Question about Goodman GMS90703BXA Heater
Condencing unit air is cold and then after 20 minutes comes out hot
Hmm i cleaned the a coil and everthing worked fine
Posted on Aug 12, 2008
  • 1,420 Answers
Check filters to see if dirty, clean or replace. Is the coil or condensing unit iceing up? If so, have your system recharged and checked for leaks.
Posted on Jul 25, 2008
2000 caddy Seville ...after starting and engine warm turn on the heater and it blows cold air. Fan works / waiting for hot air and then all the sudden it kicks in. Engine at normal temp
Low coolant, if there is an air pocket in the engine it will make it to the heater core. Once there , the air coming out is cold/cool. Once the coolant fills the heater core, it gets hot. If the coolant is fine hot or cold, then have the HVAC system scanned.
Oct 09, 2016 | 2000 Cadillac Seville
Air condtioning unit
check capicitor on motor, fan motor bearings may be locking up when they get hot then when cooled the motor comes back on. Then you must replace fan motor.
Aug 11, 2009 | Heating & Cooling
Buzzer noise from carrier A/C condencing unit.
Sounds like the contactor is bad.It has a magnate that pulls in with a call for cooling,It will buzz like crazy sometimes.
Jul 13, 2009 | Carrier Heating & Cooling
On my 1995 chevy blazer s-10 my face vents are not blowing air
Your heater valve is stuck open, also in a pinch you can crimp off your hose to the heater coil at fire wall. Try to find the heater valve vacumb hose under the hood see if it is bad and fixit. or some models have a cable to the valve could be broken.
Jun 02, 2009 | 1995 Chevrolet Blazer
I have a 2005 Honda odyssey. When I turn press the rear A/C button, the whole A/C system blows warm air and the a/c doesnt get cold at all....Is this a clogged hose or something??...
Hi i have 06 exl odyssey and i had SAME problem it was like this you turn on front ac and it works and when you turn rear ac then they both blow hot air . What is was a rock hit ac condencer . dealer replaced condencer it was like $700 bucks do not go to dealer just buy condencer for $120 online and it easy to change it and then refill with freon Also after that I put mrs grille on my odyssey . looks good and no problem at all Those condencer are common problem JUST DO NOT GO TO STEALLERSHIP
Apr 13, 2009 | 2005 Honda Odyssey
We have a roof top mount cetral heating & air unit and its a day& night unit it will blow air out but not cold air .went on top of roof to check condencer and it is hot and coils are normal...
sounds like the compessor over load is cliking on&off compressor not starting could be a capacitor or compressor or if your lucky a contactor dan
Jul 13, 2008 | Heating & Cooling
Magic Chef MCWC30MCG not getting cold?
You need to replace the Ptc unit attached to the compressor. Go to REPAIR CLINIC.COM and order the following part. 1206838 Ptc relay. They also will show you were it is located and how to replace it. Compressor tanks very rarely go bad. It is an $11.00 dollar part
May 28, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Hotpoint washer dryer leaking water whilst drying
driers work by running cold water down the back plate of the machine so the hot damp air condence's on to it. It works on the same principle as your bathroom mirror, because its colder than the air around it the moistier in the air condence's on to it. Most machines use a seperate inlet valve from the cold water to do this, they are proned to rub against the back of the drum.Take the top cover off the machine and check the hose's from the cold inlet onto the back of the machine you'll probably find a hole worn in it.
Oct 21, 2007 | Hotpoint Ultima WD72 Front Load...
Goodman GMS90703BXA Heater Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
