real way to see Would be to pull off the blue crt socket as well as the Hi Voltage lead on the crt and see if the set comes on without blue. If it does Your gonna need a pict tube. If it dosent then troubleshooting along the switched power supplys would be neccassary.. BUT I advise you THAT IF YOU HAVE NO EXPERIENCE TROUBLESHOOTING TV SETS PLEASE SEEK A PRO TO ASSIST YOU AS THERES VERY HIGH VOLTAGE INSIDE THESE SETS EVEN IF THEY ARE UNPLUGGED. GOOD LUCK
Posted on Jun 29, 2006
  • 1462 Answers
SOURCE: Why does my oven keep switching off?
there is a casing stat which senses overheat. this can be due to lack of ventilation if a built-in type or a fault with the fan
Posted on Mar 20, 2007
SOURCE: TV cut out and stay on standby
hold the power switch in from off for 10 seconds, worked for me.
Posted on Sep 03, 2007
  • 4234 Answers
SOURCE: sound cut-out
Most likely this unit goes into protect mode due to heat detection. Try to see if there is a pattern to when this behavior starts. Does a lower volume level allow the unit to run longer? Perhaps there is a problem internally that is allowing DC voltage to get to the output stage. This will cause excessive heat which can then cause the protection circuit to kick in. This unit may need to see a bench with some test gear to locate the exact problem. If you can, look for any pattern and update this.
Dan
Posted on May 13, 2008
  • 346 Answers
SOURCE: tv switches off on its
get a schematic diagram.look for any switching transistor(s) in the power supply and replace
Posted on May 28, 2008
HI, I have a 42 toshiba regza tv that is 3 years old when watching tv the screen goes blank and the sound is still there i power it off then back on and the picture is fine. Somtimes wont happen for days...
If you are using a hdmi cable take it off and switch to component cables if the problem goes away keep it that way. Sometimes the hdmi hookups have bugs like this.
May 25, 2012 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Problem with JVC CRT TV (slim) with screen to have red color at the lower left (facing the TV) corner and a green color on the upper right corner of the screen. Sometimes while watching TV shows, the upper...
There is strong magnetic field around the TV. This may be due to the tower speakers or any portable radio kept close by.
Re orient the TV try switching OFF / ON at the intervals of 30 minutes. The built in auto de-gauser will correct the problem. In cable TV program if the picture is OK, nothing wrong in the TV.
Check with a different CD.
May 19, 2010 | JVC AV-21QMG3 21" TV
Yellow tint on right side of screen sony wega kdf-wf655
Tube got magnetised.
Re orient the TV in a different direction entirely opposite. Switch on TV, Switch Off. wait for 30 minutes. Again Switch on. Repeat at this interval. The auto de-gausing circuit will de-magnetise it.
Otherwise you have to degause it externally. Contact service center.
Apr 27, 2010 | Insignia NS-27RTV 27" TV
Sometimes the on/off switch doesn't work and we haven't been able to program the DirecTV remote to turn the TV on and off. We did discover that the original Toshiba TV remote will turn the TV off and on....
Could have a bad power switch or a bad ground on the switch itself. Will the original remote work to on and off the tv every time? If not you may a bad filter cap or two near the horizontal deflection.
Oct 10, 2009 | Toshiba 32D46 32" TV
Lots of water in bottom of refrigerator
Every ten to twelve hours or more irregular intervals if equipped with an adaptive defrost control your refrigerator activates a heating element around the evaporator to defrost the accumulation of frost that develops on the evaporator. Behind the back panel there is an evaporator pan it has a rubber grommet with a hole in it this is your defrost drain hose it is clogged. Unplug or switch refrigerator off at breaker panel, remove panel covering evaporator area (rear panel in freezer), use a hair dryer or hot water to unclog defrost drain a turkey baster works well to make sure the hose is unclogged.
the water that drains down this hose accumulates in the defrost drain pan in the base of the refrigerator under normal operation the heat from the refrigeration system evaporates this water. The drain pan has a limited capacity so do not poor more than 20-25oz of hot water down the hose after you unclog it. If you poor to much it wont hurt anything just make a mess youll have to clean up.
Apr 02, 2009 | Estate TT14DKXKQ Top Freezer Refrigerator
32dw television
there might be some weird out in wiring between Reciever and Picture tube. the issue is big. contact authorised service personnel
Dec 19, 2007 | Philips 32PT6441/37 32" TV
Tv turns off at irregular intervals
MOST PROBABLY DRY SOLDER IN THE POWER SUPPLY SECTION OR REPLACED THE HORIZONTAL DRIVER TRANSFORMER . MUKU
Oct 16, 2007 | Durabrand DWT1905 TV
Flashing in and out picture
This is crt base failure due to corrosion. That is why to wont get clear picture initially when you switched on in long interval period. Change crt base problem solved.
Sep 09, 2007 | Toshiba 27AF41 27" TV
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
