Question about GE Profile JTP18 Electric Single Oven
Oven burner We turned the oven on and in about 3 mins the coil ignited as though it were being welded. The coil was burning with an almost-like white heat and it was hard to even look at it This evenually burned the entire coil and broke in half.. even when unplugged the power is still on . It is as hot as when it is on self cleaning. we are afraid to go to bed.
  • Anonymous Nov 06, 2008
    Exactly the same thing happened to one unit of my GE wall oven today, except the oven was on for about 20 minutes. I just had the control panel replaced about 5 months ago. What caused this?
  • 943 Answers
Hi thanks for the question. you saw the element burn its self out . its burnt out know don't worry go to bed . replace the element tomorrow . thanks the appliance doc
Posted on Sep 29, 2008
My maytag oven won't light what do I need to do?
When the bake igniter becomes weak or burns out, your oven will not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve
-- defective gas valve coils
NOTE_ If the ignitor did not appear to function and it is the spark type, it may be out of adjustment which generally requires professional service or it may require replacement.
Jan 09, 2010 | Ovens
Oven will not light. it is a frigidaire model #
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve will not let the gas out into the oven burner. A weak igniter must be replaced.
  1. Defective thermostat
  2. Defective selector switch
  3. Defective gas safety valve
  4. Defective gas valve coils
Dec 17, 2009 | Frigidaire Ovens
Gas oven won't ignite
Nov 15, 2009 | Bosch Ovens
Ignitor lights up and I can smell and hear the gas, but the oven will not light
Nov 13, 2009 | GE Ovens
I HAVE NO IGNITER OPERATION OR GAS COMMING THROUGH THIS OVEN, ITS SUPPOSED TO BE RELATIVELY NEW.
Nov 09, 2009 | Electrolux Ovens
My kenmore gas oven won't heat. I turn to dial to temp i want can smell gas building up in oven and can see a glow in bottom of oven but will not ignite. Sometimes if I turn on a cooking eye I can then...
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
Oct 22, 2009 | Whirlpool SB160PEE Gas Single Oven
OVEN WILL NOT IGNITE IT IS GETTING GAS TO THE SILVER PC IN THE BACK
Oct 21, 2009 | Magic Chef Ovens
Oven will not relight during cooking cycle
When the bake igniter becomes weak or burns out, your oven would not bake properly. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
Oct 20, 2009 | Whirlpool SB160PEE Gas Single Oven
The gas oven will not light. gas burners light but oven does not
O-defective thermostat
O-defective selector switch
O-defective gas safety valve
O-defective gas valve coils
Sep 20, 2009 | Ovens
Oven will not light
Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too. spark-anim1.90x11.gif
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system
Nov 20, 2008 | Frigidaire Ovens
GE Profile JTP18 Electric Single Oven Logo
80 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
