Question about Whirlpool Calypso GVW9959K Top Load Washer
Fault code C1
What is the fault code C1 mean for a Whirlpool Calypso washing machine.
  • Anonymous Mar 30, 2014
    Kenmore Washing Machine E-20
  • 5,911 Answers
"C1" is known as an Instantaneous Current Limit Error. This will occur when the Motor Controller detects a current spike of 26 amps or greater at the motor windings. Overloading the washer, excessive water and/or excessive suds can cause this problem.
The manufacturer recommends the following:
- Wash smaller loads and use the correct detergent (HE only for Calypso machines). NOTE: Make sure the HE detergent is not double or triple concentrated as this will also cause suds problems.
- Check for objects under the nunate plate. This is the wash plate. Sometimes clothing can get stuck under the plate and cause the motor to bind up. To remove the nunate plate, follow these instructions:
1. UNPLUG THE WASHER.
2. Open the washer top. Look along the front seam of the washer where the top meets the front. There are a couple of retaining clips (about 2" in from each side) that you will need to push in on with a putty knife while gently lifting up on the top to get the top to release. Carefully open the top and lay it back against the wall in a resting position. Make sure you support the lid so it doesn't fall open when you tilt the top back.
3. Remove the tub ring. This is the plastic donut shaped ring that sits on top of the wash tub. There will be a tab on either side of the outer tub near the back that you can use a screwdriver to release the tub ring. The ring is filled with fluid and is used to balance the tub. So, if you hear liquid sloshing around, this is normal.
4. Remove the center cone from the wash plate. Use a flat blade screwdriver and insert it into any of the slots available along the sides. Gently pry until it pops off. I say "gently", but you may have to use a little muscle to get it to come off. Sometimes they stick. Once the center cone is removed there will be a series of nuts under it.
5. Remove the nuts and the wash plate should lift out. Be careful not to damage the gasket under it. Clothing can get tangled in the leveler under the wash plate. This leveler should have a key on it. The wash plate will only go back in with this key mating to a slot on it. So, remember how you took it off. In addition, when putting the wash plate back on, make sure you tighten the nuts in a cross pattern and evenly tighten them as you go. This will ensure the gasket seats properly. Don't forget to put the tub ring back in.
- Check for objects stuck between the inner wash tub and the outer basket. NOTE: It is best to do this with the nunate plate removed. Use a flashlight to peer through the holes in the wash basket to see if anything is catching on the tub.
- Check the Motor Controller. You will need to determine if there is power getting the the board first and that the fuse on the board is good. If any components on the board are defective, the board has to be replaced. If you have power to the board and the fuse checks good, check for continuity between the Machine Controller and Motor Controller.
There is a tech sheet inside your washer along the interior cabinet (usually the front panel) that explains all these procedures to you. I would advise you to research the tech sheet for exact locations of the pin outs for the circuit boards. Its easier for you to view it rather than me explain it. If you need further assistance, please post back and let me know. I hope this helps you.
Posted on Jul 03, 2008
Fault saying no, press start for 5 seconds to clear, then it goes to nrO, press and hold again it goes back to no. Please help.
Whirlpool Calypso Washing Machine diagnostics & Error ...
applianceassistant.com/Washer-Repair/Calypso/Calypso-Diagnostics.php
Whirlpool,Calypso,washing machines,repair,troubleshooting,PF,FL,Er,LF,CE,Ld,CA,CI,ob,Sr,LS,SL,error code,problem ... within five seconds while the machine is in Standby Mode. ... The washer does not flash"PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost -OR-
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Drain pump error, Water level does not decrease to reset point .... If after 30 seconds the control does not detect water entering .... Press START to continue the cycle from the moment that power was lost ... Check pins 1 and 5 of P16 of the machine controller and pins 1 and 2 of P1 of the motor controller.
[PDF]Fault Code Bible v1.2.pdf - ResearchGate
Dec 02, 2015 | Washing Machines
My Whirlpool Calypso is flashing C1 when I try to start a load
Hello
C1/CI code indicates instantaneous current limit trip. This instantaneous current trip occurs if there is a spike of 26 Amps instantly at the motor windings.This may signify problems with the drive motor, thermal protector or motor controller. Overloading the unit may cause this problem. Press STOP/CANCEL to clear the display. Please get back to me if you have any other questions.
Kevin
Nov 09, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My washer keeps stopping and is flashing C1. Can you tell me what this means
The CL fault indicates that there was an instantaneous current spike of 26 amps at the motor windings in the washer. This could be caused by overloading the washer. It can also be caused by problems with the drive motor, thermal protector or the motor controller.
You should have been able to clear the display by pressing the STOP/CANCEL button.
If you try running the washer again and continue to get this fault code even with a small or medium load, I recommend calling a service technician to diagnose and repair the washer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 24, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
What does c1 mean on the display?
Hi
C1 means the motor 'overloaded'
This means the electrical current through the motor was higher than it should be, there are three things that could cause this:
- A load that was too big for the machine, too many clothes, too big of a blanket etc,
- A bad motor
- A bad motor control board
Jun 14, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Get LD error/ fault when washing
This error code means long drain.
What this means is that the drain is either clogged or kinked. Please inspect your washers drain hose and than press stop/cancel to clear the code.
Jan 13, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My kenmore elite calypso has a flashing code C1. What does this mean. Also, how can i get a manual for this washer, that explains all the codes.
C1 is not one of the normal codes. It's probably CI (upper i).
Stands for 'Instantaneous current' limit trip. Happens when there is a spike of 26 Amps intensity at the motor windings.
The manual states it may be a problem with the drive motor, thermal protector or motor controller.
check here for your stuff. make sure you put your exact model number in the box at the top. i used my machine (GVW9959KL1). absolutely awesome website and has very competitive prices, if not the best prices for parts. hope this helps.
-samson39
Aug 18, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Machine won't work it says C1 message. pls advice.
On Whirlpool Calypso washers that is probably not a "1" but is the letter i. The code "CI" is the fault code that indicates "Instantaneous Current Limit". Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings.
This may signify problems with the drive motor, thermal protector (fuse), or motor controller. Overloading the washer may cause this condition. Press stop/cancel to clear the display. Hope this helped you.
Jul 21, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore elite calypso codes a C1 and quite working
Maybe "CL" From User Manual:
“CA” or “CL” (Current Limit)
Is the washer overloaded?
Jul 04, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
C1 Fault
code CL.(C1) This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem. Calypo washers do have a history of break downs within the drive system.
Dec 08, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
425 people viewed this question
Dan Webster
Dan Webster
Sal De
