Related Tags:
This problem should be removed because:
Problem with Microsoft SQL Server 2000 Standard Edition for PC
TRIGGER IN SQL
WHAT IS TRIGGER IN SQL. WHAT IS THE USE OF TRIGGER
Solutions (1)
A trigger is a special kind of stored procedure that automatically executes when an event occurs
in the database server. A trigger is really an event handler.
SQL Server allows users to create triggers (event handlers) for 3 types of events:
- DML Event - Occurs when a DML (Data Manipulation Language) statement: INSERT, UPDATE or DELETE, is executed.
- DDL Event - Occurs when a DDL (Data Definition Language) statement: CREATE, ALTER, or DROP, is executed.
- Logon Event - Occurs when a user logins to the Server.
- DML Trigger - Executes in response to a DML event.
- DDL Trigger - Executes in response to a DDL event.
- Logon Trigger - Executes in response to a logon event.
SQL server won't work on my laptop
I have SQL Server 2000 installed on my "local" server, using the default settings, and want to use it with Visual Studio 2003....
sql server
how to install sql server on window XP?
sql server
how to download the software sql server
time based triggers or procedures
how to write triggers, in a table one field value decrement by one for next day
Add Your Solution
How can I rotate pictures
How can I rotate pictures in document.. I use ofice 2000
i am using netbeans IDE 6.9.1 SE. I am also using
i am using netbeans IDE 6.9.1 SE. I am also using JTDS driver to connect.but when i try to connect through my progamming...
I have SQL Server 2005 Standard edition running
I have SQL Server 2005 Standard edition running and have created Backup remotely. I am trying to replicate data via pull...
I can't connect the ms-sql 2005 database with...
java.sql.SQLException: Network error IOException: Connection refused: connect at...
See all Microsoft SQL Server 2000 Standard Edition for PC Problems
Fix-O-Meter
43
43 people viewed this problem
- 0 people are following this problem. Be the first!
Top Microsoft Business and Productivity Software Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
